Wolf dawg
Ride: DSM awd spyder/civic hb
My friend just just picked up a d15z1. Vtec-E What did it come out of and is the head the same as a d16z6? He is keeping the head and giving me the block. I am looking to build me a turbo motor with all stock parts I was just wondering what would be the best block rods pistons and head to use d16z6,16a or y8? I am using a dsm TDO5 14b and 450cc injectors out of dsm. Also Is there any thing I can use out of the d15z1 like the pistons look like they would be good to lower my compreshon for boost. They have the number p07. Also what stroke dose the z1 have? The same as a z6 or is just like a nomal 1.5? Some one told me to use LS rod. What year car and also what would need to be done to make them fit or should I just use stock rods out of a d16 or y8 or some thing. Any info would help. Thanks for looking Wolfy
![]() Last edited by wolfdawg2; 01-21-2008 at 06:01 AM. |
Administrator
Ride: m3, dakota
z1 is out of the vx.
its VTEC-E. the head is not the same as a z6. ls rods won't work in a d-series. your best bet is to just pick up an entire z6 or y8 longblock |
Wolf dawg
What is the diff on the head to a z6 or y8. Also some one told me Ls rods or b16 rods are the same length but they need some machine shop work to fit. I don't know any thing on that just asking. Also what would be my best bet to put in the z6 or the y8? What is the diff on them like rod piston head every thing? I what the best d that I can get to turbo it. And what would need to be changed on the dizzy for the wires will it work if I just re pin the plug to my wiring 92 vtec wiring? And the pistons out of the VX are they any good? They look good to use to lower my compression for boost. That would help out a lot
Also parts for sale Parts for sale or trade. Last edited by wolfdawg2; 12-06-2007 at 05:54 AM. |
Ride: boosted sir eg, suzuki gsx750f
well the y8 is obd2 where the z6 is obd1. and i think the y8 has a larger combustion chamber and maybe slightly larger valves then the z6 but all that for like 2 more horses
#5 |
Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec! Vtec!
#7 |
you could put a vtec head on the block you have now to make a mini me but you would be better off finding a d16y8 and building that. i bought a full y8 swap for $400 with everything in good condition so they are not that expensive.
#8 |
Wolf dawg
Do you know any one that knows any info on how to put in LS rods in to a d16/y8? Also are the vx pistons any good for lowing my compression for boost? I alredy had a d16 with a turbo runing 14psi on stock block with 20000mile on it. The only shitty part was my thermostat took a shit on me and the motor over heated and I spun a baring. PPL say you only should run 5-10psi I just what to make my stock bottom end a little stronger with stock parts. Thanks Wolfy
#9 | |||
The Kicker of Elves.
I hate it when people just talk about psi like every turbo is the same. You can run 52o3898234092384u32094834psi on a stock engine as long as the turbo is small enough and you can you can blow a built engine with 1psi on a ridiculously large turbo. It's all relative. Power is the determining factor and past that it's how you built and tuned the engine.
Check D-Series.org for the rod info. At the end of the day, it's both cheaper and easier to buy a set of TunerToys rods than modify B18 rods.
Don't misinterpret what I say. Quote:
#10 |
Wolf dawg
Thanks for the help. Don't right on my thread if you don't have the info that I am looking for.
#11 | |||
Hahaha. You completely missed my point. You also missed the fact that I did help you by pointing you in the right direction. Sorry if I didn't feel the need to spoon feed you like a baby.
![]() I'll make sure that I "left" your topic now.
#12 |
Crusher of Noob Ambitions
Ride: 97 Integra LS Coupe
NICE!
![]() Now how much do you want to bet he won't get it?
If you find something I say helpful, please rep it up! Also, DO NOT PM me with tech questions! Use the forums so we can all benefit from the answers. I will NOT respond to tech-related PMs... 97 Integra LS Coupe: *AEM Intake/Megan Header/Magnaflow Exhaust *Tokico Shocks & Springs *Megan Strut Braces & H-Brace *98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys) |
#13 |
Wolf dawg
Bet what???????? All I am asking is for LS rod in a d16/y8 info nothing more no tuning or any thing like that. For your info. I don't see you giving the info that I need.
| D16Z6 Future Build | 93 Del Sol | Civic and del Sol - EG and EK | 36 | 01-13-2008 08:03 PM |
| Cost to build B18c1 to 200whp+ and allow for future boosting? | 1320B4U | Engine Building | 4 | 09-22-2007 04:49 PM |
| What engine to build? Undecided.. | ChrisC | Engine Building | 18 | 09-15-2007 11:54 AM |
| future build | mmmcarl | HYBRID -> EG-EK / DC | 6 | 04-27-2007 01:21 AM |
| what boost to build for given a GT28R | vector | Forced Induction | 6 | 12-11-2006 11:41 AM |
