lol....... theres a reason why noone has answered yet but... im not gonna b an ashole because i dont know much myself, the answer to ure question is, yes. depending if thats the only thing u have to regulate ure psi, coz u could have a 10 psi wastegate but a 5psi bov or boost controller regulated for 5psi then u would still have 5psi of pressure and u would be stressing those other components, dont run a computer tuned for 5 pounds with 10coz ull b runing lean.
so the thing is u want 10pounds, u need change the tuning and all parts that regulate the psi on ure car to 10 psi if im wrong ppl, feel free to correct me |
Administrator
Ride: 318ti, dakota, genesis 2.0t
that's not remotely accurate.
. a BOV has ABSOLUTELY NOTHING to do with boost pressure. period. it rleases excess boost when the throttle is closed to prevent back-spinning (surge) on the turbo compressor wheel. a boost controller can NOT lower boost below the spring in the wastegate. it only goes up from the spring, and in general, a BC can do about double spring. So, a 5psi spring is the lowest, and about 10 ish is the highest with the controller for that spring. on a 10 psi wg spring, you can go to about 20 psi via the BC. To the OP, Yes, you will need to re-tune. |
#4 | |
ok nice tnks for shredding me heheheeh, the bov I kind of knew but i wasnt sure the word "backpressure" kept hitting my head while I was writting but the boost controller, well didnt know, so u couldnt set a lower pressure with a boost controller then the spring pressure on the wastegate u say? |
#5 | |
ok lol thinking about it dumb question..... so leaving to a side my obvious noobness, he could basically get a manual boost controller and get 10 psi without changing the spring hmmm that would be better for him |
#7 | |
my cars go fast
Ride: ED8
haha. yes. retune. |
| Wastegate/Turbo question | jOnZ | Forced Induction | 5 | 05-14-2008 02:17 PM |
| what wastegate should i use on a turbo b16 | orangemanja | Forced Induction | 7 | 02-18-2008 05:23 PM |
| what wastegate should i use on a turbo b16 | orangemanja | Civic - EP, FA, FG | 3 | 02-14-2008 11:58 PM |
| WTB external wastegate and turbo | dirtygsr94 | Parts: For Sale/Trade/Wanted | 2 | 03-12-2006 10:50 AM |
| Turbo Wastegate Actuator | Prowler | Forced Induction | 0 | 05-25-2003 11:01 PM |
