So I'm stumped
Old 06-22-2007, 10:45 PM   #1
The Riced Sleeper
ThatGuy4life's Avatar
Ride:  2000 Si w/B18C5-R swap
Rep Power: 45 ThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud of
myspace
Default So I'm stumped
Ok so ya'll remember my little mishap(s) on Tuesday? Well I thought I had fixed the problem but no dice. Drove all the way from home to work this morning, 53 miles no problem, drove to the bank to make some deposits for work, and a few other errands. THen around 4pm I stopped by one of my boy's performance shop cause they was supposed to have one of my a/c compressor their, upon leaving their, the same thing that happened Tuesday happened again. Major fuel cut, wouldn't crank for about 20 minutes and when she did, I manage to drive about 20 feet then no fuel again. I checked the fuel lines like EG6 suggested and from what I can see none seems to be pinched from me rolling over that big old tread.
All the guards that cover the fuel lines under the car seems tp be in tack, so I pulled the fuel pump and re-clamped the connectors and made sure the ground was tight, just cause one of my boys said it might be my fuel pump. But today while I was stalled on the freeway I unhooked it again and put it back again, and she primed every time, and I could feel the line vibrate as fuel ran through but some how it's not getting to the engine itself. Was planning on just taking it to the dealership to let them have the headache but both are backed up till tuesday, so in the meantime if any one have any suggestions as to what it might be I'm open for ideas.
Originally Posted by reckedracing View Post
it takes a strong person to open themselves to criticism, and a weak person to sit behind a computer screen and criticize
Dam, did I just beat u in my Honda? Sure did, now your girl wants to get at me (True Story) "I built it, I drive it, your opinion doesnt matter. It doesn't have to be JDM it just has to be functional." (2nd part of sig. taken from 89CRXZC)
http://racingsouthwest.com/forums/in..._item&CID=1708
ThatGuy4life is offline   Reply With Quote
Old 06-22-2007, 11:14 PM   #2
Ancient Member
welfare's Avatar
Ride:  RHD EG6 jrsc b18c :)
Rep Power: 29 welfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the rough
Send a message via AIM to welfare
umm, this may sound wierd, but check your wires for the o2 sensors. . . if nnot that, then I would say what eg6 said about a pinched fuel line.
9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6
doing it myself!
6/1/09 RHD on the road, now time for Body Shop
7/10/09 jackson gsr into rhd+hondata
91 rex ls/vtec
b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER!
13.881@102 on street tires
Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some
reptation, then give 'em a point!---,
welfare is offline   Reply With Quote
Old 06-22-2007, 11:16 PM   #3
The Riced Sleeper
myspace
Will check that tomorrow didn't think to look at that while I had it raised up, but wouldn't it throw a cel for that
Old 06-22-2007, 11:20 PM   #4
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Check for loose connections? The jarring from the tire could have knocked a connector loose.. Tossing any CEL's?
Do those civics have the same main relay problems as the late 80's/early 90's civics had? Could have aggravated a loose connection in there.
Put it up on a rack if you can and do a close inspection of the whole underside of the car.. Look for stripped/crushed wires, too.. Under the front bumper as well, no telling how far that thing flexed back.
Are the injectors "firing" and not getting any fuel, or are they not ticking at all?
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 06-22-2007, 11:25 PM   #5
The Riced Sleeper
myspace
no cels, and as for the relay I don't think there were any problems with the 99-00 si's but I did check the relay also today while I was on the freeway. when I had that bogging problem I had bought a new relay but since that wasn't the problem I had put the old one in but kept the new one in the car, so I put in the new onw while I was waiting to be towed but no dice. injectors are firing just not getting any fuel
Old 06-22-2007, 11:29 PM   #6
Ancient Member
welfare's Avatar
sometimes the cel for the second o2 sensor doesnt set right away, but yah, after a whole day of driving it prolly would have. wouldn't hurt to look tho.
I cant think of anythign else.
doing it myself!
91 rex ls/vtec
Old 06-22-2007, 11:31 PM   #7
!!YTINASNI
phyregod's Avatar
myspace
Thats odd as hell, man. Fuel pump is whirring, injectors are ticking.. no fuel. And you can drive it 50 miles before it eats shit.
Is that recurring? Drive it for 50ish miles and it breaks down for a bit, then starts back up? Or is it just dead now? Reason I ask is sometimes cars will do that if the gas cap is messed up. Cadillacs are bad about it.
You sure its a fuel issue, not a spark issue?
Old 06-23-2007, 12:32 AM   #8
The Riced Sleeper
myspace
Recurring, just the 2nd time since rolling over that tread. as far as I can tell it's getting spark, I had to end up buying one of those see through dizzy caps cause every shop in town was out of the oem ones when I was looking for as I thought the cap and rotor might have been the cause of the bogging issue I had a while back so I can see the sparks as it's cranking. What's killing me is that when I was sitting on the freeway I'd crank and she'd start then as I try to take off...fuel cut. Try to crank wight after that and nothing, wait a while and she'd turn over.
Old 06-23-2007, 12:06 PM   #9
!!YTINASNI
phyregod's Avatar
myspace
Sounds like something is overheating. Start it cold, runs fine, breaks down on you, let it cool, starts up again..
When is the last time you changed your fuel filter? Does it spit and sputter and run like crap before it dies or does it instantly cut off?
I still want to point to the fuel pump, personally.. Might have blown a seal inside there.
Old 06-23-2007, 11:07 PM   #10
hondacrxb16vtec's Avatar
Ride:  1994 civic ex coupe
Rep Power: 9 hondacrxb16vtec is on a distinguished road
Send a message via Yahoo to hondacrxb16vtec
i think mayne the filter? i had a 99 si and when it dropped beloew a half a tank it would cut out on me. i replaced the filter and all was well.
-TONY-
1994 civic ex
hondacrxb16vtec is offline   Reply With Quote
Old 06-23-2007, 11:48 PM   #11
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
almost the same as the truck i fixed... fuel in the lines, injectors not firing...
replaced the pump good to go...
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 06-24-2007, 07:54 PM   #12
The Riced Sleeper
myspace
filter was changed the same time the 255 went in which was about 3-5 months ago
Old 06-24-2007, 11:18 PM   #13
wow very puzzleing.
-TONY-
1994 civic ex
Old 06-25-2007, 10:08 PM   #14
dtob's Avatar
Rep Power: 11 dtob is an unknown quantity at this point
Sounds like a coil overheating to me.
Bad coil. Works for a while then when it heats up it quits.
dtob is offline   Reply With Quote
This one has got me kinda stumped hybrid89 HYBRID -> EG-EK / DC 15 05-28-2005 09:03 PM
Tough question......Im stumped. adnoh Car Audio / Security / Electronic Accessories 4 06-02-2004 03:45 PM
Stumped w/ a High Idle mrvanparys HYBRID -> EG-EK / DC 7 12-01-2003 12:45 AM
Stumped redhatch92 ECU's, Electronics, and Tuning 6 02-12-2003 06:18 PM
