Discuss Swap information, turbo installation, general Honda tech, ecu chipping, and tuning at HondaSwap.com
Members have access to more features and see fewer ads! It's free, what are you waiting for?
HS TECH
Ride: dc5,cr-x,mk4 gti,2nd gen civic,
well when it comes to home computers i have no clue about them, my comp keeps flashing low to no memory and my comp is slow now. what do i need to delete to get things back to normal and to have more memory. as far as i can remember i only have like 3 videos and lots of pictures.
VTEC or NOTEC
Ride: 1990 Intergra GS/XSi
Do you know how much gigabytes of memory you have and RAM?
90 Integra GS/ XSi - JDM B16A SiR2 w/ full exhaust & CAI - Skunk2 stage 1 cams (not installed yet) - J1 Tranny - H & R lowering springs - Rear strut bar and front camber kit - HKS Hi-Power exhaust - Powersteering removed XBL: JustinE66 |
#5 | |
Ride: 2004 Civic EX Coupe
1. delete all the useless shit in the tray
2. open run menu and type msconfig and then go to the startup tab and uncheck anything that looks unfamiliar or that you don't want to run when you boot up 3. go to add/remove programs in the control panel and delete any useless shit that you dont need anymore or dont use 4. download some free spyware program (i suggest ad-aware) and run it 5. defrag your hdd (start > all programs > accessories > system tools > diskeeper disk defragmenter) 6. reboot.
2004 Civic EX - current 2004 Frontier - sold 2004 Civic VP - totaled 1999 Ducati 748S - sold 1997 Accord EX - totaled 1990 Civic Hatch DX - sold 1988 RX-7 AE TII - sold Quote:
#6 | |
HS TECH
#7 | |
you don't want a lot of icons sitting in the "tray," the small box next to the clock in the lower right screen... they just eat up your memory and for the most part are useless. try to right click each icon and see if there is an exit or quit option and try to remove as many as possible
#8 | |
HS TECH
#9 | |
you probably have some spyware thats eating your memory... try those 6 things and if that doesn't work you probably have to reformat
#10 |
Ride: 93 civic cx
i agree with devit start deleteing all the programs you dont use anymore and the games you dont play so on an so forth if you have alot of songs on your computer it will slow it way down too
#11 | |
..is grounded.
Ride: '84 buick (rusted)
you could try disk cleanup which should clear all caches as well. as for ram, 256MB is barely enough to scrape by these days.
#15 |
Ride: 2001 Jeep Cherokee
xubuntu... from the specs on that thing, i doubt you do much more than surf the net and other simple things, right?
http://xubuntu.org/ other than that, you could always pick up a copy of one of those "lite" versions of XP. I always see them on Demonoid. that may be an option if you want to stick w/ windows.
!______ ....................... __ . ___ / ] ] ]\___\,__ ............. _,/ ...\/ .....\_ L--|-|-|---[]|||[]......... _,/ ..................\_ ()_)....()_)---)_)...... / ........................ Last edited by Dustin_m; 07-03-2008 at 03:14 PM. |
#16 |
Applying BoostStuffs
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
why isnt this in the computer forum? deeee
Home of the RPW built 2000 Lancer CC Coupe. - See what is done to the Little EVO5 |
#18 | |
HS TECH
#20 |
HS TECH
haha^^^^ well i done the six steps and it still seems slow. i looked at my drives and there are 2 pie charts the first one, operating system c it says that i have 5.26gb of free space out of a total of 14.6 the second one program files f says 58.8gb of free space out of a total 59.8
#21 |
reformat that biatch and it should be good. 256mb of ram is fine to run XP for what you're doing, but barely.
!______ ....................... __ . ___ / ] ] ]\___\,__ ............. _,/ ...\/ .....\_ L--|-|-|---[]|||[]......... _,/ ..................\_ ()_)....()_)---)_)...... / ........................ |
