Dismember
Ride: Whatever i can get behind the wheel of
Have the l337's hAx0rEd me? (I need a code reader)
I happened to notice a new file folder in my C: (hard drive)
The name of the folder is "6e006e1c029410c635f6d2f79f13a7 "
Inside this folder is a text file called "msxml4-KB927978-enu"
When I open the text file, there is some STRANGE looking code that has me worried. I know nothing about programming, but I know this looks weird, and I certainly didnt put it there.
What is this? Have i been hacked?
=== Verbose logging started: 3/6/2007 3:00:27 Build type: SHIP UNICODE 3.01.4000.2435 Calling process: C:\WINNT\system32\msiexec.exe ===
MSI (c) (BC:3C) [03:00:27:269]: Resetting cached policy values
MSI (c) (BC:3C) [03:00:27:269]: Machine policy value 'Debug' is 0
MSI (c) (BC:3C) [03:00:27:269]: ******* RunEngine:
******* Product: c:\6e006e1c029410c635f6d2f79f13a7\m sxml.msi
******* Action:
******* CommandLine: **********
MSI (c) (BC:3C) [03:00:27:279]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (BC:3C) [03:00:27:279]: Grabbed execution mutex.
MSI (c) (BC:3C) [03:00:27:389]: Cloaking enabled.
MSI (c) (BC:3C) [03:00:27:389]: Attempting to enable all disabled priveleges before calling Install on Server
MSI (c) (BC:3C) [03:00:27:399]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (B0:CC) [03:00:27:409]: Grabbed execution mutex.
MSI (s) (B0:A4) [03:00:27:409]: Resetting cached policy values
MSI (s) (B0:A4) [03:00:27:409]: Machine policy value 'Debug' is 0
MSI (s) (B0:A4) [03:00:27:409]: ******* RunEngine:
******* Action:
MSI (s) (B0:A4) [03:00:27:449]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (B0:A4) [03:00:27:560]: File will have security applied from OpCode.
MSI (s) (B0:A4) [03:00:27:650]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'c:\6e006e1c029410c635f6d2f79f13a7\ msxml.msi' against software restriction policy
MSI (s) (B0:A4) [03:00:27:650]: SOFTWARE RESTRICTION POLICY: c:\6e006e1c029410c635f6d2f79f13a7\m sxml.msi has a digital signature
MSI (s) (B0:A4) [03:00:29:612]: SOFTWARE RESTRICTION POLICY: c:\6e006e1c029410c635f6d2f79f13a7\m sxml.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (B0:A4) [03:00:29:643]: End dialog not enabled
MSI (s) (B0:A4) [03:00:29:653]: Original package ==> c:\6e006e1c029410c635f6d2f79f13a7\m sxml.msi
MSI (s) (B0:A4) [03:00:29:653]: Package we're running from ==> c:\WINNT\Installer\33d31b5.msi
MSI (s) (B0:A4) [03:00:29:723]: APPCOMPAT: looking for appcompat database entry with ProductCode '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'.
MSI (s) (B0:A4) [03:00:29:743]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (B0:A4) [03:00:29:753]: MSCOREE not loaded loading copy from system32
MSI (s) (B0:A4) [03:00:29:983]: Machine policy value 'TransformsSecure' is 0
MSI (s) (B0:A4) [03:00:29:983]: User policy value 'TransformsAtSource' is 0
MSI (s) (B0:A4) [03:00:29:993]: Machine policy value 'DisablePatch' is 0
MSI (s) (B0:A4) [03:00:29:993]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (B0:A4) [03:00:29:993]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (B0:A4) [03:00:30:003]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (B0:A4) [03:00:30:003]: APPCOMPAT: looking for appcompat database entry with ProductCode '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'.
MSI (s) (B0:A4) [03:00:30:003]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (B0:A4) [03:00:30:003]: Transforms are not secure.
MSI (s) (B0:A4) [03:00:30:003]: Command Line: REBOOT=ReallySuppress CURRENTDIRECTORY=c:\6e006e1c029410c 635f6d2f79f13a7 CLIENTUILEVEL=3 CLIENTPROCESSID=2492
MSI (s) (B0:A4) [03:00:30:003]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{2B27DCD9-53FA-4885-B6CD-698623819F4C}'.
MSI (s) (B0:A4) [03:00:30:003]: Product Code passed to Engine.Initialize: ''
MSI (s) (B0:A4) [03:00:30:003]: Product Code from property table before transforms: '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'
MSI (s) (B0:A4) [03:00:30:003]: Product Code from property table after transforms: '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'
MSI (s) (B0:A4) [03:00:30:003]: Product not registered: beginning first-time install
MSI (s) (B0:A4) [03:00:30:003]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (B0:A4) [03:00:30:003]: Entering CMsiConfigurationManager::SetLastUs edSource.
MSI (s) (B0:A4) [03:00:30:003]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (B0:A4) [03:00:30:013]: Adding new sources is allowed.
MSI (s) (B0:A4) [03:00:30:013]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (B0:A4) [03:00:30:013]: Package name extracted from package path: 'msxml.msi'
MSI (s) (B0:A4) [03:00:30:013]: Package to be registered: 'msxml.msi'
MSI (s) (B0:A4) [03:00:30:013]: Note: 1: 2729
MSI (s) (B0:A4) [03:00:30:033]: Note: 1: 2729
MSI (s) (B0:A4) [03:00:30:043]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (B0:A4) [03:00:30:043]: Machine policy value 'DisableMsi' is 0
MSI (s) (B0:A4) [03:00:30:043]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (B0:A4) [03:00:30:043]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (B0:A4) [03:00:30:043]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (s) (B0:A4) [03:00:30:043]: Running product '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}' with elevated privileges: Product is assigned.
MSI (s) (B0:A4) [03:00:30:043]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'.
MSI (s) (B0:A4) [03:00:30:043]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'c:\6e006e1c029410c635f6d2f79f13a7' .
MSI (s) (B0:A4) [03:00:30:043]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.
MSI (s) (B0:A4) [03:00:30:043]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '2492'.
