Engine light comes on after a couple days??
Old 09-16-2008, 11:38 AM   #1
Rep Power: 0 jamielangdo is on a distinguished road
Default Engine light comes on after a couple days??
i swaped my d16y7 for a d15b vtec. the car runs good except my engine light came on after a couple days of daily driving, why? so i heard it may be my IAC vavle, so i cleaned it, my car runs great, but engine light came on again after a couple days????
any ideas?
the first time it came on, my car would iddle up and down very quick at arround 1200rmp.
but now its not, the engine light is just on
jamielangdo is offline   Reply With Quote
Old 09-16-2008, 11:44 AM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 164 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
well first you need to figure out what code your throwing
Old 09-16-2008, 11:56 AM   #3
its throwing a caode for IACV
Old 09-16-2008, 11:56 AM   #4
HS TECH
AHHVTEC's Avatar
then fix that and it should go away
Old 09-16-2008, 12:00 PM   #5
i did..even replaced the part. still comes on after a couple of days
Old 09-16-2008, 12:02 PM   #6
HS TECH
AHHVTEC's Avatar
did you reset your ecu after you put the new part on
Old 09-16-2008, 12:04 PM   #7
yes. then it came on again after a few days.
Old 09-16-2008, 12:05 PM   #8
HS TECH
AHHVTEC's Avatar
what ecu are you using
Old 09-16-2008, 12:07 PM   #9
P2p ecu
Old 09-16-2008, 12:09 PM   #10
HS TECH
AHHVTEC's Avatar
idk, if you put a new part on there and reset the ecu, it should have went away maybe check the wires between the iacv and the ecu to make sure there good and connected with no grime build up
Old 09-16-2008, 12:12 PM   #11
yeah. the wires for the iacv are new. i had to wire them seperate. that shouldnt be a problem there. some people have told me that placing a breather filter on my vlave cover and pluging the cold air breather tube should help because the deposits from the valve cover can cause the iacv to get dirty. is that true?
Old 09-16-2008, 12:14 PM   #12
HS TECH
AHHVTEC's Avatar
i mean it can make them dirty but thats what the screen is for i myself dont like to plug it with a filter i like running it like it came from the factory.and with you running the wires yourself just double check to make sure there getting a good connection at the ecu, it happens
Old 09-16-2008, 12:17 PM   #13
ok i'll check that out tonight. any other ideas of what it may possibly be?? i just find it weird that it takes a few days or so for the engine light to come on.
Old 09-16-2008, 12:18 PM   #14
HS TECH
AHHVTEC's Avatar
yeah thats all i can think of maybe check the code again to make sure its the right one
Old 09-16-2008, 12:22 PM   #15
alright.thanks for your help!
Old 09-17-2008, 01:52 AM   #16
Von Europa
awptickes's Avatar
Ride:  1999 Civic EJ9, 2003 Civic EX Coupé
Rep Power: 59 awptickes has a brilliant future
Hook up an OBD2 reader, this will ensure you're pulling the correct code.
Do you have and idle problems?
awptickes is offline   Reply With Quote
Old 09-20-2008, 11:58 AM   #17
well sort of..its when i press the gas at arround 1700rpm my car give a little shake. it jumps the rmp up about 200rmp. just like a little kick? not sure why it does that
Old 09-22-2008, 03:10 AM   #18
Von Europa
awptickes's Avatar
Have you checked the secondary o2 sensor?
Are you using the correct ECU? No. The p2p is for the d16y8.
You need the proper ECU for the d15Bx. Get that ecu, and you'll not have a CEL.
Old 10-02-2008, 10:59 PM   #19
Rep Power: 0 frankmaster is infamous around these partsfrankmaster is infamous around these partsfrankmaster is infamous around these partsfrankmaster is infamous around these parts
if you have not hacked your harness go to a garage where you can find a snap-on motis and ask them to put the scope to your car.you will pay a diagnostic fee but the motis will find the problem. if your ballin buy a motis.if your broke or just too proud,keep typing
frankmaster is offline   Reply With Quote
Forum Jump
engine light stedscivic HYBRID -> EG-EK / DC 17 10-26-2004 07:24 PM
Engine light or dummie light 4DRonDUBS ECU's, Electronics, and Tuning 2 09-29-2004 07:50 PM
Engine Light randerson165 ECU's, Electronics, and Tuning 3 11-05-2003 10:52 AM
Engine Light randerson165 ECU's, Electronics, and Tuning 1 06-21-2003 02:18 PM
Engine Light obdtwointegra General Tech and Maintenance 2 05-14-2003 07:03 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
