leaking civic??
Old 07-01-2008, 11:47 AM   #1
Ride:  06 BOM DC5
Rep Power: 7 squeals will become famous soon enoughsqueals will become famous soon enough
Default leaking civic??
so i noticed some moisture in my carpet one day on the floor board of my civic hatchback on the passenger side. i pulled up the carpet and there's a crack in that tar type stuff that is allowing moisture to come up through the floor boards. is this a serious problem? what could i use to cover the cracks?
squeals is offline   Reply With Quote
Old 07-01-2008, 12:36 PM   #2
Blinker Fluid Specialist
Ride:  95 delsol SI
Rep Power: 8 delsol88 is on a distinguished road
myspace
caulk would be your best bet prolly, or just some rubber cement
delsol88 is offline   Reply With Quote
Old 07-01-2008, 12:37 PM   #3
stevennn09's Avatar
Ride:  94 civic Ex
Rep Power: 8 stevennn09 will become famous soon enoughstevennn09 will become famous soon enough
Send a message via AIM to stevennn09 myspace
the tar type stuff is not ment to keep moisture out. it's sound deadening material. jack up the car and look in that area where u see the leak, look for a crack or soemthing that would let water in. than spray some undercoating on it for quick fix. or waterproof caulk it.
stevennn09 is offline   Reply With Quote
Old 07-01-2008, 12:43 PM   #4
Ride:  06 BOM DC5
thanks a lot!! i'll def put in on a lift later and check it out
Old 07-01-2008, 08:20 PM   #5
Rep Power: 4 thetunersource is on a distinguished road
yea check for rust holes
2002 Honda Civic Si Greddy Turbo'd
1989 BMW 328ci SR20DET Powered
1972 Honda CB350 Supersport
1971 Mercedes Benz 300sel 6.3 Monster
1989 Dodge Colt/Mitsubishi Mirage Turbo 4g63 Turbo'd -- goodbye, you will be missed
www.thetunersource.com
thetunersource is offline   Reply With Quote
92 Civic leaking clutch fluid inside cabin CRXratedR Civic and del Sol - EG and EK 5 04-07-2008 06:01 AM
leaking oil civiclxb16 General Tech and Maintenance 10 08-04-2005 12:40 PM
a/c leaking j954drgsr General Tech and Maintenance 1 07-24-2005 03:41 PM
leaking oil turbohatche Forced Induction 6 09-08-2004 02:50 PM
civic is leaking water smashed4thgen Body / Exterior / Interior / Cosmetics 8 02-08-2004 12:39 PM