MSI (s) (B0:A4) [03:00:30:043]: TRANSFORMS property is now:
MSI (s) (B0:A4) [03:00:30:043]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (B0:A4) [03:00:30:053]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Application Data
MSI (s) (B0:A4) [03:00:30:053]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Favorites
MSI (s) (B0:A4) [03:00:30:063]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\NetHood
MSI (s) (B0:A4) [03:00:30:073]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\My Documents
MSI (s) (B0:A4) [03:00:30:083]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\PrintHood
MSI (s) (B0:A4) [03:00:30:083]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Recent
MSI (s) (B0:A4) [03:00:30:093]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\SendTo
MSI (s) (B0:A4) [03:00:30:103]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Templates
MSI (s) (B0:A4) [03:00:30:113]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Application Data
MSI (s) (B0:A4) [03:00:30:123]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Local Settings\Application Data
MSI (s) (B0:A4) [03:00:30:123]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\My Documents\My Pictures
MSI (s) (B0:A4) [03:00:30:153]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools
MSI (s) (B0:A4) [03:00:30:163]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Startup
MSI (s) (B0:A4) [03:00:30:173]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs
MSI (s) (B0:A4) [03:00:30:183]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Desktop
MSI (s) (B0:A4) [03:00:30:183]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Start Menu\Programs\Administrative Tools
MSI (s) (B0:A4) [03:00:30:193]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Start Menu\Programs\Startup
MSI (s) (B0:A4) [03:00:30:203]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Start Menu\Programs
MSI (s) (B0:A4) [03:00:30:213]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Start Menu
MSI (s) (B0:A4) [03:00:30:213]: SHELL32::SHGetFolderPath returned: C:\WINNT\system32\config\systemprof ile\Desktop
MSI (s) (B0:A4) [03:00:30:223]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Templates
MSI (s) (B0:A4) [03:00:30:223]: SHELL32::SHGetFolderPath returned: C:\WINNT\Fonts
MSI (s) (B0:A4) [03:00:30:223]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 20
MSI (s) (B0:A4) [03:00:30:233]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (B0:A4) [03:00:30:233]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsof t\MS Setup (ACME)\User Info 3: 2
MSI (s) (B0:A4) [03:00:30:233]: PROPERTY CHANGE: Adding USERNAME property. Its value is ' '.
MSI (s) (B0:A4) [03:00:30:233]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'c:\WINNT\Installer\33d31b5.msi'.
MSI (s) (B0:A4) [03:00:30:233]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'c:\6e006e1c029410c635f6d2f79f13a7\ msxml.msi'.
MSI (s) (B0:A4) [03:00:30:243]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (B0:A4) [03:00:30:243]: Machine policy value 'DisableRollback' is 0
MSI (s) (B0:A4) [03:00:30:243]: User policy value 'DisableRollback' is 0
MSI (s) (B0:A4) [03:00:30:243]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
=== Logging started: 3/6/2007 3:00:30 ===
MSI (s) (B0:A4) [03:00:30:243]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (B0:A4) [03:00:30:243]: Doing action: INSTALL
MSI (s) (B0:A4) [03:00:30:253]: Running ExecuteSequence
MSI (s) (B0:A4) [03:00:30:253]: Doing action: DesktopFolder.4576A2F1_959E_4BCA_94 A9_596523761901
Action start 3:00:30: INSTALL.
MSI (s) (B0:A4) [03:00:30:263]: PROPERTY CHANGE: Adding DesktopFolder.4576A2F1_959E_4BCA_94 A9_596523761901 property. Its value is 'C:\Documents and Settings\All Users\Desktop\'.
Action start 3:00:30: DesktopFolder.4576A2F1_959E_4BCA_94 A9_596523761901.
MSI (s) (B0:A4) [03:00:30:263]: Doing action: ProgramMenuFolder.4576A2F1_959E_4BC A_94A9_596523761901
Action ended 3:00:30: DesktopFolder.4576A2F1_959E_4BCA_94 A9_596523761901. Return value 1.
MSI (s) (B0:A4) [03:00:30:263]: PROPERTY CHANGE: Adding ProgramMenuFolder.4576A2F1_959E_4BC A_94A9_596523761901 property. Its value is 'C:\Documents and Settings\All Users\Start Menu\Programs\'.
Action start 3:00:30: ProgramMenuFolder.4576A2F1_959E_4BC A_94A9_596523761901.
MSI (s) (B0:A4) [03:00:30:263]: Doing action: WindowsFolder.0E9F98FC_A692_A6DF_FF 6B_D6B9ABF34537
Action ended 3:00:30: ProgramMenuFolder.4576A2F1_959E_4BC A_94A9_596523761901. Return value 1.
MSI (s) (B0:A4) [03:00:30:263]: PROPERTY CHANGE: Adding WindowsFolder.0E9F98FC_A692_A6DF_FF 6B_D6B9ABF34537 property. Its value is 'C:\WINNT\'.
Action start 3:00:30: WindowsFolder.0E9F98FC_A692_A6DF_FF 6B_D6B9ABF34537.
MSI (s) (B0:A4) [03:00:30:273]: Doing action: SystemFolder.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537
Action ended 3:00:30: WindowsFolder.0E9F98FC_A692_A6DF_FF 6B_D6B9ABF34537. Return value 1.
MSI (s) (B0:A4) [03:00:30:273]: PROPERTY CHANGE: Adding SystemFolder.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 property. Its value is 'C:\WINNT\system32\'.
Action start 3:00:30: SystemFolder.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537.
MSI (s) (B0:A4) [03:00:30:273]: Doing action: WindowsFolder.DA6654F6_456F_3658_FF 6B_D6B9ABF34537
Action ended 3:00:30: SystemFolder.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537. Return value 1.
MSI (s) (B0:A4) [03:00:30:273]: PROPERTY CHANGE: Adding WindowsFolder.DA6654F6_456F_3658_FF 6B_D6B9ABF34537 property. Its value is 'C:\WINNT\'.
Action start 3:00:30: WindowsFolder.DA6654F6_456F_3658_FF 6B_D6B9ABF34537.
MSI (s) (B0:A4) [03:00:30:273]: Doing action: SystemFolder.DA6654F6_456F_3658_FF6 B_D6B9ABF34537
Action ended 3:00:30: WindowsFolder.DA6654F6_456F_3658_FF 6B_D6B9ABF34537. Return value 1.
MSI (s) (B0:A4) [03:00:30:273]: PROPERTY CHANGE: Adding SystemFolder.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 property. Its value is 'C:\WINNT\system32\'.
Action start 3:00:30: SystemFolder.DA6654F6_456F_3658_FF6 B_D6B9ABF34537.
MSI (s) (B0:A4) [03:00:30:283]: Doing action: WindowsFolder.7B2FCEFF_0F22_B7E1_FF 6B_D6B9ABF34537
Action ended 3:00:30: SystemFolder.DA6654F6_456F_3658_FF6 B_D6B9ABF34537. Return value 1.
