| | #1 |
| Junior Member | Okay ive got an idle probleme on my b16 The idle goes up and down up and down up and down..!!! Even when i drive steady i starts to burp .! when i give a lil kick of gass it commes back to normal lolll I tried to check for somme vacuum leaks.. I took off and clean the IAC solenoid and even put a nother one from my other car... and stilll.. could this be the oxygen sensor? tps sensor? or whatever shit sensor ..!! Its pissing me off and no one can help me whit this..! |
| | #6 | |
| No idea what I'm saying Join Date: Feb 2006 Location: Long Island, NY
iTrader: 0 / 0% Ride: 1985 CRX B16 with a bit of boost,, 92 EG B16
Rep Power: 10 ![]() | Quote:
Let me know what you find. E | |
| | #9 |
| Junior Member | OKAY :P ive took the tps sensor off of my other car and the idle is still going up and down up and down.... I have two error code ... 22 and 7 22 VTEC Pressure Switch (i knu that) 7 Tp Sensor for the tps ive just change it.. why is is still doing the same thing? OHH by the wayyy i cant get my dam vtec to go on..!!! When i reach a high rpm the check engine light goes on and error 22 pops up VTEC Pressure Switch ... do i have to change the pressure swicth |
| | #10 |
| Junior Member | Okayy for a reason i ignore... its running idle okay SOMETIME and some othertime the idle goes up and down up and downnn anddd i runsss funny when i drive stady on the road... u can feel the motor sounds changes until i give a jeark of gass it commes back to normal..!! |
| | #13 |
| Senior Member Join Date: Sep 2006 Location: washington Age: 23
iTrader: 0 / 0% Ride: 91 integra with ls/vtec...
Rep Power: 11 ![]() | maybe u still got a bad tps.. check all ur vaccum lines... the pvc vavle too that could be plugged or cam loose... check the fast idle valve its the one right under the throttle body... try swapping that out... what kind of car is it?? |
| | #14 |
| Junior Member | hey, i been having that problem too, i didn't drive my car for like about 3 months cuzz it was setting in the garage cuzz we was working on the body, getting ready to repaint, once it was done,, we drove it again and the tps sensor went out,,so we got like 3 and only a few was able to work okay and not having the check engine light come on,,now i still have a problem, the vtec is not kicking in as before at 4.5 rpm,,its laggin around 5.5 rpm,,and also sometimes it revs really high when u been driving for a while, i used to have that jerking problem like u did,,but some how that doesn't do it anymore,,now i just need to make it kick or find wats wrong wit it, and make the vtec kick again at 4.5 and not lag, but i'm lookin forward to getting a new throttle body with a new tps sensor on it,,then maybe it should run right again,,any ? let me no |
Similar Threads | ||||
| Honda Gsr Vtec Head B16 B18 B20 Ls Vtec Integra Civic | RSS-Bot | Auctions | 0 | 12-18-2007 08:23 PM |
| B16 VTEC Head 100% Complete Cleanest on ebay LSVTEC B16 | RSS-Bot | Auctions | 0 | 12-07-2007 07:13 PM |
| Future Build help me out. | wolfdawg2 | Civic and del Sol - EG and EK | 10 | 12-07-2007 04:27 AM |
| Turbo B16 Vtec | ChaseRsX | Engine Building | 3 | 04-10-2003 04:08 AM |
| LS-VTEC/CR- VTEC Info | pissedoffsol | General Tech Articles | 1 | 11-10-2002 03:19 AM |
