turbo question
Old 01-27-2009, 01:22 AM   #1
rkwoos12's Avatar
Ride:  94 honda civic ex 5 speed
Rep Power: 8 rkwoos12 will become famous soon enoughrkwoos12 will become famous soon enough
Default turbo question
hey guys i have a 94 civic ex with a stock d16z6 vtec engine with 100k miles on it right now i was wonder im thinking about boostin it but unsure because im afraid if i will mess with the reliability of the engine i dont want to run very high boost like a 10 psi on t4 turbo or something like that nothing major but my last engine i had in the car got blowed up because the guy that had the car befor me had a turbo on it and messed it up perty bad befor sellin it to me with out telling me so my question is should i go ahead and slap a turbo on the d16 with a good tune or should i build up the engine first, if i build the engine im thinking about going with a B16 sir2 swap and building it for later on turbo. let me know what you guys think i should do either way i want a turbo i have driven a turbo civic befor and loved it i dont want no crazy hp levels or nothing jsut enough to have some fun out of my dd.
rkwoos12 is offline   Reply With Quote
Old 01-27-2009, 02:02 AM   #2
sufikation's Avatar
Ride:  95 civic sedan ex (dd), 92 caged civic hb (project)
Rep Power: 28 sufikation is a splendid one to beholdsufikation is a splendid one to beholdsufikation is a splendid one to beholdsufikation is a splendid one to beholdsufikation is a splendid one to behold
i have been pondering throwing my turbo onto my 95 eg sedan, but as a dd i would only want to run like 5-6 pounds of boost. although 10 pounds may not seem like a lot it will wear down any dd over time. also...learn to punctuate. good luck, peace.
Son Of a Bitch Everythings Real
sufikation is offline   Reply With Quote
Old 01-27-2009, 03:28 AM   #3
rkwoos12's Avatar
well first off sorry about no punctuation, but any how, would 8psi be ok on stock internals? tuned on crome? is there any thing i can do with out tearing down my whole engine and rebuilding it?
Old 01-27-2009, 05:23 AM   #4
rkwoos12's Avatar
about how much hp could i be expecting with a stock d16z6 vtec engine and t4 turbo at about 6-8 psi?
Old 01-27-2009, 10:00 AM   #5
Stleger184634's Avatar
Ride:  98 honda prelude
Rep Power: 3 Stleger184634 will become famous soon enough
myspace
i would think you would be fine running 6-8 psi on that stock motor but not with a crome tune you will need to have to have it dynoed or it will run like doo doo, as far as building it if your gonna do the work to turbo a single cam you might as well just buy rods and pistons while ur at it its not hard to do. and as far as how much hp tht will land you i couldnt tell u cuz i never went that low. but as your dd your car isnt going to be very reliable if you dont do any work to it before putting a turbo on it
97 EK4 d16zc boosted 18lbs : t-boned by drunk driver
98 BB6 f20b : Daily Driver =)
www.theoldone.com
Stleger184634 is offline   Reply With Quote
Old 01-28-2009, 01:04 PM   #6
Hamby
hondacivicdx92's Avatar
Ride:  Turbo 92 Civic DX hatchback
Rep Power: 8 hondacivicdx92 has a spectacular aura abouthondacivicdx92 has a spectacular aura about
myspace
alright, first off psi is irrelevant , ask anyone who knows their shit. Second, ur D will be fine with a little boost and a good tune, just make sure you have it dyno tuned by a reputable tuner. It will be reliable. You may also want to figure out when you want to be able to build boost. If you want to be making boost at lowe rpm's then you may want to go with something a little smaller than the t4 that will spool faster. Anyways these are just some suggestions.
Some good advice I got when first entering into turbo's was: up to 6psi stock internals are fine, 6-12psi u will want to go with forged rods and pistons, anything over 12psi forged rods and pistons and sleeves. but for any boost I would recommend arp head studs and either a quality aftermarket head gasket like a cometic or an oe gasket.
hondacivicdx92 is offline   Reply With Quote
Old 01-28-2009, 01:21 PM   #7
Greenhorn
Ride:  1994 del Sol Type R
Rep Power: 0 iJDM is on a distinguished road
Do internals before boosting, or else you'll blow it and be back to square one. My friend was running 8 psi with a T3/T4 turbo in a Ls/VTEC and he blew the motor.
iJDM is offline   Reply With Quote
Old 01-28-2009, 11:50 PM   #8
rkwoos12's Avatar
yeah thanks for all the suggestions i was thinking of going with a t4 turbo think that be enought for me i was wanting to run about 6 to 12 some where inbetween so i guess i need to build the motor first.
Old 01-28-2009, 11:54 PM   #9
rkwoos12's Avatar
is there any thing i should do to my stock ex transmission while geting ready for this turbo setup?
Old 01-29-2009, 01:01 AM   #10
rkwoos12's Avatar
so would Wiseco Pistons and Eagle Rods be a good choice at 75.50mm (+020" Overbore) and compression at 8.5:1? of should i resleve my block befor i bore it? or would 020" bore be fine?
Old 01-29-2009, 05:51 PM   #11
austin20110's Avatar
Ride:  96 civic coupe, 05 s2k project car with buddies
Rep Power: 39 austin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud of
Send a message via AIM to austin20110
weld your spider gears together lol
Originally Posted by packardbell View Post
i plan to modify it to the max and swap out the motor and go fi.
austin20110 is offline   Reply With Quote
new turbo question? aCCordHSF Accord 15 04-09-2008 11:43 PM
motor mount question and gasket question 93integraxchic HYBRID -> ED-EF / DA 2 07-12-2007 01:50 AM
can someone do me a favor? (simple wiring question and speedo question) civiclxb16 ECU's, Electronics, and Tuning 2 03-29-2007 11:21 AM
Turbo b16 question Specc Forced Induction 6 04-14-2006 08:16 PM
first turbo question! Taco15 Forced Induction 14 03-12-2006 10:45 PM
