Transmission Noise
Old 03-17-2007, 02:29 PM   #1
S14Civic's Avatar
Rep Power: 6 S14Civic is on a distinguished road
Default Transmission Noise
Hey so I have a question......my car is making a funny noise when i let the clutch out......when i press the clutch in the noise stops.....i just replaced the throw out bearing so im pretty sure its not that? Any ideas? someone said it might be the pilot bearing? if thats the case how long do i have until my transmission dies on me?
S14Civic is offline   Reply With Quote
Old 03-18-2007, 03:52 AM   #2
drive it like U stole it
custompainter's Avatar
Ride:  99 dx coupe y8, 94 ex coupe z6, 89 teg zc,
Rep Power: 11 custompainter is on a distinguished road
well it might be your clutch or presure plate too theres only one way to find out pull the tranny see what your working with it's not hard only takes a couple hours
custompainter is offline   Reply With Quote
Old 03-18-2007, 05:47 PM   #3
Rep Power: 12 stuntstere is off the scale
My car did the same thing. It ended up being a bearing on the mainshaft inside the tranny. Hope this helps ya.
stuntstere is offline   Reply With Quote
Old 03-19-2007, 02:04 AM   #4
S14Civic's Avatar
replaced the clutch and flywheel as well....forgot to say that.......it was making the noise before i replaced the flywheel, clutch, and throwout bearing....i replaced those parts hoping it would fix the noise.....still making the noise though
Old 03-20-2007, 08:18 PM   #5
asst.region manager
joecivic's Avatar
Ride:  94 honda civic
Rep Power: 8 joecivic is on a distinguished road
I did the samething with my trans it was making a noise exactly like you decribed so I did the same thing replaced the clutch and the throw out bearing but it still made the same noise.it most likely is the mainshaft bearing how you know this is when you take out the trans grab the shaft of the trans and try to move it around it should not move in and out or have play in any direction.Its up to you weather you want toi rip the trans apart and replace the bearing or buy a new trans.I bought a used trans and kept my old one to fix later
joecivic is offline   Reply With Quote
auto to manual conversion d112crzy HYBRID -> BA-BB /CA-CD 0 09-13-2006 11:27 AM
Transmission Noise illmatik General Tech and Maintenance 5 09-20-2004 04:22 PM
B-series Transmission Guide pissedoffsol Swap Articles 1 06-01-2004 05:46 PM
B18c5 In 88 Crxdx Will There Be Room 4 Turbo?>? T4 88crxdx HYBRID -> EG-EK / DC 13 02-04-2003 05:03 PM