MSI (s) (B0:A4) [03:00:30:283]: PROPERTY CHANGE: Adding WindowsFolder.7B2FCEFF_0F22_B7E1_FF 6B_D6B9ABF34537 property. Its value is 'C:\WINNT\'.
Action start 3:00:30: WindowsFolder.7B2FCEFF_0F22_B7E1_FF 6B_D6B9ABF34537.
MSI (s) (B0:A4) [03:00:30:283]: Doing action: SystemFolder.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537
Action ended 3:00:30: WindowsFolder.7B2FCEFF_0F22_B7E1_FF 6B_D6B9ABF34537. Return value 1.
MSI (s) (B0:A4) [03:00:30:283]: PROPERTY CHANGE: Adding SystemFolder.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 property. Its value is 'C:\WINNT\system32\'.
Action start 3:00:30: SystemFolder.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537.
MSI (s) (B0:A4) [03:00:30:283]: Doing action: SystemFolder.FA0F135B_0C6B_485B_9A2 7_5A4A5044D5AB
Action ended 3:00:30: SystemFolder.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537. Return value 1.
MSI (s) (B0:A4) [03:00:30:293]: PROPERTY CHANGE: Adding SystemFolder.FA0F135B_0C6B_485B_9A2 7_5A4A5044D5AB property. Its value is 'C:\WINNT\system32\'.
Action start 3:00:30: SystemFolder.FA0F135B_0C6B_485B_9A2 7_5A4A5044D5AB.
MSI (s) (B0:A4) [03:00:30:293]: Doing action: SystemFolder.781A0624_31FF_4712_BFF D_31C829FFDBF1
Action ended 3:00:30: SystemFolder.FA0F135B_0C6B_485B_9A2 7_5A4A5044D5AB. Return value 1.
MSI (s) (B0:A4) [03:00:30:293]: PROPERTY CHANGE: Adding SystemFolder.781A0624_31FF_4712_BFF D_31C829FFDBF1 property. Its value is 'C:\WINNT\system32\'.
Action start 3:00:30: SystemFolder.781A0624_31FF_4712_BFF D_31C829FFDBF1.
MSI (s) (B0:A4) [03:00:30:293]: Doing action: SystemFolder.246EB7AD_459A_4FA8_83D 1_41A46D7634B7
Action ended 3:00:30: SystemFolder.781A0624_31FF_4712_BFF D_31C829FFDBF1. Return value 1.
MSI (s) (B0:A4) [03:00:30:293]: PROPERTY CHANGE: Adding SystemFolder.246EB7AD_459A_4FA8_83D 1_41A46D7634B7 property. Its value is 'C:\WINNT\system32\'.
Action start 3:00:30: SystemFolder.246EB7AD_459A_4FA8_83D 1_41A46D7634B7.
MSI (s) (B0:A4) [03:00:30:293]: Doing action: LaunchConditions
Action ended 3:00:30: SystemFolder.246EB7AD_459A_4FA8_83D 1_41A46D7634B7. Return value 1.
Action start 3:00:30: LaunchConditions.
MSI (s) (B0:A4) [03:00:30:303]: Doing action: FindRelatedProducts
Action ended 3:00:30: LaunchConditions. Return value 1.
Action start 3:00:30: FindRelatedProducts.
MSI (s) (B0:A4) [03:00:30:303]: Doing action: AppSearch
Action ended 3:00:30: FindRelatedProducts. Return value 1.
Action start 3:00:30: AppSearch.
MSI (s) (B0:A4) [03:00:30:314]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (B0:A4) [03:00:30:314]: PROPERTY CHANGE: Adding WINHTTP_51 property. Its value is 'WinHttpRequest Component version 5.1'.
MSI (s) (B0:A4) [03:00:30:314]: Skipping action: CCPSearch (condition is false)
MSI (s) (B0:A4) [03:00:30:314]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (B0:A4) [03:00:30:314]: Doing action: ValidateProductID
Action ended 3:00:30: AppSearch. Return value 1.
Action start 3:00:30: ValidateProductID.
MSI (s) (B0:A4) [03:00:30:314]: Doing action: CostInitialize
Action ended 3:00:30: ValidateProductID. Return value 1.
MSI (s) (B0:A4) [03:00:30:324]: Machine policy value 'MaxPatchCacheSize' is 10
Action start 3:00:30: CostInitialize.
MSI (s) (B0:A4) [03:00:30:344]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'c:\'.
MSI (s) (B0:A4) [03:00:30:344]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (B0:A4) [03:00:30:344]: Note: 1: 2205 2: 3: Patch
MSI (s) (B0:A4) [03:00:30:344]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (B0:A4) [03:00:30:344]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (B0:A4) [03:00:30:344]: Note: 1: 2205 2: 3: __MsiPatchFileList
MSI (s) (B0:A4) [03:00:30:354]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (B0:A4) [03:00:30:354]: Note: 1: 2228 2: 3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Me dia_` ORDER BY `DiskId`
MSI (s) (B0:A4) [03:00:30:354]: Doing action: FileCost
Action ended 3:00:30: CostInitialize. Return value 1.
MSI (s) (B0:A4) [03:00:30:354]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:30: FileCost.
MSI (s) (B0:A4) [03:00:30:354]: Doing action: CostFinalize
Action ended 3:00:30: FileCost. Return value 1.
