idle surges when headlights on???
Old 09-29-2008, 06:30 PM   #1
Rep Power: 0 vtec_me has a spectacular aura aboutvtec_me has a spectacular aura about
Default idle surges when headlights on???
I just picked up a eg hatch, and found out that when ever i turn on the headlight my idle surges, but when its off it does not do it. does anyone know whats up? could it be poor ground or battery?
vtec_me is offline   Reply With Quote
Old 09-29-2008, 08:16 PM   #2
The Hondaswap Canadian
Justin66's Avatar
Ride:  1990 Intergra GS/XSi
Rep Power: 27 Justin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to beholdJustin66 is a splendid one to behold
Maybe give that a check. Your Idle Air Control Valve (IACV) might not be working right. Does this happen when you turn on anything else (defogger, A/C) ?
90 Integra GS/ XSi
- JDM B16A SiR2 w/ full exhaust & short ram
- J1 Tranny
- Skunk2 stage 1 cams & gears (not installed yet)
- H & R lowering springs
- Rear strut bar and front camber kit
- HKS Hi-Power exhaust
- Powersteering removed
- JDM 1-piece headlights & sidemarkers
- Optima RedT relocated to rear
XBOX LIVE: JustinE66
Justin66 is offline   Reply With Quote
Old 10-02-2008, 03:23 PM   #3
EGDriver93's Avatar
Rep Power: 0 EGDriver93 is on a distinguished road
A grounding kit took care of my surges. Also try cleaning out your throttle body. Helps a bit. Prob your IACV though.
EGDriver93 is offline   Reply With Quote
Old 10-02-2008, 03:27 PM   #4
Resident Fat Ass
George777's Avatar
Ride:  90 Hatch, 91 Rex, 85 Yamaha Virago, 82 CB900F Supersport
Rep Power: 58 George777 has a brilliant future
One of your wires could be exposed too, so when you turn the lights on it reacts with something else or grounds out. It wouldn't hurt to trace the wires and make sure there aren't any exposed parts.
Originally Posted by Blanco View Post
Eat shit and fucking die you ignorant redneck.
Originally Posted by B16RacerN2NR View Post
I don't know how to do plastic surgery but I love titties, you don't see me trying to go around giving breast implants do you?
Originally Posted by phyregod View Post
Yup, Its sex on wheels. Violent, vigorous sex. With a super model. Scratch that, super model twins.
George777 is offline   Reply With Quote
Old 10-03-2008, 01:34 AM   #5
Rep Power: 0 JdMsoles is on a distinguished road
i would just check the battery if its below 12.4 volts then your going to have problems where things start acting up like that just check that first before doing anything else and make sure ground to battery is clean of rust or anything i don't think its the iacv, should be around 4.5v no more .5volts GL!
JdMsoles is offline   Reply With Quote
Old 10-03-2008, 12:41 PM   #6
Rep Power: 0 fijitec is infamous around these partsfijitec is infamous around these partsfijitec is infamous around these parts
is this problem solved..?
fijitec is offline   Reply With Quote
Old 10-25-2008, 09:04 AM   #7
no not solved yet still doing this i havent checked my iac valve yet, but when its cold it surges pretty bad too drops almost to 400-300 and goes back to 1100 last time i check battery was at 11.8 ill clean off my grounds and see waht happens
Old 10-25-2008, 09:18 AM   #8
eg'sforlife's Avatar
Ride:  92 Civic LX
Rep Power: 1 eg'sforlife is on a distinguished road
it still sounds like a grounding problem like your lights are grounding off something i had this problem once and my grounding wire for my light was corroded but its looked fine just looking
eg'sforlife is offline   Reply With Quote
Old 10-25-2008, 12:08 PM   #9
Hondaholic
prpprimo's Avatar
Ride:  91 hatch z6/ 98 coupe z7
Rep Power: 2 prpprimo is on a distinguished road
Send a message via AIM to prpprimo
Check the output voltage from your alternator. It should be around 13.5 to 14.3 volts. (you should be able to do this with a basic multi meter or bring it to a local auto parts store that offers free diagnosis)The symptom your describing sounds like a charging issue. Most all components are designed to run off a full 12 volts. If it falls below that, it can affect the engine idle circuit.
It is similar to jump starting another car that has a dead/weak battery. Once the cables are connected, you will notice the engine in the car delivering the charge decrease RPM's to compensate the load.
prpprimo is offline   Reply With Quote
Old 10-25-2008, 01:58 PM   #10
!!YTINASNI
phyregod's Avatar
Ride:  97 teggy, 98 jeep GC 4x4, 07 CBR 1000rr
Rep Power: 162 phyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
^^ That would be my first guess. Weak alternator. Next would be the ground thing.
aleaf.CRX: I don't think I've ever had the steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane one day and attack someone
Forum Jump
Car surges under partial throttle Dasfinc Civic and del Sol - EG and EK 8 01-22-2008 10:29 PM
hatchback surges and makes sputtering sound cfwthb_94 General Tech and Maintenance 2 12-09-2004 10:43 PM
B16 surges @ 2000 rpm when decelerating? fardoche General Tech and Maintenance 0 04-13-2004 11:06 PM
Power Surges? B16 ECU's, Electronics, and Tuning 2 01-29-2003 09:13 PM
surges while accelerating hybridtech HYBRID -> EG-EK / DC 13 01-09-2003 11:55 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
