Go Back   HondaSwap Forums > Model Specific > Civic - EP, FA, FG
Mucho Issues :o
Old 06-04-2009, 11:41 AM   #1
SOHC Pocket Rocket
Ride:  civic coupe 1998 1.6 D16Y7
Rep Power: 0 Han_solo1982 is on a distinguished road
Send a message via MSN to Han_solo1982
Exclamation Mucho Issues :o
About 2 years back i did an engine swap in my 1997 civic coupe from a obd2 d16y7 engine into a obd1 d16z6 engine. seems pretty simple now but at the time it proved a problem and with me being (at the time) an uber noob and reading some very bad advice i started chopping away at wired and purchased wiring harnesses and ended up doing something i dont wanna talk about and well ....... lets just say an accident happened and i threw the engine and harness out >.<
alot of stuff happened and well it wasnt pretty. 2 years on i still have the shell of a car and i recently purchased (what i thought ) was a new loom and installed it along with a new engine (d16z6).
Here is my problem. when i fire the engine up it starts and runs but its almost like the engine has a skipping rope and is jumping up and down from 1000-1200 rpm. when she warms up it quickens from 1050-1150. its annoying as hell!!!! :s
here is my predicament i am not sure there is some shorted wire or faulty sensor on the car. i am using a p28 ecu and when i turn the car on it throws code 14 but when i manually test to iacv it makes the normal clicking noise so i am stumped.
was gonna strip the car back and test each wire on the ecu plugs to see if i have a short someplace or something. i just am a lil frustrated as i dont REALLY wanna give up on it as i have now been on this mission for ages yar yar i know... NOOB alert BUT any advice would be really helpfull.
Peace
Han_solo1982 is offline   Reply With Quote
Old 06-04-2009, 11:46 AM   #2
AHHVTEC's Avatar
clean the iac, there should be a little screen inside of it that gets dirty and can make it do that.so unbolt it and have a look
Old 06-04-2009, 11:52 AM   #3
SOHC Pocket Rocket
did that ... used some break cleaner (well i was told to use it so am hoping it ok to use that )
didnt do anything. problem is if it was the iacv then when i manually activated the solinoid on the batery it still makes a clicking noise.
i am thinking after reading some here that it could be a distributor problem. will check that and get back.
~To sum up my life~
Lots of money spend and an engine went BOOM!!!
Old 06-04-2009, 11:55 AM   #4
AHHVTEC's Avatar
yeah but if there is a code 14 then thats a problem too
Old 06-04-2009, 12:06 PM   #5
SOHC Pocket Rocket
k am gonna investigate and report back... sir yes sir!!!
~To sum up my life~
Old 06-04-2009, 01:12 PM   #6
Rep Power: 0 victor carrillo can only hope to improve
hi
i have a 95 civic ex with the d16z6 the ecu that i have is the p28 but my car is only reving is only ta 6500rpm my car doesnt rev to 7200rpm like a suposed to what can my problem be
victor carrillo is offline   Reply With Quote
Old 06-04-2009, 01:16 PM   #7
AHHVTEC's Avatar
Originally Posted by victor carrillo View Post
hi
search button, then if you dont find a answer start your own thread dont jack this one.
Tags
d16z6, ecu fault, wiring
AC issues 90'CivicSi Civic and CRX - EF 3 08-25-2008 10:04 AM
having issues micah Wheels / Suspension / Tires / Brakes 4 05-31-2005 12:28 AM
How mucho 2000Si General Tech and Maintenance 4 04-10-2004 03:51 PM
ZC issues timEspeed HYBRID -> ED-EF / DA 11 11-18-2003 10:09 AM
P28 Ecu Issues Spyderturbo ECU's, Electronics, and Tuning 4 05-16-2003 10:01 PM
