D16y8 n/a build
Old 10-19-2008, 11:01 PM   #151
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 26 philyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the rough
Alright that works...what about type-r cams? Would they give anymore power than the gsr cams? Either way having a b16 in my car rather than a y8 like I have had will feel like a big change in power. I think I have almost settled on that swap however I have also thought about just waiting and finding a block for cheap dropping it in and selling my civic for an Integra that I can build up myself. It is between those two options as of now. Should I go the second route I think I may try and sell my Trans Am as well. Right now I am just sitting back and mulling over my options.
philyphreak2127 is offline   Reply With Quote
Old 10-19-2008, 11:57 PM   #152
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
Type R cams would work as well. The B16's camshafts are probably the most conservative of all the dual-cam VTEC engine cams, so anything else is an improvement.
As for the other question, I dunno mam, that's a tough one...
PSN Network ID: BrutalB83
Old 10-20-2008, 02:04 AM   #153
The name's Sam
I don't know. Not a whole lot of people have b-series civics around and there are a ton of civics around here all d-series for the most part so I think that is the route I wanna go. Even though it is a civic I want it to be somewhat unique. Which is kinda why I am proud to own a 4 door civic.
Old 10-20-2008, 02:06 AM   #154
The name's Sam
While I am doing the swap I was thinking a lightweight flywheel, and maybe a better clutch? any preferences on brands? I figured only like a stage one clutch if anything just so it is a little beefier but not overkill. But I am kinda intrigued by this whole b16 with gsr cams plan. I think that is the way I will probably go.
Old 10-20-2008, 02:17 PM   #155
Brutal Moderator
BrutalB83's Avatar
myspace
The clutch will depend on how much power you plan on making. If you intend on keeping things relatively stock or doing some minor building (the cams for instance) then a Stage 1 should suit you just fine. Anything beyond that will be a bit harsh for daily driving, but necessary if you're making a lot of power...
Old 10-20-2008, 03:16 PM   #156
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 189 awptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
Don't put a new clutch in until you cook the stock one. You'll thank me later for this tidbit of wisdom.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 10-20-2008, 10:22 PM   #157
The name's Sam
um...okay? any reason why?
Old 11-15-2008, 03:41 AM   #158
The name's Sam
I am still waiting for my reason why on that clutch....
anyways I found a b18 with mounts, accessories, manifolds, axles, wiring harness, and ecu for $400, it has relatively high miles at 173,000 miles but it is coming out of an automatic 4 door integra so it couldn't have been driven too too hard. But also I found a gsr manual tranny for $80. That is pretty much the whole swap for $480. But I would need an exhaust, and the manual ecu of course. I know 173,000 miles is a lot but with dropping a b-series motor in I now have a couple more options with more power than the d-series motors which is something I have been craving.
Anyways a couple questions for you B-series guys...Any preferences for a full exhaust that is relatively cheap?
Old 11-15-2008, 09:47 AM   #159
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 103 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
A GSR tranny for $80? Holy cow! Either that is the deal of the century or something is wrong with it. Do you know how many miles it has on it Sam and who owned it before?
I'm not a "B-series guy" yet...more like one in the making...haha...but I just went to the muffler shop and had them make me what I wanted. It was relatively cheap, though it seems that a properly tuned exhaust is definitely worth it from what I have seen. Then again, I really don't know. Best of luck!
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
http://hondaswap.com/members-lounge/...thread-278554/
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 11-15-2008, 07:25 PM   #160
The name's Sam
It needs to be reassembled, and he said he didn't know how many miles are on it...Which is why he is selling it so cheap. However I have the rare oppurtunity to look at the gears and such as it is disassembled.
