whats a better bottom end z6 y7 y8?
Old 10-08-2008, 01:28 AM   #1
LS_TUNER
Ride:  92 integra ls
Rep Power: 0 mountainracer1988 is on a distinguished road
Default whats a better bottom end z6 y7 y8?
My buddy is rockin a 94 civic coupe he put a rod through the block and wants to put another single cam in it WHY is beyond me. But anyway the d16z6 block that was in it was a beast (FOR A SINGLE CAM) but if im gonna help him build a faster one i wanna know what the best block would be for it
mountainracer1988 is offline   Reply With Quote
Old 10-08-2008, 01:43 AM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 160 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
d16z6
AHHVTEC is online now   Reply With Quote
Old 10-08-2008, 10:45 AM   #3
Rotary Man
hunter4life's Avatar
Ride:  1991 Mazda Rx-7
Rep Power: 14 hunter4life is a glorious beacon of lighthunter4life is a glorious beacon of lighthunter4life is a glorious beacon of lighthunter4life is a glorious beacon of lighthunter4life is a glorious beacon of light
+1 D16z6 is best option
An ounce of action is worth a ton of theory. - Friedrich Engels
*Posted a few pics of the rex on my profile*
My Ride(s)
91 fc Rx7 (first and only car)
hunter4life is offline   Reply With Quote
Old 10-08-2008, 05:40 PM   #4
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 10 t3t4delsol has a spectacular aura aboutt3t4delsol has a spectacular aura about
I actualy disagree the z6 comes with a 9.2:1 compression while the y8 comes with a 9.6:1. The y8 makes 2 extra hp and tq because of the extra compression. Now considering that you are talking about a z6 block to begin with, I would stick with that. You have extra things to worry about with the y8 like a knock sensor. Also changing over to the y8 would require converting to obd2, unless your planing on chipping the ecu to run the correct maps for the y8.
Just my .02
t3t4delsol is offline   Reply With Quote
Old 10-08-2008, 05:51 PM   #5
HS TECH
AHHVTEC's Avatar
he asking about blocks not heads, and the y8 block is known to go because of its poor ability to oil right
Old 10-08-2008, 06:01 PM   #6
Ride:  89 ZC CIVIC HATCH AND 96 CIVIC 4DOOR
Rep Power: 0 honda1 is on a distinguished road
z6 block
honda1 is offline   Reply With Quote
Old 10-08-2008, 06:19 PM   #7
mintoxik's Avatar
Ride:  93 civic cx
Rep Power: 4 mintoxik is on a distinguished road
z6
mintoxik is offline   Reply With Quote
Old 10-08-2008, 06:21 PM   #8
t3t4delsol's Avatar
No where did i mention about heads, and the y8 doesn't have poor oil ability, It does however have slightly longer rods for increased stroke, so the length the oil has to travel through the spert holes in the rods is longer. If thats what your referring to about poor oil ability. This speculation that the z6 oils better then the y8 has been going on for years. However there is no difference between the two. Honestly I would think is would be harder for the z6 to oil primary on start up because the oil pan is deeper.
Old 10-08-2008, 06:43 PM   #9
HS TECH
AHHVTEC's Avatar
compression is made from the head type and pistons, there both a 1.6 so the stroke is pert much dead on. the y series does have a oil problem ive saw lots of y8 with my own eyes fail because of this.
Old 10-08-2008, 08:51 PM   #10
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
Rep Power: 18 90civicboy is a glorious beacon of light90civicboy is a glorious beacon of light90civicboy is a glorious beacon of light90civicboy is a glorious beacon of light90civicboy is a glorious beacon of light
What about a D16A6 block, its known to be the strongest.
Rep's nice if I say helpful stuff.
Build thread: http://hondaswap.com/auto-multi-medi...3/#post1157798
90 Civic Si
~Auto to manual, Si tranny.
~eBay intake , K&N filter.
~NGK plug wires.
~DA Integra rear discs.
~DA Integra 40/40 prop. valve.
~DA Integra booster/master cylinder.
~D16Z6 swap coming soon.
~Ricer fart can soon to be removed.
~Full stereo w/sub.
90civicboy is offline   Reply With Quote
Old 10-08-2008, 08:54 PM   #11
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
Ya, Y7, Y8. I've seen SOOOOO may with spun bearings or blown.
90 Civic Si
~NGK plug wires.
~Full stereo w/sub.
Old 10-08-2008, 08:58 PM   #12
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 101 efhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
I have a Y7 in my back yard with a rod knock so bad it sounds like a diesel motor.
Looking for a P28 and B-series turbo parts, PM me.
Old 10-08-2008, 09:07 PM   #13
HNFTuning
D15Beater's Avatar
Ride:  91 B7/Y8 mini Hatch
Rep Power: 9 D15Beater has a spectacular aura aboutD15Beater has a spectacular aura about
+1
D15Beater is offline   Reply With Quote
Old 10-08-2008, 09:24 PM   #14
Youngest on HS :P
90civicboy's Avatar
Ride:  ED7 Civic
Originally Posted by D15Beater View Post
+1
My dad snaped a timing belt on his and we put a new piston in and a new head on and its as happy as can be. And believe me, he beats the shit out of it.
90 Civic Si
~NGK plug wires.
~Full stereo w/sub.
Old 10-08-2008, 09:59 PM   #15
HNFTuning
D15Beater's Avatar
My next mini me build is gonna be part SOHC ZC, part Y8, part D16a1
Old 10-08-2008, 11:26 PM   #16
99sidude's Avatar
Ride:  93 DX Hatch
Rep Power: 28 99sidude is a glorious beacon of light99sidude is a glorious beacon of light99sidude is a glorious beacon of light99sidude is a glorious beacon of light
Send a message via AIM to 99sidude
the y7/y8 motors are known to have oil pump issues. I'd go for the z6
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 10-24-2008, 05:07 PM   #17
Rep Power: 0 beano135 is on a distinguished road
Hey guys. I've got a 98 Civic EX with the d16y8 and its locked up. I want to just swap the block over and/or put a good crank in with some eagle rods and some forged pistons for turbo-charging the beast. From what i've seen all the blocks from 92 to '00 will work(i'm assuming providing the are vtec)
Do they have to be Vtec blocks to bolt my y8 head back onto it? correct me please and lead me in the right direction. I want to get her running soon. I'm guessing you will say Z6 block right. What model civic did they come in?
I have considered swapping to a b16a but I think it would be cheaper to turbo what i have and not have to do all the swap work.
Thanks for any good input
beano135 is offline   Reply With Quote
Forum Jump
H23 bottom end Q's operation-DA Prelude 11 08-07-2008 12:10 AM
WTB B20 Bottom End ls ef Parts: For Sale/Trade/Wanted 0 03-21-2007 01:15 PM
bottom end seanclark Forced Induction 19 12-17-2004 07:09 PM
gsr bottom end TWAN Parts: For Sale/Trade/Wanted 19 03-04-2004 10:22 PM
b16 bottom end t3t4si Forced Induction 3 12-23-2003 01:47 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
