will this engine(swap) work......
Old 07-18-2008, 04:43 PM   #1
Ride:  95 civic
Rep Power: 0 civicdude007 is on a distinguished road
Default will this engine(swap) work......
i am pulling my 1'5l out of my 95 civic and looking for a replacement.i found a d16z6 and it is a single cam vtec engine. the engine was pulled out orinally from a 95 civic . what else do i need to get my civic back on the streets.......is the harness the same , tranny bolt up ...is there anything else i need to purchase?
civicdude007 is offline   Reply With Quote
Old 07-18-2008, 04:51 PM   #2
mintoxik's Avatar
Ride:  93 civic of doom
Rep Power: 5 mintoxik is on a distinguished road
if i've read enough on here ya it will work you will need a new ecu and wire up vtec,and new motor mounts. the tranny i dont know about, but i would get the z6 tranny anyway if your going to swap the hole motor
mintoxik is offline   Reply With Quote
Old 07-18-2008, 05:26 PM   #3
Ride:  95 civic
so if i get a harness from a vtec d16 and a computer from the same d16 vtec engine that will be it..........?
Old 07-19-2008, 01:51 AM   #4
stevennn09's Avatar
Ride:  94 civic Ex
Rep Power: 7 stevennn09 will become famous soon enoughstevennn09 will become famous soon enough
Send a message via AIM to stevennn09 myspace
only thing. the tranny will fit. but if you can you might as well upgrade as long as it's the same as in auto or standard as the current one. if not it might be hard to convert for someone with not alot of knoweldge. i have a z6 in my car and i actually have grown to like it quite a bit.
heavens not a place that you go when you die it's that moment in life when you actually feel alive, so live for the moment now.
stevennn09 is offline   Reply With Quote
Old 07-19-2008, 11:57 AM   #5
stevennn09's Avatar
Ride:  94 civic Ex
i think you can mod the harness to work 4 vtec. i might be wrong though
Old 07-19-2008, 02:56 PM   #6
ambitious...but rubbish
hatukazi's Avatar
Ride:  90 crx Si, LS w/GSR trans.
Rep Power: 16 hatukazi is a jewel in the roughhatukazi is a jewel in the roughhatukazi is a jewel in the roughhatukazi is a jewel in the rough
myspace
if you are getting the engine wiring harness from the D16Z6 engine, everything will plug into your original wiring including the ECU.
some the plugs are tricky to remove but if you take them off the mounts and pull on both sides it helps.
I live my life a quarter mile at a time, thats how far I get before I break down.
hatukazi is offline   Reply With Quote
Old 07-21-2008, 03:30 AM   #7
Blinker Fluid Specialist
Ride:  95 delsol SI
Rep Power: 7 delsol88 is on a distinguished road
myspace
u can use old mounts in the original car. advice on the tranny, assuming both are manuals, if u want better mpg stick with the 1.5 tranny longer gears so you will get better mileage.
delsol88 is offline   Reply With Quote
Old 07-21-2008, 05:15 PM   #8
mintoxik's Avatar
but if not then just wire up vtec its not that hard
Old 07-21-2008, 05:43 PM   #9
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 102 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
All you have to do is either a)run the two wires from your solenoid to your ECU or b) go to www.rywire.com and buy the VTEC wiring harness.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
http://hondaswap.com/members-lounge/...thread-278554/
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Forum Jump
what does it take to make an EF wagon 4wd engine swap work? 949 Civic and CRX - EF 1 03-17-2008 08:15 PM
Honda CRX Del Sol B16a.... Will a B18 engine swap work!?!? Hel CRXDRESOL General Tech and Maintenance 4 03-31-2007 07:44 PM
engine swap, will it work? DA9god Integra 6 01-17-2007 09:33 PM
Engine Work crxjdm34 Engine Building 0 03-30-2003 09:03 PM
Engine Work hondacivicjosh Engine Building 3 03-06-2003 03:59 PM
SEO by vBSEO 3.2.0
 | a SkeyMedia Network site
