Ride: 93 Civic Si Hatch
Hey everyone,
I've been searching around but can't seem to find the answer that fixes my problem. I just rebuilt and replaced my cylinder head on my 93 Civic Si. I put in brand new valves and guides, all new seals and gaskets. The head was pressure tested, resurfaced, valve grind to reseat, and had the machine shop put the guides and everything on the head back together. Only thing I had to do was put the cam in and rocker arm assembly. I've got the head back on now, but I can't get the car to start. There's spark, fuel and compression. I lined the mark on the balancer in TDC, and the mark on the cam with the mark on the timing cover back plate, and "up" facing up and slightly forward. The rotor in the dizzy is also facing the #1 cylinder, so I'm not 180 out, I don't think. The engine comes close, but won't quite start, even when I move the timing belt over a tooth or two. Any help or suggestions are appreciated. Thanks, Phil |
#2 | |
Ride: gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Go through and check all of your grounds. The most important ones are the one down by the starter, the one that bolts to the thermostat housing, and the one going from the valve cover to the rad. support. The last time I had my car totally apart I forgot to tighten down one of the grounds, causing it to crank and crank but not fire.
93' dx hatch jdm b18c - jrsc 8psi s300 440cc RC's |
#4 | ||
Thanks, Phil Quote:
Thanks, Phil |
#5 |
Got it! Guy over on honda-tech mentioned that I hadn't adjusted the valves. They were way too tight since I put the new valves in.
Thanks a lot guys, Phil |
#6 | |
SOHC on this!!
Weird. When I rebuilt my Z6 head my valves were too tight and it ran but really bad.
#7 | |
![]() Last edited by Phil_Civic; 11-06-2009 at 06:23 PM. |
#8 | |
SOHC on this!!
Haha you think? You're the guy who bought the red EG right? If so how's it comeing along?
#9 | |
. I bought another D16z6 to rebuild. I've only done the head so far, 'cause the parts I want from fj distributors are still back ordered and I fried my head gasket on my DD being an idiot...lol...I'm considering getting the tuner turbo kit from go-autoworks and trying to get 150whp on my stock block and then I'd like to have 200 whp on my DD once I build the bottom end. |
#10 | ||
SOHC on this!!
Don't know if you've seen this.... FOR-TRADE: 92-2000 Honda civic Turbo ready! Saanich, Victoria __________________
#11 | |
Oh yeah. That's actually kind of tempting. I'd rather build my own block though to be honest. |
| D16z6 Timing Issue? | Phil_Civic | General Tech and Maintenance | 0 | 11-04-2009 08:19 PM |
| Strange timing issue | therobesons | Civic and CRX - EF | 3 | 09-10-2007 10:45 PM |
| timing belt issue | crippleddave | Civic and del Sol - EG and EK | 11 | 01-27-2007 02:08 AM |
| Timing issue. | 90_civic_Si | Civic and CRX - EF | 2 | 10-11-2006 06:39 PM |
| I Think i have a Timing Issue | poops87 | Engine Building | 6 | 02-28-2006 03:56 AM |
