Ive got a 99 civic cx hatch with a d15y7 vtec that has almost 400k miles on it. I just bought an OBD2 SOHC VTEC D15B. I was told that this is the 3 stage vtec motor and from the pics I've seen and descriptions I've read it is. I heard that you could wire the vtec so that instead of kicking in the second time it will kick in at the same time as the first. Is this true and if so what needs to be done to do this?
I'm trying to get the swap done this weekend so any help will be greatly appreciated. Thanks for any help you can offer |
Crusher of Noob Ambitions
Ride: 97 Integra LS Coupe
Are you sure it's an OBD2 motor? I wasn't aware that they made that engine in anything other than OBD1. And also, the 3-stage VTEC-E is different than regular VTEC. It's meant to help with fuel economy and it engages much lower in the power-band than standard VTEC. You can't just swap a few wires and make it perform like regular VTEC...
Oh, and you're in the wrong place also...this forum is for questions about 01+ Civics and RSXs...
If you find something I say helpful, please rep it up! Also, DO NOT PM me with tech questions! Use the forums so we can all benefit from the answers. I will NOT respond to tech-related PMs... 97 Integra LS Coupe: *AEM Intake/Megan Header/Magnaflow Exhaust *Tokico Shocks & Springs *Megan Strut Braces & H-Brace *98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys) |
the three stage vtec was a JDM b15b engine in the 96-00 civics. The beauty of these engines is that they can get 55mpg and 130HP.
The problem is that they are OBD 2, and finding a way to control the 2nd and 3rd vtec stages is a bitch. not only are the original p2j(not sure) ecus nearly impossible to find, most of them (80%) are for the CVT transmission. anyway, it would be easiest to convert the engine to obd1, then try to figure out how to get it to work in your car. but if you're gonna just have 2nd and 3rd stages kick in at the same time, you're kinda missing the point of the engine... |
| K series swap | custompainter | HYBRID -> EG-EK / DC | 9 | 03-27-2008 08:59 PM |
| d15b vtec swap | EMFinite | HYBRID -> ED-EF / DA | 4 | 04-29-2007 10:39 PM |
| D15b in 93 civic DX swap engine codes.... | civicswap101tech | HYBRID -> ED-EF / DA | 0 | 04-14-2007 05:41 PM |
| All Swap Info for EF | Riceras | HYBRID -> ED-EF / DA | 2 | 02-07-2005 02:20 PM |
| can i swap parts from a D16 to a D15B | evo8 | HYBRID -> EG-EK / DC | 1 | 01-05-2005 01:48 PM |