MSI (s) (B0:A4) [03:00:30:354]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (B0:A4) [03:00:30:354]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (B0:A4) [03:00:30:354]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (B0:A4) [03:00:30:354]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (B0:A4) [03:00:30:354]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'c:\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Modifying WindowsFolder property. Its current value is 'C:\WINNT\'. Its new value: 'c:\WINNT\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Modifying CommonFilesFolder property. Its current value is 'C:\Program Files\Common Files\'. Its new value: 'c:\Program Files\Common Files\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding MicrosoftShared.3FB7DAB3_19E7_40A0_ 8730_4482CE77AC59 property. Its value is 'c:\Program Files\Common Files\Microsoft Shared\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding MSDN.3FB7DAB3_19E7_40A0_8730_4482CE 77AC59 property. Its value is 'c:\Program Files\Common Files\Microsoft Shared\MSDN\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Modifying WindowsFolder.0E9F98FC_A692_A6DF_FF 6B_D6B9ABF34537 property. Its current value is 'C:\WINNT\'. Its new value: 'c:\WINNT\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Modifying SystemFolder.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 property. Its current value is 'C:\WINNT\system32\'. Its new value: 'c:\WINNT\system32\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding WinSxsDirectory.0E9F98FC_A692_A6DF_ FF6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding policydir_ul.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_policy.4.20.Mi crosoft.MSXML2_6bd6b9abf345378f_4.2 0.9841.0_x-ww_ff05e224\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding payload.0E9F98FC_A692_A6DF_FF6B_D6B 9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_policy.4.20.Mi crosoft.MSXML2_6bd6b9abf345378f_4.2 0.9841.0_x-ww_ff05e224\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding WinSxsManifests.0E9F98FC_A692_A6DF_ FF6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Manifests\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding WinSxsPolicies.0E9F98FC_A692_A6DF_F F6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Policies\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding policydir.0E9F98FC_A692_A6DF_FF6B_D 6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Policies\x86_polic y.4.20.Microsoft.MSXML2_6bd6b9abf34 5378f_x-ww_88e8eab8\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding payload_ul.0E9F98FC_A692_A6DF_FF6B_ D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_policy.4.20.mi crosoft.msxml2_6bd6b9abf345378f_4.2 0.9841.0_none_a6dfa6920e9f98fc\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Modifying WindowsFolder.DA6654F6_456F_3658_FF 6B_D6B9ABF34537 property. Its current value is 'C:\WINNT\'. Its new value: 'c:\WINNT\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Modifying SystemFolder.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 property. Its current value is 'C:\WINNT\system32\'. Its new value: 'c:\WINNT\system32\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding WinSxsDirectory.DA6654F6_456F_3658_ FF6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding policydir_ul.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_Microsoft.MSXM L2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding WinSxsPolicies.DA6654F6_456F_3658_F F6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Policies\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding policydir.DA6654F6_456F_3658_FF6B_D 6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Policies\x86_Micro soft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding WinSxsManifests.DA6654F6_456F_3658_ FF6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Manifests\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding payload.DA6654F6_456F_3658_FF6B_D6B 9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_Microsoft.MSXM L2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding payload_ul.DA6654F6_456F_3658_FF6B_ D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_microsoft.msxm l2r_6bd6b9abf345378f_4.1.0.0_none_3 658456fda6654f6\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Modifying WindowsFolder.7B2FCEFF_0F22_B7E1_FF 6B_D6B9ABF34537 property. Its current value is 'C:\WINNT\'. Its new value: 'c:\WINNT\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Modifying SystemFolder.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 property. Its current value is 'C:\WINNT\system32\'. Its new value: 'c:\WINNT\system32\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding WinSxsDirectory.7B2FCEFF_0F22_B7E1_ FF6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding policydir_ul.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_Microsoft.MSXM L2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\'.
MSI (s) (B0:A4) [03:00:30:364]: PROPERTY CHANGE: Adding WinSxsPolicies.7B2FCEFF_0F22_B7E1_F F6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Policies\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding policydir.7B2FCEFF_0F22_B7E1_FF6B_D 6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Policies\x86_Micro soft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding WinSxsManifests.7B2FCEFF_0F22_B7E1_ FF6B_D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\Manifests\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding payload.7B2FCEFF_0F22_B7E1_FF6B_D6B 9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_Microsoft.MSXM L2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding payload_ul.7B2FCEFF_0F22_B7E1_FF6B_ D6B9ABF34537 property. Its value is 'c:\WINNT\winsxs\x86_microsoft.msxm l2_6bd6b9abf345378f_4.20.9841.0_non e_b7e10f227b2fceff\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Modifying SystemFolder.FA0F135B_0C6B_485B_9A2 7_5A4A5044D5AB property. Its current value is 'C:\WINNT\system32\'. Its new value: 'c:\WINNT\system32\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Modifying SystemFolder.781A0624_31FF_4712_BFF D_31C829FFDBF1 property. Its current value is 'C:\WINNT\system32\'. Its new value: 'c:\WINNT\system32\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Modifying SystemFolder.246EB7AD_459A_4FA8_83D 1_41A46D7634B7 property. Its current value is 'C:\WINNT\system32\'. Its new value: 'c:\WINNT\system32\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Modifying DesktopFolder property. Its current value is 'C:\Documents and Settings\All Users\Desktop\'. Its new value: 'c:\Documents and Settings\All Users\Desktop\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Modifying ProgramFilesFolder property. Its current value is 'C:\Program Files\'. Its new value: 'c:\Program Files\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding MSXML property. Its value is 'c:\Program Files\MSXML 4.0\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding INC.4576A2F1_959E_4BCA_94A9_5965237 61901 property. Its value is 'c:\Program Files\MSXML 4.0\inc\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding LIB.4576A2F1_959E_4BCA_94A9_5965237 61901 property. Its value is 'c:\Program Files\MSXML 4.0\lib\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding DOC.4576A2F1_959E_4BCA_94A9_5965237 61901 property. Its value is 'c:\Program Files\MSXML 4.0\doc\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Modifying ProgramMenuFolder.4576A2F1_959E_4BC A_94A9_596523761901 property. Its current value is 'C:\Documents and Settings\All Users\Start Menu\Programs\'. Its new value: 'c:\Documents and Settings\All Users\Start Menu\Programs\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Adding MenuMSXML.4576A2F1_959E_4BCA_94A9_5 96523761901 property. Its value is 'c:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\'.
MSI (s) (B0:A4) [03:00:30:374]: PROPERTY CHANGE: Modifying DesktopFolder.4576A2F1_959E_4BCA_94 A9_596523761901 property. Its current value is 'C:\Documents and Settings\All Users\Desktop\'. Its new value: 'c:\Documents and Settings\All Users\Desktop\'.
MSI (s) (B0:A4) [03:00:30:374]: Target path resolution complete. Dumping Directory table...
