Tranny Issues
Old 03-29-2008, 11:16 PM   #1
Rep Power: 0 santaclaus57 is on a distinguished road
Default Tranny Issues
So I have an issue with my 5 speed. The clutch pedal goes to the floor and the car will start but there are absolutely no gears, the shifter won't go into gear wether it's started or not.
Ideas?
santaclaus57 is offline   Reply With Quote
Old 03-31-2008, 10:34 PM   #2
Blinker Fluid Specialist
Ride:  95 delsol SI
Rep Power: 8 delsol88 is on a distinguished road
myspace
does the shifter move at all. Might be your linkage
delsol88 is offline   Reply With Quote
Old 04-01-2008, 07:14 PM   #3
ya, the shifter moves but it just wont go into gear.
Old 04-01-2008, 07:27 PM   #4
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
Slave Cylinder or Throw Out Bearing
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 04-01-2008, 09:26 PM   #5
AHHVTEC's Avatar
but it should still be able to go in gear while the car is off without even using the clutch peddle
Old 04-02-2008, 01:07 AM   #6
ya, it goes into gear when the car is off but not when it's running.
Thnx for the advice on the slave cylinder, I'll have to replace it.
Old 04-02-2008, 01:23 AM   #7
AHHVTEC's Avatar
yea in that case it sounds like a bad slave
Old 04-08-2008, 12:48 AM   #8
Ride:  95 delsol SI
myspace
how about u get a buddy to push the clutch while the hood is popped. if its good you should see the rubber boot on the tranny move a little bit. if it doesnt move its bad.
Old 04-08-2008, 01:09 AM   #9
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
If the pedal is going to the floor, than there is either air in the system caused from a leak or an improper bleed procedure, or the slave cylinder is damaged internally. Remove the slave cylinder and bench bleed it to see if it will bleed without leaking from the rear (where it mounts to the firewall). If there is brake fluid exposed in there than the slave cylinder is bad. I would check the slave first, and if its all clean where it mounts (2 bolts), than bleed the slave cylinder from the bleeder screw on the transaxle. Make sure its done correctly or else you will end up with the same problem you have now. If all else fails, check the lines and fittings for leaks. If all good than replace the slave cylinder with a new one (remanufactured), and bench bleed it before you put it on. After it is on, you must bleed the line out as well. After that, pump the clutch pedal with the engine running until the clutch pedal returns on its own and has minimal pedal play.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
busted tranny.......no more! Taco15 Auto Multi-Media 28 05-21-2006 10:10 PM
3.2 Liter SOHC V-TEC and Tripnotic Tranny TheGreekLV Parts: For Sale/Trade/Wanted 18 03-24-2006 07:06 PM
D16Z6 tranny issues after swap beatboxed HYBRID -> EG-EK / DC 0 11-10-2004 04:38 PM
K24 Longblock, type S tranny, clutchmasters clutch acydphryck Parts: For Sale/Trade/Wanted 0 01-27-2004 02:26 PM
Tranny Problems? Raxx General Tech and Maintenance 2 05-14-2003 07:23 AM
