Go Back   HondaSwap Forums > Model Specific > Civic - EP, FA, FG
automatic to 5 speed trany swap
Old 08-21-2009, 07:37 PM   #1
Greenhorn
Rep Power: 0 cejota is on a distinguished road
Default automatic to 5 speed trany swap
i have a d16y7 motor on my 96 civic i did a trany swap from auto to 5 speed now the check eng light is on statin that i have transmision malfunctionin do i have 2 swap the ECU since is stil the auto one and put a 5 speed ECU in it please help my car wont pass inspection because of this issue
cejota is offline   Reply With Quote
Old 08-21-2009, 07:40 PM   #2
Greenhorn
z z z
Old 08-21-2009, 07:42 PM   #3
Greenhorn
anyone plz
Old 08-21-2009, 09:02 PM   #4
Sleepy...
oyy0's Avatar
Ride:  '05 DC5, '93 FD, '85 AE86
Rep Power: 6 oyy0 will become famous soon enoughoyy0 will become famous soon enough
myspace
I have run it both ways, didn't see any difference and the check engine light did not come up once.
What is your transmission doing that makes you think it is malfunctioning?
Did you do the wiring yourself or did you have someone else do it?
Originally Posted by gatto-is-alive View Post
i'm going to install a 5th injector is that good or not?
It ain't broke until you can't fix it no more.
oyy0 is offline   Reply With Quote
Old 08-22-2009, 12:54 AM   #5
Greenhorn
i did not do any wiring on trany most of the plugs from the the auto trany fit the 5 speed it just that auto trany has more plugs than the 5 speed the and check engine light is on i took it 2 get it check out and the code state tha the transmision is malfunctionin
Old 08-22-2009, 01:01 AM   #6
Greenhorn
the transmision is in runin cond no problem at all everythin is ok with motor and trany its just that engine light is on with a malfunction transmision code but the car is ruinin dont now wat it could be
Old 08-22-2009, 05:31 AM   #7
HondaMan
shadyman8's Avatar
Ride:  Civic Ek & EG
Rep Power: 0 shadyman8 is infamous around these partsshadyman8 is infamous around these parts
you need a 5 speed ecu ... the ecu you are using now is for an automatic so it is sending a signal to all of the sensors for an automatic trans and it is not getting a signal back there for it thinks there is somthing the matter get the ecu and you have to drive it for a lil while once you get it so it can run all of its ecu test, then it should pass safty and emissions if no emissions slap it in and get it tested
SHADY
If you think I helped you out leave me some Rep. Thanks
shadyman8 is offline   Reply With Quote
Old 08-22-2009, 08:54 AM   #8
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
This forum is for 2001+ Civics. Next time, use the EG/EK forum please...
PSN Network ID: BrutalB83
Old 08-22-2009, 02:24 PM   #9
Greenhorn
thanks guys i preciated
cable 5 speed trany for a jdm b16 ran great before pull RSS-Bot Auctions 0 03-15-2008 02:53 PM
cable 5 speed trany for a jdm b16 ran great before pull RSS-Bot Auctions 0 03-05-2008 01:53 PM
trany swap sinezter HYBRID -> ED-EF / DA 10 10-12-2007 11:47 AM
automatic to 5 speed swap cornfed85 Civic and CRX - EF 3 06-06-2007 02:04 AM
Trany swap question? 91 Si inzo Prelude 1 11-28-2006 07:57 AM