MSI (s) (B0:A4) [03:00:30:374]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: TARGETDIR , Object: c:\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WindowsFolder , Object: c:\WINNT\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: CommonFilesFolder , Object: c:\Program Files\Common Files\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: MicrosoftShared.3FB7DAB3_19E7_40A0_ 8730_4482CE77AC59 , Object: c:\Program Files\Common Files\Microsoft Shared\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: MSDN.3FB7DAB3_19E7_40A0_8730_4482CE 77AC59 , Object: c:\Program Files\Common Files\Microsoft Shared\MSDN\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WindowsFolder.0E9F98FC_A692_A6DF_FF 6B_D6B9ABF34537 , Object: c:\WINNT\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: SystemFolder.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 , Object: c:\WINNT\system32\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsDirectory.0E9F98FC_A692_A6DF_ FF6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: policydir_ul.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 , Object: c:\WINNT\winsxs\x86_policy.4.20.Mic rosoft.MSXML2_6bd6b9abf345378f_4.20 .9841.0_x-ww_ff05e224\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: payload.0E9F98FC_A692_A6DF_FF6B_D6B 9ABF34537 , Object: c:\WINNT\winsxs\x86_policy.4.20.Mic rosoft.MSXML2_6bd6b9abf345378f_4.20 .9841.0_x-ww_ff05e224\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsManifests.0E9F98FC_A692_A6DF_ FF6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\Manifests\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsPolicies.0E9F98FC_A692_A6DF_F F6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\Policies\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: policydir.0E9F98FC_A692_A6DF_FF6B_D 6B9ABF34537 , Object: c:\WINNT\winsxs\Policies\x86_policy .4.20.Microsoft.MSXML2_6bd6b9abf345 378f_x-ww_88e8eab8\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: payload_ul.0E9F98FC_A692_A6DF_FF6B_ D6B9ABF34537 , Object: c:\WINNT\winsxs\x86_policy.4.20.mic rosoft.msxml2_6bd6b9abf345378f_4.20 .9841.0_none_a6dfa6920e9f98fc\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WindowsFolder.DA6654F6_456F_3658_FF 6B_D6B9ABF34537 , Object: c:\WINNT\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: SystemFolder.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 , Object: c:\WINNT\system32\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsDirectory.DA6654F6_456F_3658_ FF6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: policydir_ul.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 , Object: c:\WINNT\winsxs\x86_Microsoft.MSXML 2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsPolicies.DA6654F6_456F_3658_F F6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\Policies\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: policydir.DA6654F6_456F_3658_FF6B_D 6B9ABF34537 , Object: c:\WINNT\winsxs\Policies\x86_Micros oft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsManifests.DA6654F6_456F_3658_ FF6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\Manifests\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: payload.DA6654F6_456F_3658_FF6B_D6B 9ABF34537 , Object: c:\WINNT\winsxs\x86_Microsoft.MSXML 2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: payload_ul.DA6654F6_456F_3658_FF6B_ D6B9ABF34537 , Object: c:\WINNT\winsxs\x86_microsoft.msxml 2r_6bd6b9abf345378f_4.1.0.0_none_36 58456fda6654f6\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WindowsFolder.7B2FCEFF_0F22_B7E1_FF 6B_D6B9ABF34537 , Object: c:\WINNT\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: SystemFolder.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 , Object: c:\WINNT\system32\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsDirectory.7B2FCEFF_0F22_B7E1_ FF6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: policydir_ul.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 , Object: c:\WINNT\winsxs\x86_Microsoft.MSXML 2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsPolicies.7B2FCEFF_0F22_B7E1_F F6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\Policies\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: policydir.7B2FCEFF_0F22_B7E1_FF6B_D 6B9ABF34537 , Object: c:\WINNT\winsxs\Policies\x86_Micros oft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: WinSxsManifests.7B2FCEFF_0F22_B7E1_ FF6B_D6B9ABF34537 , Object: c:\WINNT\winsxs\Manifests\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: payload.7B2FCEFF_0F22_B7E1_FF6B_D6B 9ABF34537 , Object: c:\WINNT\winsxs\x86_Microsoft.MSXML 2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: payload_ul.7B2FCEFF_0F22_B7E1_FF6B_ D6B9ABF34537 , Object: c:\WINNT\winsxs\x86_microsoft.msxml 2_6bd6b9abf345378f_4.20.9841.0_none _b7e10f227b2fceff\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: SystemFolder.FA0F135B_0C6B_485B_9A2 7_5A4A5044D5AB , Object: c:\WINNT\system32\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: SystemFolder.781A0624_31FF_4712_BFF D_31C829FFDBF1 , Object: c:\WINNT\system32\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: SystemFolder.246EB7AD_459A_4FA8_83D 1_41A46D7634B7 , Object: c:\WINNT\system32\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: DesktopFolder , Object: c:\Documents and Settings\All Users\Desktop\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: ProgramFilesFolder , Object: c:\Program Files\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: MSXML , Object: c:\Program Files\MSXML 4.0\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: INC.4576A2F1_959E_4BCA_94A9_5965237 61901 , Object: c:\Program Files\MSXML 4.0\inc\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: LIB.4576A2F1_959E_4BCA_94A9_5965237 61901 , Object: c:\Program Files\MSXML 4.0\lib\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: DOC.4576A2F1_959E_4BCA_94A9_5965237 61901 , Object: c:\Program Files\MSXML 4.0\doc\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: ProgramMenuFolder.4576A2F1_959E_4BC A_94A9_596523761901 , Object: c:\Documents and Settings\All Users\Start Menu\Programs\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: MenuMSXML.4576A2F1_959E_4BCA_94A9_5 96523761901 , Object: c:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\
MSI (s) (B0:A4) [03:00:30:374]: Dir (target): Key: DesktopFolder.4576A2F1_959E_4BCA_94 A9_596523761901 , Object: c:\Documents and Settings\All Users\Desktop\
Action start 3:00:30: CostFinalize.
MSI (s) (B0:A4) [03:00:30:514]: Doing action: SetODBCFolders
Action ended 3:00:30: CostFinalize. Return value 1.
MSI (s) (B0:A4) [03:00:30:514]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (B0:A4) [03:00:30:514]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Direct ory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (B0:A4) [03:00:30:514]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (B0:A4) [03:00:30:514]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Direct ory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action start 3:00:30: SetODBCFolders.
MSI (s) (B0:A4) [03:00:30:514]: Doing action: MigrateFeatureStates
Action ended 3:00:30: SetODBCFolders. Return value 0.
Action start 3:00:30: MigrateFeatureStates.
MSI (s) (B0:A4) [03:00:30:524]: Doing action: InstallValidate
Action ended 3:00:30: MigrateFeatureStates. Return value 0.
