Facebook Twitter
HELP PLEASE! My del sol won't run
This is a discussion on HELP PLEASE! My del sol won't run in the Civic and del Sol - EG and EK forum
Ok so I have a 93 del sol that I bought last summer with a b16a sir 2 gen swapped into it already, and I only drove it 100 miles and then I parked it and a week later it would not start . So ...
Old 06-10-2007, 02:44 PM   #1
Default HELP PLEASE! My del sol won't run
Ok so I have a 93 del sol that I bought last summer with a b16a sir 2 gen swapped into it already, and I only drove it 100 miles and then I parked it and a week later it would not start . So I pulled the ecu and opened it up and the q31 transistor was burned up, so I figured maybe the ecu was just bad so I but a new one in and the same transistor burned up. But I don't think that is the problem. My car wants to start but it will die immediately after it starts, I have spark and it seems to be getting fuel at first when it starts but then it dies like it has no fuel. also when I pull the spark plugs they do not have any gas on them.... I am wondering if maybe it is the fuel pump or the rely???? Does anyone know what the q31 transistor does, do I have a short somewhere? The check engine light was also coming on when the car ran, I checked the codes out but I don't remember what they were I think it might of been 2, and 11. Thanks I would appreciate any advice or suggestions you could offer me.
Masonj123 is offline   Reply With Quote
Old 06-12-2007, 06:36 PM   #2
If any one has any suggestions on what I should check on my car itwould be greatly appriciated. I am thinking about changing the fuel pump rely and seeing if that does anything. Thanks
Old 06-18-2007, 11:01 PM   #3
I talked to a guy that builds motors and he said that my timing belt could of jumped teeth, since it is pretty loose because I think the belt tensioner is bad. What should I do to check this?
Old 11-11-2008, 04:50 PM   #4
Honda-Tech.com: Engine Management and Tuning: What is this IC on the p72 ecu?? same thing about q31... u have Sensors pluged in wrong
whitericethinktwice is offline   Reply With Quote
© 2001-2013 HondaSwap.com
