Timing light?
Old 08-09-2006, 02:22 PM   #1
abarone300 is on a distinguished road
Default Timing light?
Would anyone know how many degrees BTDC or ATDC should I adjust my timing is it in the manual, or is there a lable under the hood somewhere, and do I use a timing light, where are the timing marks located on, on the crankshaft pulley?
I have a '95 Sol with a VTEC/DOHC, and its a bit hesitant from a dead stop.
I recently replaced the timing belt, It runs well, except for the slight hesitation, I think if I advance the timing a couple degrees it'll be ok!
Thanks
abarone300 is offline   Reply With Quote
Old 08-09-2006, 03:10 PM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
reikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
reikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
myspace
most hondas are +16. check at the flywheel side of the engine, you should be able to shine the timing light in there and see what your timing is set at.
reikoshea is offline   Reply With Quote
Old 08-09-2006, 06:36 PM   #3
Default Thank you!
Thank you Reikoshea, will do!
Aldo
Old 08-09-2006, 07:43 PM   #4
Default No opening in bellhousing...
In order to see anything rotating on the flywheel side, the transmission bellhousing would to have a window, I don't see one (unless one looks under the car). The opening on the underside is probably for drainage or some other reason...
Aldo
Old 08-09-2006, 07:53 PM   #5
HS Troll...And Mod
reikoshea's Avatar
myspace
there is usually a rubber plug over the window...at least there is on the h22.
Old 08-09-2006, 08:04 PM   #6
Default I'm going out there, and look for that plug right now!
I'm going to give it another try R!
No luck! Sorry...
How many forum posters does it take..... pissedoffsol Members' Lounge 51 11-30-2007 11:32 PM
a6 head on z6 block... which timing belt hmtcrxsir Engine Building 9 11-08-2005 05:32 AM
RPM on Timing light question? hondadriver General Tech and Maintenance 1 12-27-2004 06:45 PM
who makes a good timing light? saturn_boy96 General Tech and Maintenance 3 04-14-2004 11:09 AM
How to: Adjusting Cam Gears pissedoffsol General Tech Articles 0 01-12-2004 12:49 AM