MSI (s) (B0:A4) [03:00:30:524]: Feature: MSXML; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Feature: MSXMLSYS; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Feature: MSXMLSUPP; Installed: Absent; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Feature: MSXMLSUPP2; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Feature: MSXMLSXS; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Feature: XMLSDK; Installed: Absent; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: RememberInstallFolder; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: QKBKEY; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: MSXML4_System.246EB7AD_459A_4FA8_83 D1_41A46D7634B7; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: MSXML4_SystemRes.246EB7AD_459A_4FA8 _83D1_41A46D7634B7; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: MSXML4_ANSI.246EB7AD_459A_4FA8_83D1 _41A46D7634B7; Installed: Absent; Request: Local; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: WINHTTP50_COMPONENT.781A0624_31FF_4 712_BFFD_31C829FFDBF1; Installed: Absent; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: PROXYCFG_COMPONENT.FA0F135B_0C6B_48 5B_9A27_5A4A5044D5AB; Installed: Absent; Request: Local; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: uplevel.7B2FCEFF_0F22_B7E1_FF6B_D6B 9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: downlevel_manifest.7B2FCEFF_0F22_B7 E1_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: downlevel_payload.7B2FCEFF_0F22_B7E 1_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: uplevel.DA6654F6_456F_3658_FF6B_D6B 9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: downlevel_manifest.DA6654F6_456F_36 58_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: downlevel_payload.DA6654F6_456F_365 8_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: uplevel.0E9F98FC_A692_A6DF_FF6B_D6B 9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: downlevel_manifest.0E9F98FC_A692_A6 DF_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: XMLSDK_Docs.4576A2F1_959E_4BCA_94A9 _596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: XMLSDK_LIB.4576A2F1_959E_4BCA_94A9_ 596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: XMLSDK_INC.4576A2F1_959E_4BCA_94A9_ 596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: CookDoc_dll.3FB7DAB3_19E7_40A0_8730 _4482CE77AC59; Installed: Absent; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: __uplevel.7B2FCEFF_0F22_B7E1_FF6B_D 6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: __uplevel.DA6654F6_456F_3658_FF6B_D 6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: __uplevel.0E9F98FC_A692_A6DF_FF6B_D 6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: __QKBKEY65; Installed: Null; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: __MSXML4_System.246EB7AD_459A_4FA8_ 83D1_4165; Installed: Null; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: __downlevel_payload.7B2FCEFF_0F22_B 7E1_FF665; Installed: Null; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: __downlevel_manifest.7B2FCEFF_0F22_ B7E1_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: __downlevel_payload.DA6654F6_456F_3 658_FF665; Installed: Null; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: __downlevel_manifest.DA6654F6_456F_ 3658_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: __downlevel_manifest.0E9F98FC_A692_ A6DF_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (B0:A4) [03:00:30:524]: Component: __CookDoc_dll.3FB7DAB3_19E7_40A0_87 30_448265; Installed: Null; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Component: __XMLSDK_Docs.4576A2F1_959E_4BCA_94 A9_596565; Installed: Null; Request: Null; Action: Null
MSI (s) (B0:A4) [03:00:30:524]: Note: 1: 2205 2: 3: BindImage
MSI (s) (B0:A4) [03:00:30:524]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (s) (B0:A4) [03:00:30:524]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (B0:A4) [03:00:30:524]: Note: 1: 2205 2: 3: Font
Action start 3:00:30: InstallValidate.
MSI (s) (B0:A4) [03:00:30:554]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (s) (B0:A4) [03:00:30:954]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (B0:A4) [03:00:30:964]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (B0:A4) [03:00:30:964]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (B0:A4) [03:00:30:964]: Note: 1: 2205 2: 3: BindImage
MSI (s) (B0:A4) [03:00:30:964]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (s) (B0:A4) [03:00:30:964]: Note: 1: 2205 2: 3: Font
MSI (s) (B0:A4) [03:00:30:964]: Note: 1: 2727 2:
MSI (s) (B0:A4) [03:00:30:974]: Note: 1: 2727 2:
MSI (s) (B0:A4) [03:00:30:974]: Doing action: InstallInitialize
Action ended 3:00:30: InstallValidate. Return value 1.
MSI (s) (B0:A4) [03:00:30:974]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (B0:A4) [03:00:30:974]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (B0:A4) [03:00:30:974]: BeginTransaction: Locking Server
MSI (s) (B0:A4) [03:00:30:974]: SRSetRestorePoint skipped for this transaction.
MSI (s) (B0:A4) [03:00:30:974]: Server not locked: locking for product {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Action start 3:00:30: InstallInitialize.
MSI (s) (B0:A4) [03:00:31:836]: Doing action: SxsInstallCA
Action ended 3:00:31: InstallInitialize. Return value 1.
MSI (s) (B0:F4) [03:00:31:886]: Invoking remote custom action. DLL: C:\WINNT\Installer\MSIB5.tmp, Entrypoint: CustomAction_SxsMsmInstall
MSI (s) (B0:80) [03:00:31:886]: Generating random cookie.
MSI (s) (B0:80) [03:00:31:926]: Created Custom Action Server with PID 2304 (0x900).
MSI (s) (B0:EC) [03:00:32:066]: Running as a service.
MSI (s) (B0:EC) [03:00:32:066]: Hello, I'm your 32bit Elevated custom action server.
Action start 3:00:31: SxsInstallCA.
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1306 4: 0
1: sxsdelca 2: traceop 3: 1307 4: 0
1: sxsdelca 2: traceop 3: 796 4: 0
1: sxsdelca 2: traceop 3: 801 4: 0
1: sxsdelca 2: traceop 3: 802 4: 0
1: sxsdelca 2: traceop 3: 803 4: 0
1: sxsdelca 2: traceop 3: 805 4: 0
1: sxsdelca 2: traceop 3: 812 4: 0
1: sxsdelca 2: traceop 3: 813 4: 0
1: sxsdelca 2: traceop 3: 814 4: 0
1: sxsdelca 2: traceop 3: 819 4: 0
1: sxsdelca 2: traceop 3: 820 4: 0
1: sxsdelca 2: traceop 3: 821 4: 0
1: sxsdelca 2: traceop 3: 827 4: 0
1: sxsdelca 2: traceop 3: 831 4: 0
1: sxsdelca 2: traceop 3: 827 4: 259
1: sxsdelca 2: traceop 3: 1311 4: 0
1: sxsdelca 2: traceop 3: 1312 4: 0
1: sxsdelca 2: traceop 3: 1077 4: 0
1: sxsdelca 2: traceop 3: 1081 4: 0
1: sxsdelca 2: traceop 3: 1083 4: 0
1: sxsdelca 2: traceop 3: 1087 4: 0
1: sxsdelca 2: traceop 3: 1093 4: 0
1: sxsdelca 2: traceop 3: 1097 4: 0
1: sxsdelca 2: traceop 3: 1101 4: 0
1: sxsdelca 2: traceop 3: 1105 4: 0
1: sxsdelca 2: traceop 3: 1109 4: 0
1: sxsdelca 2: traceop 3: 1113 4: 0
1: sxsdelca 2: traceop 3: 1117 4: 0
1: sxsdelca 2: traceop 3: 1121 4: 0
1: sxsdelca 2: traceop 3: 1313 4: 0
1: sxsdelca 2: traceop 3: 1314 4: 0
1: sxsdelca: Added reg value for 2: downlevel_manifest.7B2FCEFF_0F22_B7 E1_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_payload.7B2FCEFF_0F22_B7E 1_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_manifest.DA6654F6_456F_36 58_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_payload.DA6654F6_456F_365 8_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_manifest.0E9F98FC_A692_A6 DF_FF6B_D6B9ABF34537
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
MSI (s) (B0:A4) [03:00:32:356]: Doing action: AllocateRegistrySpace
Action ended 3:00:32: SxsInstallCA. Return value 1.
