#1 | |
The Riced Sleeper
Ride: 2000 Si w/B18C5-R swap
So I've finally broke down and got me a new laptop w/ Vista, maybe I don't have the patience I'm normally able to figure stuff out like this but I can't seem to create a network between the laptop w/ vista and my desktop w/ xp. Tried doing the basic home network, tried doing the wireless home network to no avail. I can get the cpu's to both connect to the wireless home network but they can't see each other. anyone here had this problem that got it fixed?
![]() :confused :__________________
(True Story) "I built it, I drive it, your opinion doesnt matter. It doesn't have to be JDM it just has to be functional." (2nd part of sig. taken from 89CRXZC)http://racingsouthwest.com/forums/in..._item&CID=1708 |
Administrator
Ride: 318ti, dakota, genesis 2.0t
are they on the same work group?
xp joins "mshome" by default and vista joins "workgroup" (or is it the other way around? i forget?) either way, make sure both are on the same workgroup name. |
Ride: 1991 CRX DX/ Blacktop ZC 5spd Swap
What B said. Plus you gotta make sure the folders you want to access on either machine has the permissions setup correctly.
XBL GT: Churched V2 H3, CoD 4, CoD: WaW, Forza 2, H3: ODST, CoD 4: MW 2 МОΛΏΝ ΛΑΒΈ |
#4 | |
The Riced Sleeper
yep u got it right. I changed the vista to mshome last night but for the life of me I don't even rember how I did it, all folders have permissions set but still no dice
#5 | |
The Riced Sleeper
Aight, I think i'll just dedicate one day to fixing this, when I actually have time. finally got vista to see xp cpu but can't access it. Xp still not seeing vista, getting an error code: 0x80070035-The network path was not found.
#6 | |
SOHC on this!!
Im in the same boat. I just want my printer to work. :cry:
#8 | |
SOHC on this!!
Na, I want a computer in another room to print off of the computer that's actually hooked up. I have to make a network first but one is xp and the other vista.
#9 | |
Neon Owner
Ride: '04 NEON
Sorry to jack the thread here lol... at least my question was sort of on topic. Also, as far as I know, what B said should work just fine. Hope you get it working dude. __________________
I have D16Y7 injectors and fuel rail fo sale. pm me if interested.
#10 |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
your windows firewall is fucking with you.
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
#12 |
some if not most of these solutions have been posted, but forgive me because ill list the steps:
1) have to be sure the computers are on the same network, if not change it and restart computers. 2) ensure the folder(s) or drive(s) have the permissions set. i usually put everyone can read, but not write so that way i dont have to set permissions individually. besides i check my logs on the router everyday to be sure only computers i recongize are issued an ip. 3) turn off windows firewall because its useless. if you need one i recommend using comodo or zonealarm, which both are free and infinitely better than windows. 4) allow file sharing on firewall and open ports if required. if you dont know, search on google or something to see which ports are used. dont remember off hand. 5) enable file and printer sharing if on vista. for printers. install new printer on the computer you want to access via ethernet. choose network printer. browse for it and it should pop up. if not try install basic drivers for the printer first. this helped for an hp printer i had issues with. |
#13 |
Goodness Reflects the Light; And Evil Bares the Seed to all Darkness; These are Mirrors of the Soul; Reflections of the Mind--Choose Well |
| need some help from the civic guru's | ukaccord92 | ECU's, Electronics, and Tuning | 1 | 04-10-2009 12:44 AM |
| CEL guru's please help!!! | 93NOTCH | HYBRID -> EG-EK / DC | 4 | 09-19-2008 05:15 PM |
| I need a CRX wiring GURU's help. | ryangt | HYBRID -> ED-EF / DA | 18 | 01-10-2007 06:33 PM |
| ecu guru's help | preludebuddy | ECU's, Electronics, and Tuning | 0 | 11-17-2006 07:51 PM |
| Need Honda Guru's Help! | MotoXracerfss | HYBRID -> EG-EK / DC | 6 | 11-01-2006 12:31 AM |
