Big Joseph
hey i am swapping a b18c1 gsr swap in my coupe and was wondering if it was worth getting a chipped ecu and also where would be a good spot to find someone to do it or to buy one, and also is it easy to make the harness for the VTEC because mine is a dx and does not already habe it,
thanks |
i think its worth it you get a better fuel and ignition curve. and usaully you can find one in a import shop they should have the chips there but you will need a p28 to be able to chip one its the best one to chip. and no its not hard you just have to find which pins on your ecu the vtec wire goes in
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
sending it anywhere without the car doesnt do anything
ever heard of dyno tuning? that's the only way to do it right. stock parts = stock fuel maps. |
#6 |
senior member
Ride: 92 civic coupe
i agree with legal if you want your car done right take it somewhere..i go to my boy wangs tuning in new hampshire hes like the honda god no joke..and as for wireing vtec you need to wire it to your knock sensor and your ecu...better leave that to a pro..no offense..and the easy way to swap is to wire the gr-r all up the drop the motor in and just plug it into the main clips on the side of the engine bay...then do you s/l..axels..exaust nd your done..
#8 |
you dont really need tuning when you get your computer chipped unless its a custom chip or some stand alone system i had a mugen and a spoon chipped ecu with no tuning just got it chipped put it on my car and reved the fuck out of it.. and as for what ecu to chip it is recommmened to use a p28 ( 92-95 civic ex)!! the chip on ebay is like 8 dollars or so and actaully getting chipped is llike 50 so it aint that expensive lol
#10 |
yeah you can run it but the motor is not going to be pulling its full power potential if you dont have a chip on that p28 from what i know you cant chip the p72 i dont know though its easier to chip the p28
#12 | |
chipping it like this changes your stock fuel maps. belive it or not, you lost horsepower. a mugen chip is for a full mugen built motor a spoon chip is for a full spoon built motor dont chip it the cheap/incorrect way. the life of your motor depends on it! btw, mugen and spoon are retuned. and not for YOUR motor. so you DID change the fuel/ignition tables... Last edited by YBLEGAL; 01-24-2008 at 08:02 PM. |
#13 | |
Applications By Engine |
#14 | |
prove all this then stupidass!! the spoon chip has a 8700 rpm redline!! and exactly how do you lose horsepower by changing your stock fuel maps?? how the fuck you gonna have a mugen built motor?? haha your stupid!! have you had a mugen chipped ecu?? |
#15 |
the only difference is that the p28 is a vtec ecu and the dx or po6 is non vtec.. it is easier to chip a p28 though then a p06 hope this helps!! but if anything you can always use a stock gsr and your motor will run good you just have to wire the knock and vtec sensor
#16 | |
yeah hondata is not just a ecu that will run your motor!! its a stand alone engine management system!! that actually requires dynoing and tuning!! cuz its meant to run your motor for power!! |
#17 | |
BOTH chips have air/fuel ratios ment for differnet combinations of parts. different compression. different lift and duration. if you have an otherwise stock motor, yes you are losing power because of it. those fuel maps are not written for a stock motor. get bent. dont call someone a stupid ass because they tell you want you said is wrong. just keep reving your motor, and when it breaks a valve, then you'll learn. |
#18 | |
go home! this isnt Need For Speed Undergound Last edited by YBLEGAL; 01-24-2008 at 08:33 PM. |
#19 |
#20 | |
#21 |
Big Joseph
lol, i appreciate both or yalls help but im confused as a bit** right now, rigth after i do the swap the motor is going to be stock exept for a header and intake, is it best to run the civic ex ecu with a chip then later on when i upgrade the cams retainers valves and springs then epgrade again or what, sorry for the confusion.
#22 |
Big Joseph
and also when wiring the VTEC into either the gsr ecu or the ex ecu i need the VTEC wires i saw on rywire.com that they have a harness for that is that all that i would need
#23 | |
#24 | |
http://hondaswap.com/ecu-s-electroni...93/#post928276 as for fucking up your power. go search the forums. i'm done wasting my time with you ![]() |
#25 | |
you cant just throw some arbitrary fuel maps at a motor and expect it to run better because they're different. later on when you get cams/retainers, that whole bit, thats when you should be looking to shell out the money for a chipping and tune. then you should pick up something more like 20+whp, depending on the parts you choose of course. |
| LS Swap Into 91CRX HF WIRING!!!!!!!!!!!!!!!!!!!!!! | ExclusiveImports | Civic and CRX - EF | 9 | 09-27-2008 09:55 AM |
| 99-00 civic Si cluster swap into EF How To (pics0) | B18C5James | HYBRID -> ED-EF / DA | 30 | 07-11-2007 06:25 PM |
| vtec wiring for a jdm d15b swap? | 92civy | HYBRID -> EG-EK / DC | 1 | 09-07-2006 07:22 PM |
| Free set of VX wheels wiring my swap. GSR into VX | dwnthehatch | HYBRID -> EG-EK / DC | 3 | 08-24-2003 05:15 PM |
| H22a Wiring Harness For My Swap | 300hph22civic | Engine Building | 4 | 02-09-2003 04:13 PM |
