Hey there,
I got a 95ex. The ac doesn't work I have attemped to add refrigerant and that wouldn't get the compressor going. I pulled the connector off the pressure switch found on the driverside just beside the condensor and headlight. I energized that with 12v and the compressor rolled with the ac switch on in the car. I turned the switch off and the compressor quit. I would assume the switch in the car is good. I also swapped out the two relays just on top of the pressure switch and nothing changed. I checked the voltage on the pressure switch and said like 234v? Do I need a new pressure switch or what? I have the manual for the car however the ac section is not included from honda? Could someone with a little more knowledge assist me. I appreciate all the help you can lend me in advance...take care.. |
| engine start problem | LJK | ECU's, Electronics, and Tuning | 3 | 01-02-2007 04:47 PM |
| engine start problem | LJK | Civic and del Sol - EG and EK | 0 | 12-17-2006 05:57 PM |
| Electronical problem with honda accord 95 | jay_nightrider | General Tech and Maintenance | 2 | 12-04-2006 12:39 PM |
| Old Problem, Revisted | YBLEGAL | HYBRID -> EG-EK / DC | 4 | 11-25-2006 08:45 PM |
| Electrical Problem With My 1986 CRX Si | The_MATRIX | General Tech and Maintenance | 0 | 06-17-2004 06:08 PM |
