Problem Starting
Old 10-10-2008, 03:30 PM   #1
Rep Power: 0 Hondakid91 is on a distinguished road
Default Problem Starting
Okay I am new but here's my ? I have 92 civic hb and the other day it died on the way home. Later on it started again but died again. I have checked all fuel related possible problems. So could this be electrical? It turns over but thats all.
Hondakid91 is offline   Reply With Quote
Old 10-10-2008, 03:41 PM   #2
Rotary Man
hunter4life's Avatar
Ride:  1991 Mazda Rx-7
Rep Power: 14 hunter4life is a glorious beacon of lighthunter4life is a glorious beacon of lighthunter4life is a glorious beacon of lighthunter4life is a glorious beacon of lighthunter4life is a glorious beacon of light
Well I kinda had the same problem with my Rx-7. If your sure its not fuel related. Check obviously to see if you have spark. If not check your plugs wires as well as the obvious fuses. If this isn't the problem check all your grounds in your car and make sure they are all good as well. It's a step by step process and make sure you go through all of this with a fine tooth comb. Now if you still haven't found your problem check your distrubtor and your ignition coils Most likely you probably will have found your problem but if not try a new ecu.
Note: make sure you look for things like loose connections..perhaps to your ecu. Check main relay as well.
Hopefully someone else can chime in as well.
An ounce of action is worth a ton of theory. - Friedrich Engels
*Posted a few pics of the rex on my profile*
My Ride(s)
91 fc Rx7 (first and only car)
hunter4life is offline   Reply With Quote
« b-series | d16y7... »
Forum Jump
91 da starting problem 91da Integra 5 08-13-2008 11:05 PM
Starting Problem S14Civic Civic and del Sol - EG and EK 5 06-05-2007 12:36 AM
starting problem need help BAD jiajiexue Integra 26 05-18-2007 08:43 AM
starting problem crxricer88 Civic and del Sol - EG and EK 21 04-02-2007 09:14 AM
starting problem ^crx^ ECU's, Electronics, and Tuning 1 05-18-2005 03:34 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
