i just swapped a b20vtec with a b16 head...when cold the idle is at 1500 rpm..and when is in operating temp it seems to die out so when iam at a stop light cars doesnt idle it jus dies out..what seem to be the problem???
Green on the scene.
Ride: Fuckin Prelude Si 2.1l 1990
so at a stop, itll idle for a second or two but then cut off?
does the time it idles at stops vary? if you drive it for a while, on the freeway or something, then come to a stop, does it idle better? |
#6 |
Green on the scene.
try adjusting your idle screw.
unplug the fitv i think, then adjust the screw. |
#10 |
Green on the scene.
thats also for fuel injected.
i have a picture for carburated too.. |
#19 |
Christmas Car
Ride: 93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Are you throwing any codes when the car stalls/dies? It sounds like a bad iacv. Change it and go from there.
Please direct your questions in the following format. 1) Did I search it on Google? 2) Did I use the search function in the TOP RIGHT AREA of this page? 3) Refer to Step 1 and 2. If that doesn't work, then feel free to post. |
| b16a idle problem not iacv or fast idle | toqeer1986 | HYBRID -> EG-EK / DC | 9 | 12-12-2007 03:06 PM |
| Idle Problem..... | erik07 | General Tech and Maintenance | 0 | 12-01-2007 03:32 PM |
| low idle problem | invokingpain | General Tech and Maintenance | 4 | 12-15-2006 05:27 PM |
| Having a problem with my idle | Blanco | General Tech and Maintenance | 12 | 08-28-2003 07:09 PM |
| Idle Problem With B16 In 93 Cx | RandomTask76 | General Tech and Maintenance | 0 | 05-12-2003 07:21 PM |