Old 11-15-2008, 07:28 PM   #161
Honda Enthusiast
Luis998's Avatar
That would be a good experience to have for $80 bucks in my opinion. You can use it, if for nothing else, as a learning tool as well. Though I am thinking you will get a lot out of it and even be able to replace any parts that need to be replaced very easily and cost effectively. Now then, putting it back together is another thing. haha
Old 11-17-2008, 03:01 AM   #162
The name's Sam
Exactly well pretty soon I will be posting pictures of my car taken apart......again. We pushed it into my garage today drained all the fluids, pulled my manifolds, p/s pump and resovoir, coolant resovoir, strut bar, my passenger side fan. (plan on running a pusher fan). The guy I am buying the b18 from came over and helped a little. He saw my radiator and told me name my price because I have a half rad of course, and he has a 1993 integra that he is building a turbo setup for. so....just curious but could I just take out all my a/c crap, and run a full size teggy radiator? The best part is if I can do that he will throw in his full size radiator from the car the motor is coming out of and take money off of how much he is asking for the motor. So if it can be done it is worth it.
Old 12-10-2008, 12:15 AM   #163
The name's Sam
Well yet again plan change. I found a d15b7 with low miles on it. So my plan again is a mini-me setup. However this is most likely the last plan change. I get paid thursday, and I can pick up the motor that day. Which is the plan as of now. If I were to run a y8/b7 mini me setup could I run the p2p ecu with this or will I have to run the b7 ecu and have it tuned?
Old 12-10-2008, 07:34 PM   #164
Honda Enthusiast
Luis998's Avatar
Hey Sam, what year Y8 head are you using? I was going to do a thread on this but figured I may ask you first as the guy that sold me my 2000 Y8 head told me that it should only be used on a 2000 Y8 block, as it will leak on other blocks. Have you ever heard of anything like that? He said it is because of the way the head is made.
I say either use the P2P or switch to OBD1 and a P28 and tune it, of course.
Old 12-10-2008, 10:57 PM   #165
The name's Sam
Mine is a 98. I have never heard anything about that. I think you are supposed to use the oem hondata y8 head gasket. But I would ask Blanco.
Old 12-17-2008, 02:31 AM   #166
The name's Sam
If anyone even still reads this thread I had kind of a goofy question but how hard would it be to install gsr struts and springs on my 98 civic. I am pretty sure my front springs are bad, and the previous owner installed 2 adjustable struts and left 2 stock struts on, with the no-name coilovers, and the stock springs. wow. I want to at least get the car where it handles decent so matching the struts and getting good springs on the car are two goals of mine, and there is a set of gsr struts and springs for sale by me $100 or best offer. Could solve two problems.
Old 12-27-2008, 01:10 AM   #167
The name's Sam
Bought a d15b7 motor tonight. 85,634 documented miles. Came with all accessories, wiring harness, even the serpentine belt. It is completely ready to drop in. Too Bad I won't settle for that. I am gonna swap the y8 head on there, replace all the top end gaskets, and timing belt. Repaint my valve cover, and replace my front brakes, and a cv axle before I drive it.
Old 12-28-2008, 10:01 PM   #168
The name's Sam
Looks like its gonna be about two weeks before I start to "refresh" my y8 top end gasket wise. I have to buy a z6 timing belt. I want to also replace the oil pan gasket on the b7 just because it will be easier while the motor is out of the car. I can't wait to have it running. I am excited to have decent power for a change.
Old 12-29-2008, 02:08 AM   #169
The name's Sam
Got the motor started prepping the car and motor for the head swap. Got a solid 6 hours of work on the car tonight. Pulled the p/s/ pump, entire a/c system in the car, pulled the alternater, pulled the cam gear and timing belt off. (Need to buy hex key set for arp head studs to pull the head)
On the d15b7 I pulled alternater swapped it for the y7 alternator from the car, pulled the head, pulled the exhaust manifold, pulled the throttle body.
That may not seem like a lot but we did have some issues. It was me and a buddy of mine who doesn't know much about cars but was more than willing to learn with hands on experience. Basically right now I have to wait til I get paid again to buy the gasket set, chilton's manual and timing belt hopefully. After that I will assemble the motor to spec with all new gaskets, retime the motor put in the new spark plugs, and plug wires I bought. It will probably be around 2 weeks just due to my lame checks now. But I plan on buying the chilton's manual, timing belt, arp headstuds, gasket kit, and oil pan gasket. It will probably all cost around $250-$300.