Action start 3:00:32: AllocateRegistrySpace.
MSI (s) (B0:A4) [03:00:32:397]: Doing action: ProcessComponents
Action ended 3:00:32: AllocateRegistrySpace. Return value 1.
MSI (s) (B0:A4) [03:00:32:397]: Note: 1: 2205 2: 3: MsiPatchCertificate
MSI (s) (B0:A4) [03:00:32:397]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (B0:A4) [03:00:32:397]: Resolving source.
MSI (s) (B0:A4) [03:00:32:397]: Resolving source to launched-from source.
MSI (s) (B0:A4) [03:00:32:397]: Setting launched-from source as last-used.
MSI (s) (B0:A4) [03:00:32:397]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'c:\6e006e1c029410c635f6d2f79f13a7\ '.
MSI (s) (B0:A4) [03:00:32:397]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'c:\6e006e1c029410c635f6d2f79f13a7\ '.
MSI (s) (B0:A4) [03:00:32:397]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'.
MSI (s) (B0:A4) [03:00:32:397]: SOURCEDIR ==> c:\6e006e1c029410c635f6d2f79f13a7\
MSI (s) (B0:A4) [03:00:32:397]: SOURCEDIR product ==> {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
MSI (s) (B0:A4) [03:00:32:397]: Determining source type
MSI (s) (B0:A4) [03:00:32:397]: Source type from package 'msxml.msi': 2
Action start 3:00:32: ProcessComponents.
MSI (s) (B0:A4) [03:00:32:397]: Source path resolution complete. Dumping Directory table...
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: TARGETDIR , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WindowsFolder , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: CommonFilesFolder , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: MicrosoftShared.3FB7DAB3_19E7_40A0_ 8730_4482CE77AC59 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Microsoft Shared\ , ShortSubPath: MICROS~1\
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: MSDN.3FB7DAB3_19E7_40A0_8730_4482CE 77AC59 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Microsoft Shared\MSDN\ , ShortSubPath: MICROS~1\MSDN\
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WindowsFolder.0E9F98FC_A692_A6DF_FF 6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: SystemFolder.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsDirectory.0E9F98FC_A692_A6DF_ FF6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: policydir_ul.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\k0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: payload.0E9F98FC_A692_A6DF_FF6B_D6B 9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\h0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsManifests.0E9F98FC_A692_A6DF_ FF6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsPolicies.0E9F98FC_A692_A6DF_F F6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: policydir.0E9F98FC_A692_A6DF_FF6B_D 6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Policies\i0r1wg7y.dq e\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: payload_ul.0E9F98FC_A692_A6DF_FF6B_ D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\j0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WindowsFolder.DA6654F6_456F_3658_FF 6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: SystemFolder.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsDirectory.DA6654F6_456F_3658_ FF6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: policydir_ul.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\8n0mtfut.k85\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsPolicies.DA6654F6_456F_3658_F F6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: policydir.DA6654F6_456F_3658_FF6B_D 6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Policies\6n0mtfut.k8 5\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsManifests.DA6654F6_456F_3658_ FF6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: payload.DA6654F6_456F_3658_FF6B_D6B 9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\5n0mtfut.k85\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: payload_ul.DA6654F6_456F_3658_FF6B_ D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\7n0mtfut.k85\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WindowsFolder.7B2FCEFF_0F22_B7E1_FF 6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: SystemFolder.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsDirectory.7B2FCEFF_0F22_B7E1_ FF6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: policydir_ul.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\wl34x2va.rt8\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsPolicies.7B2FCEFF_0F22_B7E1_F F6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: policydir.7B2FCEFF_0F22_B7E1_FF6B_D 6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Policies\ul34x2va.rt 8\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: WinSxsManifests.7B2FCEFF_0F22_B7E1_ FF6B_D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: payload.7B2FCEFF_0F22_B7E1_FF6B_D6B 9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\tl34x2va.rt8\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: payload_ul.7B2FCEFF_0F22_B7E1_FF6B_ D6B9ABF34537 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: Windows\winsxs\vl34x2va.rt8\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: SystemFolder.FA0F135B_0C6B_485B_9A2 7_5A4A5044D5AB , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: SystemFolder.781A0624_31FF_4712_BFF D_31C829FFDBF1 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: SystemFolder.246EB7AD_459A_4FA8_83D 1_41A46D7634B7 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: System\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: DesktopFolder , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: ProgramFilesFolder , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: MSXML , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: INC.4576A2F1_959E_4BCA_94A9_5965237 61901 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: redist\inc\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: LIB.4576A2F1_959E_4BCA_94A9_5965237 61901 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: redist\lib\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: DOC.4576A2F1_959E_4BCA_94A9_5965237 61901 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: redist\doc\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: ProgramMenuFolder.4576A2F1_959E_4BC A_94A9_596523761901 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: MenuMSXML.4576A2F1_959E_4BCA_94A9_5 96523761901 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: redist\MSXML 4.0\ , ShortSubPath: redist\MSXML4\
MSI (s) (B0:A4) [03:00:32:397]: Dir (source): Key: DesktopFolder.4576A2F1_959E_4BCA_94 A9_596523761901 , Object: c:\6e006e1c029410c635f6d2f79f13a7\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (B0:A4) [03:00:32:407]: Doing action: UnpublishComponents
Action ended 3:00:32: ProcessComponents. Return value 1.
MSI (s) (B0:A4) [03:00:32:407]: Note: 1: 2262 2: PublishComponent 3: -2147287038
Action start 3:00:32: UnpublishComponents.
