Swap or not?
Old 01-04-2008, 11:28 PM   #1
rockenroller6's Avatar
Ride:  99 Civic Ex
Rep Power: 0 rockenroller6 can only hope to improve
Default Swap or not?
Sorry if I have posted in the wrong forum but I've got a 94 civic dx with the stock d15b7 motor and after replacing a head gasket that I thought was blown, it now has decided to leak again. I dont want to part with my little blue wonder because its in super shape for a 94 besides the head which has to be cracked or warpped. So that leaves me with the option of dropping in a d16z6 vtec motor. I dont need the power, its my daily driver and with the idiots in my town, believe me my little 1.6L will get the job done. So my question is will this motor drop straight in and bolt to my stock tranny without modification or extra parts besides the ecu and vtec wires? Or should I just pull the head, mill it and call it a day?
rockenroller6 is offline   Reply With Quote
Old 01-05-2008, 02:58 AM   #2
xips(86CRXSI)'s Avatar
Ride:  91 si hb gsr swap
Rep Power: 10 xips(86CRXSI) is off the scale
myspace
Either way would be a go, the d16z6 will drop right in with no mods to your trans, and if you didn't want to get the ecu and wire the v-tech you could drop in right in and go, or get the ecu and run some wire's(not hard to do) and have a nice little set up, and if you go the other way and have the head milled make sure you have the shop test it to see if it has a crack, and make sure you run a straight edge across the top of you block in multiple place's to make sure the block is not warped (most likely not) and put back together and go. Less work to fix the head and money, but if you want v-tech than do the swap. or just swap in the v-tech head and wire the v-tech and change the ecu. All those options will get you back on the road, It's just a matter of what one you want to do.
xips(86CRXSI) is offline   Reply With Quote
Old 01-05-2008, 03:16 PM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Old 01-05-2008, 05:19 PM   #4
Ride:  99 Civic Ex
Yeah I was thinking about a mini-me swap, I know the blocks not cracked or anything, so I would be fine to just bolt on a d16z6 head? Wouldnt have to change injectors or anything right? Just the head? I want this to be reliable so I dont want the wiring to be all ghetto so should I just use a P28?
Old 01-15-2008, 11:51 PM   #5
myspace
Yes get the p28, and have some one who know what there doing wire the vtec, or you can do this, if you trust you self to do it right, I'm pretty sure you can use you intake and injectors and all, but make sure you get the all the head parts, there may be something you need to do to the block for the vtec to work, I'm not positive though.
Old 01-15-2008, 11:58 PM   #6
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Just have the head re-surfaced, and check the deck of the block and make sure it is somewhat level.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 01-16-2008, 12:09 AM   #7
myspace
Heres a link I found that should help you on this. http://hondaswap.com/hybrid-eg-ek-dc...rite-up-96144/
Old 01-16-2008, 03:15 PM   #8
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 103 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
Ah, the ironies of life. haha After quite a while, lets just say, of having the same engine, a D15B7, I came across a D16Z6 for a very low price. It's a direct bolt-on as everyone else has told you and wooooo, I could tell the difference in power. haha I know it's sad but true. This is going to help keep me going until I either A, decide to build up the LS block that I have or B, decide on whether to go with a B18B or a B18C. Decisions, decisions. Either way, I wish you luck my friend. Keep us posted.
Luis998 is offline   Reply With Quote
Old 01-30-2008, 12:35 AM   #9
Banned
Rep Power: 0 OKCZombie is on a distinguished road
do the mini me swap and have some fun - I dunno if that is the same write up I have saved at home but there is a few things to make sure you do or it won't work and vtec won't engage it isn't just head gasket and head bolt on -
OKCZombie is offline   Reply With Quote
Head swap brownkobe8 HYBRID -> BA-BB /CA-CD 5 03-08-2007 10:59 PM
Need help deciding which swap, B18A or H23A bigblockhatch Civic and del Sol - EG and EK 8 11-20-2006 03:37 PM
need some info on swap gin Civic and del Sol - EG and EK 0 09-16-2006 09:22 PM
need info on b18 swap gin Civic - EP, FA, FG 1 09-13-2006 09:15 PM
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 01:32 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
