overheating?
Old 04-09-2007, 08:10 PM   #1
Ride:  87 Accord Hatch, 92 Acura Legend, 93 Civic Coupe
Rep Power: 0 charlesb2003 is on a distinguished road
myspace
Default overheating?
hey guys! i just bought my girlfriend's 93 civic dx. it's a really nice car, low miles, but the head gasket blew on it once before and her ex-bf fixed it. well, i don't think he did too good of a job, and it's ok because i'm gonna be doing a mini-me head swap to it soon and i can straighten it all out then, but for now, it's running a little hot. not to the red, but above the middle, and i know that's not normal on any honda. i tried flushing the coolant and refilling with 50/50 honda premix, and it doesn't do much good. there are no bubbles in the system, i bled it out for 20 minutes from the bleed valve and let it run and kept adding till there were no more bubbles. when i come to a stop, it goes to normal range (just below half) but the minute i hit the gas, it starts moving. it never reaches the red, but it moves up and down a lot. there was some gook in the overflow and around the cap, i hope leftovers from the bhg, but the coolant i drained was fairly clean. i cleaned the overflow and the cap and so far, no more gook. any guesses?
charlesb2003 is offline   Reply With Quote
Old 04-09-2007, 08:51 PM   #2
Rep Power: 10 Dasfinc will become famous soon enough
Check your T-stat. If its Bouncing up and down Rather Violently, it could be Sticking.
Teggy Powered Civic CX Hatch, and a 07 Ford Focus.
Check out my Mini-Me Write-up!
http://hondaswap.com/hybrid-eg-ek-dc...rite-up-96144/
Check out my B18B1 Swap Write-up!
http://www.honda-tech.com/zerothread?id=2239971
Dasfinc is offline   Reply With Quote
Old 04-10-2007, 09:39 PM   #3
Rep Power: 6 96EKB18C5 is on a distinguished road
pull your plugs & an try to start your car, if u see a water-foutain show, there's your answer=cracked/warped head or still blown head gasket.
96EKB18C5 is offline   Reply With Quote
Old 04-11-2007, 08:02 PM   #4
Rep Power: 0 TDSI99 is on a distinguished road
I would check you thermostat. It is either bad or is stuck. I have had that problem before....but mine shot to the top of the red.
TDSI99 is offline   Reply With Quote
Old 04-22-2007, 10:37 AM   #5
Ride:  94 civic
Rep Power: 0 JLTeedee is on a distinguished road
Default T-stat
sounds like it maybe stuck open a little, flowing to fast to cool, and make sure the bleed hole is up when you put it in.
JLTeedee is offline   Reply With Quote
Old 04-22-2007, 12:46 PM   #6
TheManRSW
Ride:  1995 Honda Del sol Si
Rep Power: 8 TheManRSW is on a distinguished road
Send a message via AIM to TheManRSW
Thermostat.
TheManRSW is offline   Reply With Quote
Old 04-22-2007, 06:21 PM   #7
Got Rice?
801CRX's Avatar
Ride:  89' CRX HF and 90' Civic Si
Rep Power: 25 801CRX is just really nice801CRX is just really nice801CRX is just really nice801CRX is just really nice
Thermostat
+1000
What's the difference between ricers and tuners?
RICERS: Use whats popular
TUNERS: Use what works
What are you
801CRX is offline   Reply With Quote
Forum Jump
h22 Overheating raidmax General Tech and Maintenance 17 11-25-2006 01:52 PM
Overheating???? supaCOUPE HYBRID -> EG-EK / DC 10 09-30-2006 03:27 PM
94 Civic overheating - help tloepfe General Tech and Maintenance 1 08-10-2006 10:58 AM
overheating problems? ReDLiNe_9700K HYBRID -> BA-BB /CA-CD 9 01-19-2005 12:23 PM
OVERHEATING with new Turbo setup hybrid89 Forced Induction 13 07-26-2004 05:25 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
