D16z6
Old 04-06-2008, 08:36 PM   #1
Rep Power: 0 matt9112 is infamous around these partsmatt9112 is infamous around these parts
Default D16z6
thats the name of the z6 engine right? its alot harder to find than a y8 ive herd whats chances my local junkyard has one. id prefer it over the y8 if i can help it. dont bash too hard legit q lol .
matt9112 is offline   Reply With Quote
Old 04-06-2008, 09:16 PM   #2
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
Yes, you're correct. What kind of car is this going into?
PSN Network ID: BrutalB83
BrutalB83 is online now   Reply With Quote
Old 04-06-2008, 09:35 PM   #3
96 civic dx i just have some doughts about my stock d16y7 engine it lacks power in the higher rpms and hits high rpms higher than it should i think. for example i need to be in 5th to go past 60 and stay within a reasonable rpm granted it dosent have a tac god it sounds awfully high. so before i do any major work i want to get a solid good cond D to replace mine i have a y8 head and intake mani already along with gaskets and belt tho.
Old 04-06-2008, 09:39 PM   #4
Brutal Moderator
BrutalB83's Avatar
myspace
A complete Y8 would be an easier swap as far as wiring purposes go. All Z6s are set up for OBD1...
Old 04-06-2008, 09:47 PM   #5
dont i need the p28 anyway to run vtec? rember i have y7 in car now and y8 shit on bench lol but like i said i just want a solid running engine before i start buying parts turboing ect ect
Old 04-06-2008, 10:15 PM   #6
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
I like the d16z6, personally. I'm all about B-series, but if I had to build a D, that would be the platform. Even if its going into an obd2 car, you can still convert it to obd1 and it wont cost an arm and a leg.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 04-06-2008, 11:17 PM   #7
Brutal Moderator
BrutalB83's Avatar
myspace
No, you need the ECU that goes with the motor. The P28 is specific to to the D16Z6, and it can be chipped and reprogrammed to run other engines. Your car is OBD2, and if you're going to keep it that way and use the Y8 head, then you're going to want an OBD2 ECU, of which the P28 is NOT. Did you not know this?
I guess I figured that you knew more than you do about ECUs since you were criticizing me for harping on that newb in the other thread...
Old 04-07-2008, 07:24 PM   #8
no no no just know that the p28 with a harness and chipping works fine and is tryed and true plus is cheap =)
Old 04-07-2008, 08:29 PM   #9
FObangah's Avatar
Ride:  2009 tC, 1991 EF hatch
Rep Power: 18 FObangah is a jewel in the roughFObangah is a jewel in the roughFObangah is a jewel in the roughFObangah is a jewel in the rough
myspace
Originally Posted by Blanco View Post
You get the ECU that comes with the Y8. Oddly enough, Honda was smart enough to make it capable of running the engine correctly. Wacky, eh?
Listen to the man, plus the y8 head is way better than the z6. Quench zones anyone???
Oh and since when was a d16z6 "hard to find" ????
2009 Scion tC; Classic Silver Metalic, factory lip spolier
1991 Civic Hatch DX; Coilovers,16" Focal's, Factory yellow fogs,2.4" custom exhaust, ebay intake
FObangah is offline   Reply With Quote
Old 04-07-2008, 08:45 PM   #10
around me i cant find anyone and i was gonna go obd1 you guys confuse meeh. lol tell me everything ive researched is a crock of shit lol.
Old 04-07-2008, 09:02 PM   #11
FObangah's Avatar
myspace
Your research wasn't bad it just went in the wrong direction. It's always better to match (X)gen motor with (X)gen car.
Old 04-07-2008, 10:35 PM   #12
95 del sol D16
Ride:  1995 honda civic del sol stock i/e
Rep Power: 8 frodotoolbox is on a distinguished road
Send a message via AIM to frodotoolbox myspace
if i were you i would just pull a d16z6 from a del sol (if you can find one) cuz most del sol were just bought be old people that wanted a weekend car with good gas mileage or drivin by women so they werent beaten on and get obd1 (unless your not electrically inclined)
rep is always appreciated.
95 del sol-died 10-24-08 (but will come back to life frankenstein style)
soon to be 1973 opel gt- waiting on the clutch a$$ holes havent sent it out yet.
XBL Gamertag: jamietoolbox (all one word)
frodotoolbox is offline   Reply With Quote
Old 04-07-2008, 10:46 PM   #13
Brutal Moderator
BrutalB83's Avatar
myspace
Well if you want to convert to OBD1 then yes, a P28 would be a great choice. If you want to keep it OBD2 (and you might, depending on where you live) then you'll want a P2P...
Old 04-08-2008, 05:14 PM   #14
i want obd1 theres no inspections in Florida they don't check anything not to mention emissions . and yeah i have plans hopefully down the road for my 250whp and the tunning chipping ect i was going to have professionally done as i dont know jack shit about it. xencron tunning any decent saw there banner on the site and hcekced it out a little. but yeah as of now goal is just to get new engine or head anyway on with all needed parts and running perfect with the new ecu and vtec. =) thanks for input guys.
EG: D16Z6 Garage Sale!!! D See 2 Parts: For Sale/Trade/Wanted 24 04-28-2008 10:41 PM
F/S A Bigs list of d16z6 And 92-95 Civic parts Boosted4dr Parts: For Sale/Trade/Wanted 31 04-10-2005 11:03 PM
FS in WI: d16z6 head w/stg 2 P&P-plus more esi42 Parts: For Sale/Trade/Wanted 3 03-28-2005 04:42 PM
D16z6 Parts And Sensor. Sinner Parts: For Sale/Trade/Wanted 1 07-03-2003 01:16 AM
Wanted : D16Z6 Complete Head Havok Parts: For Sale/Trade/Wanted 8 10-21-2002 11:33 PM
