Honda Civic 1992-1995 EG Electric Cooling Fans
Old 06-25-2009, 09:20 PM   #1
master23 has a spectacular aura aboutmaster23 has a spectacular aura about
Default Honda Civic 1992-1995 EG Electric Cooling Fans
Click on the link to see the complete article with images check it out here: Electric Cooling Fans - 1992-1995 Honda Civic EG. Garage411.com
For wiring circuit information, see wiring diagrams located on bottom of this page. Some wires have been assigned a superscript to distinguish them from other wires of the same color. For example, the Yellow/Green wire is not the same as the Yellow/Green wire.
COOLANT TEMPERATURE SWITCH
1. Remove coolant temperature switch (located on rear of engine block). Suspend temperature switch and thermometer in a container with a 50/50 mixture of coolant and water. DO NOT allow thermometer or temperature switch to touch bottom of container. Heat coolant mixture.
2. Check continuity between temperature switch terminals. With coolant temperature 181-191°F (83-91°C), continuity should not exist. With coolant temperature 191-203°F (91-95°C), continuity should be present.
FAN MOTOR
Unplug 2-pin connector from fan motor. Connect battery power to either fan motor terminal. Connect ground to other fan motor terminal. Replace motor if it fails to run.
RELAYS
1. Remove radiator and condenser fan relays. Radiator fan relay is located on right front inner fender and condenser fan relay is located on left front inner fender (if equipped).
2. Connect positive battery power to relay terminal "C" and connect terminal "D" to ground. For terminal identification, see wiring diagrams . Continuity should be present between relay terminals "A" and "B". No continuity should be present when battery power is disconnected.
master23 is offline   Reply With Quote
Tags
eg cooling fans, eg electronic fans, garage411.com
Perma-Cool electric fans two 10" fans eg ek eg6 ek9 JDM RSS-Bot Auctions 0 01-28-2009 01:17 PM
Honda civic 1992-1995 electric mirror RSS-Bot Auctions 0 01-04-2009 01:36 PM
Are more expensive cooling fans worth the money??? BigBoy General Tech and Maintenance 8 02-16-2006 07:50 PM
Cooling Fans. mikeislord HYBRID -> BA-BB /CA-CD 9 12-13-2005 07:15 PM
cooling fans 2000cfm 11"x2.75" thick Jermbos Parts: For Sale/Trade/Wanted 7 11-27-2005 05:01 PM
