This is a discussion on OBDII code P1337 CSF Sensor no signal in the Civic and del Sol - EG and EK forum
Can anyone tell me if the OBDII code P1337 CSF Sensor no signal is an easy fix or is it a shop issue....
| | #1 |
| Can anyone tell me if the OBDII code P1337 CSF Sensor no signal is an easy fix or is it a shop issue. |
| | #2 |
| Year? Car? for a 98 civic ex coupe all you need is a ohm meter to check for resistance between pins 1 and 3 (1.6-3.2k ohms) if its not that then replace the ckf sensor then check for ground from pin 1 and ground from pin 3 of the ckf sensor(it should be open when you check between the pins and body ground) if there is continuity, then replace the ckf sensor Then measure resistance between c1 and c11(harness side) if there isn't 1.6-3.2k ohms then fix your open wire. Then check for ground from c1(harness side) to body ground, if there is conintuity then fix the short keep in mind that this was the procedure for a p1337 on a 98 civic ex coupe
__________________ We pity him. We hate him. We fear him-all because there is a little of him in each of us, though we admit it to ourselves only in the darkest part of the night |
| | #3 |
| The vehicle is a 1996 Civic, sorry I thought I had that in there. Does what you wrote apply to this vehicle? thanks for the write back. Mitch |
| | #4 |
| It should yes. Just so you know what the code really is Diagnostic Trouble Code (DTC) P1337: No signal in the Crankshaft Speed Fluctuation (CKF) sensor circuit. Description The diagnostic system has a pulser rotor on the crankshaft and a pulse pick-up sensor on the engine block. The ECM/PCM monitors the crankshaft speed fluctuation based on the CKF sensor signal, and judges that an engine misfire occurred if the fluctuation goes beyond a predetermined limit. Could also try just clearing the code and seeing if it comes back on, it might be an intermittent failure. Last edited by girls_are_mean; 10-02-2006 at 12:03 AM. |
| | #5 |
| Hi, I just registered because I have the exact same code as the thread creator. I have a 2000 Honda Civic and I have code 1336, 1337. Please can you tell me if I can fix this myself with basic tools or must I put my car in the shop. For reference, the biggest job I did on my car is changing the timing belt (same honda as the one mentioned here) Thanks. |
| | #6 |
| i had my timing belt replaced at McDavid Honda in frisco and 2 weeks later i started getting p1337. I have the same honda civic 2000 ex auto. What did you do to get it fixed. Did you take it to the machanic, if so, what did he told you it was? thanks |
| | #7 |
| If your cars are still running fine and are not hard to start just clear the code and see if it comes back. If it comes back read above for trouble shooting. Someone already told you how to fix your car. READ! |
| | #8 |
| yea can anyone tell me more or less were it would b located?...the ckf and csf i never messed wit tht b4 |
| | #9 |
Similar Threads | ||||
| How a car amp works (pic) | cheese9988 | Car Audio / Security / Electronic Accessories | 11 | 08-29-2006 07:03 AM |
| Engines with the fastest piston speeds | asmallsol | Members' Lounge | 10 | 08-25-2006 08:01 AM |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 12:03 PM |
| codes | civichbwithb18a1 | HYBRID -> ED-EF / DA | 1 | 10-03-2003 02:24 PM |
| Code 16 - Ignition Output Signal | RFHOMI2U | ECU's, Electronics, and Tuning | 1 | 06-11-2003 02:29 AM |