Old 01-10-2009, 03:44 AM   #170
The name's Sam
I ordered a set of arp headstuds for the block, and I already have a full set of y8 bolts. I need 1 y8 headstud, and 9 b7 headstuds for this mini-me. I can pick them up monday. However big progress today. The motor is out of the car with tranny. I have to take the tranny off, and pull the head off the y8. I plan to connect the tranny and the block and dropping that back in the car hook everything up and make sure it's all solid. Which will give me time to port the head, and start mocking up the custom exhaust a buddy is going to weld for me. I also bought the head gasket, intake manifold gasket, timing belt, exhaust manifold gasket, valve cover gasket and throttle body gasket. I already have new spark plugs, spark plug wires, oil, and oil filter in my garage waiting. Basically the "left to buy" list consists of misc. fluids. Just so everything is topped off perfectly.
Me and my friend Lee plan on working on the motor for a while tomorrow. I am going to try and getting it back together enough to roll it onto the driveway and wash out engine bay and the overall car.
Old 01-12-2009, 01:10 AM   #171
The name's Sam
block and tranny back in car. Cv axles back in, wiring harness all wired to block. Waiting for head studs tomorow. I have about two or three hours of solid work left to have this car ready to drive. I cleaned the block a little bit, also bolted up the shift linkage, put the suspension all back together, put the wheels on. It's now sitting back on the ground. Looking good so far. Tomorrow I plan on trying to also wash and vacuum the car if I can get time. I still have to work all this week.
Old 01-12-2009, 01:28 AM   #172
Greenhorn
Ride:  93 Civic hatch lsvtec, 06 lexus gs300, ek civic
Rep Power: 0 jimmyvong is on a distinguished road
Your gonna want more displacement for an all motor build that will actully be worth the money. You will spend tons of money on your D build that won't mean much without displacement. All motor builds should start with the biggest displacement your budget can handle. Just my thought.
jimmyvong is offline   Reply With Quote
Old 01-13-2009, 12:22 AM   #173
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
It's nice, but not always necessary or even appropriate depending on what you're trying to achieve with the engine. Too long of a stroke could lead to peaky power delivery...
Old 01-13-2009, 11:55 AM   #174
The name's Sam
You are for the most part correct. An N/A motor should in most cases be a bigger displacement motor however in this case I am both a huge fan of the d-series motors and have been following some builds much like my own for a while now and many people said this build gives a nice power boost over the stock y7. Not to mention I am into the whole sleeper aspect of cars and in this case no one will have any clue that I have vtec unless they look for the solenoid. But eventually down the line when I can actually collect parts for it I would like to supercharge this motor because it should be running a relatively high compression ratio, and I want something different than the rest of the crowd.
Also I have another car and need to get this one running so I can finish what needs to be done on the Trans Am.
Old 01-14-2009, 04:26 AM   #175
The name's Sam
All I have left to do is clean up the bottom "mating" surface of the head and the top "mating" surface of the block to ensure a good seal, throw the new head gasket on and bolt the head on. The intake manifold is bolted to the head as is the throttle body to the manifold both with new gaskets in place. After cleaning the head and block the next step will be to change the timing belt, followed by plugging in the p2p ecu and running vtec wires to the neccessary spot, followed by the final part bolting on the head then the exhaust manifold and plugging everything where it belongs. I am itching to get off work tomorrow already!! I am pretty sure I will have a couple buddies over to help so everything should move rather quickly, hell maybe I will even have a video of the start up to post up. Who knows? Thanks for anyone who still reads this.
D16Y8 turbo build turbodhatch Engine Building 24 09-20-2009 03:25 PM
d16y8 DooMed070 HYBRID -> EG-EK / DC 6 11-09-2007 03:21 PM
D16y8 to D16y7 Downgrade Issues... NHBsi HYBRID -> EG-EK / DC 6 04-11-2007 10:03 PM
what boost to build for given a GT28R vector Forced Induction 6 12-11-2006 11:41 AM
FS: Everything d16y8 related drunkNun Parts: For Sale/Trade/Wanted 16 07-17-2006 05:40 PM
