H22 civic questions
Old 04-30-2008, 08:40 AM   #1
Rep Power: 0 123stojic is on a distinguished road
Default H22 civic questions
Hey guys, I am in the prossess of putting an h22a from a 1992 prelude si into my 92 civic lx. I just have some questions about the ecus and injectors. I want to mess with the least amout of wiring as possible, so could anyone tell me the stuff that is not going to be used with the p28 ecu? From what I'm hearing this is what ive got so far: egr, aib's, knock sensor, resistor box. That stuff is not needed. So if I didnt want to mess with the resistor box, I could get some injectors off of an obd2 h22 wich are saturated, and I wont need the resistor box? Ok, I ve heard soooooooo many different opinions about ecus with the h22a, I want to know which one you would recomend. I was leaning toward the p28, but I dont know if I can just put it in my car and drive it right to the dyno to get it tuned, or if it will run like crap. Thanks for your help, David
123stojic is offline   Reply With Quote
Old 05-01-2008, 08:07 AM   #2
Hamby
hondacivicdx92's Avatar
Ride:  Turbo 92 Civic DX hatchback
Rep Power: 8 hondacivicdx92 has a spectacular aura abouthondacivicdx92 has a spectacular aura about
myspace
as far as the ecu goes, check out hondata.com. there you can find what ecu's work with what motors.
hondacivicdx92 is offline   Reply With Quote
Old 05-01-2008, 09:58 AM   #3
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
The only ECU you should be using on any given motor is either the stock one that came with the engine, or one that's been chipped and programmed to emulate the stock ECU's parameters (or a custom setup for built/modded engines).
There are some exceptions, but generally that's a good rule to follow...
PSN Network ID: BrutalB83
Code 43 on B20 swap George777 HYBRID -> ED-EF / DA 4 04-16-2008 01:53 PM
ecu code 2 long 3 short ?pr3 cvccricebaby@yahoo.com ECU's, Electronics, and Tuning 26 07-19-2007 02:47 AM
H22 into civic EG swap H-Ridah HYBRID -> EG-EK / DC 2 12-09-2006 06:29 PM
H22 Swap Questions DjMcPhatty HYBRID -> EG-EK / DC 8 05-30-2003 08:17 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
