I am placing a d15z1 in my 89 dx. I was pondering changing the dx tranny for the cx/vx that actually belongs to this engine, but they hard to come by for a decent price. I have access to a crx hf tranny, i do not know which one it is though. Would my dx tranny run the rpm's too high if I just kept it, and also, would the hf gears be a bit too long and make my pickup speed suffer greatly? While I'm asking questions, will the hf tranny fit the z1 and my hatch with my current mounts?
Crusher of Noob Ambitions
Ride: 97 Integra LS Coupe
Keep in mind that they switched to hydraulic transmissions for the Civics in 92, so unless you want to do an expensive conversion, you're limited to 91 or older transmissions anyway...
If you find something I say helpful, please rep it up! Also, DO NOT PM me with tech questions! Use the forums so we can all benefit from the answers. I will NOT respond to tech-related PMs... 97 Integra LS Coupe: *AEM Intake/Megan Header/Magnaflow Exhaust *Tokico Shocks & Springs *Megan Strut Braces & H-Brace *98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys) |
#3 | |
The hf trans is simmilar to the cx/vx trans' in that they are geared purely for mileage rather than performance. Being a cable trans it will bolt right up. I know that the dx trannies are only 4 speed, which I would avoid.
93' dx hatch jdm b18c - jrsc 8psi s300 440cc RC's |
#5 | |
Well then if you owned one then you would know better than me. I guess I thought that the dx was the lowest model.
#6 | |
#7 |
Ride: 88 Honda Civic HB
I love my Std.
Then again, it has a swapped motor and transmission.
1988 Honda Civic STD-more mods than I want to list Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 |
#8 |
Ride: 1992 Civic VX hb
are u going for fuel efficiency ? just bolt up the HF then. make sure ur clutch/flywheel match the tranny tho.
Free info on affordable access to Justice & ID Theft Services @ www.prepaidlegal.com/hub/deantaber
#9 |
For the non-8v motors, letting the engine rev can net higher MPG. I got 57mpg on the highway, sitting at 4000rpm at 70mph on a D15B-VTEC with DOHC ZC transmission(4.25 Si FD).
For the 8v and VTEC-E engines, it's good to keep the revs a little lower. A good compromise is the to get a DX transmission and just use the HF final drive along with the HF 5th gear.
#10 |
Ride: 95 Del Sol, 97 Accord
57 MPG.....Wow. Ok now the dumb questions. I've got a Z1 block with everything else (head, i/e and tranny) from my Z6. How do I get even close to that??? I just ran my first tank thru on this set up and got 35MPG doing 50 to 65 on mostly curving rolling hills. I'm really jealous!
#11 |
Well, my setup is pretty close to a "Z6"; but with the Z1 block I'm pretty sure you're losing some power/efficiency from that dished piston. The Z1 head has a smaller combustion chamber to make up for that; so I'd look into changing the piston for P08 or PMS ones.
Also, how you drive makes the biggest difference. Avoid having to give it large amounts of throttle during cruising, don't worry too much about RPM as load makes more of a difference. This means that if you have to give it more gas in order to cruise in the next gear...then just stay in your current gear....especially with hills.
| JDM GSR Swap B16 tranny ls 5th Skunk 2 goods NICE swap!! | dornon13 | Parts: For Sale/Trade/Wanted | 13 | 02-07-2008 12:04 PM |
| gsr tranny to ls tranny swap. cracked bellhousing | bannacrx | Integra | 8 | 04-02-2007 12:47 PM |
| gsr tranny or ls tranny for b20z swap | deity | HYBRID -> EG-EK / DC | 3 | 07-10-2005 10:31 PM |
| Cable Tranny to Hydrolic Tranny Swap | slick469 | HYBRID -> ED-EF / DA | 7 | 02-16-2004 10:55 PM |
| Automatic tranny swap with 5sp tranny | lexvdub | HYBRID -> BA-BB /CA-CD | 4 | 09-28-2003 10:20 AM |