MSI (s) (B0:A4) [03:00:32:407]: Doing action: MsiUnpublishAssemblies
Action ended 3:00:32: UnpublishComponents. Return value 1.
Action start 3:00:32: MsiUnpublishAssemblies.
MSI (s) (B0:A4) [03:00:32:407]: Doing action: UnpublishFeatures
Action ended 3:00:32: MsiUnpublishAssemblies. Return value 1.
Action start 3:00:32: UnpublishFeatures.
MSI (s) (B0:A4) [03:00:32:407]: Doing action: StopServices
Action ended 3:00:32: UnpublishFeatures. Return value 1.
MSI (s) (B0:A4) [03:00:32:407]: Note: 1: 2205 2: 3: ServiceControl
MSI (s) (B0:A4) [03:00:32:407]: Note: 1: 2228 2: 3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 3:00:32: StopServices.
MSI (s) (B0:A4) [03:00:32:407]: Doing action: DeleteServices
Action ended 3:00:32: StopServices. Return value 1.
Action start 3:00:32: DeleteServices.
MSI (s) (B0:A4) [03:00:32:407]: Doing action: UnregisterComPlus
Action ended 3:00:32: DeleteServices. Return value 1.
MSI (s) (B0:A4) [03:00:32:407]: Note: 1: 2205 2: 3: Complus
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2228 2: 3: Complus 4: SELECT `ComponentId`, `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed` FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action start 3:00:32: UnregisterComPlus.
MSI (s) (B0:A4) [03:00:32:417]: Doing action: SelfUnregModules
Action ended 3:00:32: UnregisterComPlus. Return value 0.
Action start 3:00:32: SelfUnregModules.
MSI (s) (B0:A4) [03:00:32:417]: Doing action: UnregisterTypeLibraries
Action ended 3:00:32: SelfUnregModules. Return value 1.
Action start 3:00:32: UnregisterTypeLibraries.
MSI (s) (B0:A4) [03:00:32:417]: Doing action: RemoveODBC
Action ended 3:00:32: UnregisterTypeLibraries. Return value 1.
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2205 2: 3: ODBCDataSource
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2228 2: 3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverD escription`,`Description`,`Registra tion` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `Translator`,`ComponentId`,`Descrip tion`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description `, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2711 2: ODBCDriverManager
Action start 3:00:32: RemoveODBC.
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (B0:A4) [03:00:32:417]: Doing action: UnregisterFonts
Action ended 3:00:32: RemoveODBC. Return value 1.
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2205 2: 3: Font
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2228 2: 3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action start 3:00:32: UnregisterFonts.
MSI (s) (B0:A4) [03:00:32:417]: Doing action: RemoveRegistryValues
Action ended 3:00:32: UnregisterFonts. Return value 1.
Action start 3:00:32: RemoveRegistryValues.
MSI (s) (B0:A4) [03:00:32:417]: Doing action: UnregisterClassInfo
Action ended 3:00:32: RemoveRegistryValues. Return value 1.
Action start 3:00:32: UnregisterClassInfo.
MSI (s) (B0:A4) [03:00:32:417]: Doing action: UnregisterExtensionInfo
Action ended 3:00:32: UnregisterClassInfo. Return value 1.
MSI (s) (B0:A4) [03:00:32:417]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: UnregisterExtensionInfo.
MSI (s) (B0:A4) [03:00:32:417]: Doing action: UnregisterProgIdInfo
Action ended 3:00:32: UnregisterExtensionInfo. Return value 1.
MSI (s) (B0:A4) [03:00:32:427]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: UnregisterProgIdInfo.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: UnregisterMIMEInfo
Action ended 3:00:32: UnregisterProgIdInfo. Return value 1.
MSI (s) (B0:A4) [03:00:32:427]: Note: 1: 2262 2: MIME 3: -2147287038
Action start 3:00:32: UnregisterMIMEInfo.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: RemoveIniValues
Action ended 3:00:32: UnregisterMIMEInfo. Return value 1.
MSI (s) (B0:A4) [03:00:32:427]: Note: 1: 2205 2: 3: IniFile
MSI (s) (B0:A4) [03:00:32:427]: Note: 1: 2228 2: 3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`, `Section`,`IniFile`.`Key`,`IniFile` .`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action start 3:00:32: RemoveIniValues.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: RemoveShortcuts
Action ended 3:00:32: RemoveIniValues. Return value 1.
Action start 3:00:32: RemoveShortcuts.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: RemoveEnvironmentStrings
Action ended 3:00:32: RemoveShortcuts. Return value 1.
MSI (s) (B0:A4) [03:00:32:427]: Note: 1: 2205 2: 3: Environment
MSI (s) (B0:A4) [03:00:32:427]: Note: 1: 2228 2: 3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action start 3:00:32: RemoveEnvironmentStrings.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: RemoveDuplicateFiles
Action ended 3:00:32: RemoveEnvironmentStrings. Return value 1.
Action start 3:00:32: RemoveDuplicateFiles.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: RemoveFiles
Action ended 3:00:32: RemoveDuplicateFiles. Return value 1.
MSI (s) (B0:A4) [03:00:32:427]: Note: 1: 2205 2: 3: RemoveFile
Action start 3:00:32: RemoveFiles.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: RemoveFolders
Action ended 3:00:32: RemoveFiles. Return value 0.
Action start 3:00:32: RemoveFolders.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: CreateFolders
Action ended 3:00:32: RemoveFolders. Return value 1.
Action start 3:00:32: CreateFolders.
MSI (s) (B0:A4) [03:00:32:427]: Doing action: MoveFiles
Action ended 3:00:32: CreateFolders. Return value 1.
Action start 3:00:32: MoveFiles.
MSI (s) (B0:A4) [03:00:32:437]: Doing action: InstallFiles
Action ended 3:00:32: MoveFiles. Return value 1.
Action start 3:00:32: InstallFiles.
MSI (s) (B0:A4) [03:00:32:437]: Note: 1: 2205 2: 3: Patch
MSI (s) (B0:A4) [03:00:32:437]: Note: 1: 2228 2: 3: Patch 4: SELECT `Patch`.`File_`, `Patch`.`Header`, `Patch`.`Attributes`, `Patch`.`Sequence`, `Patch`.`StreamRef_` FROM `Patch` WHERE `Patch`.`File_` = ? AND `Patch`.`#_MsiActive`=? ORDER BY `Patch`.`Sequence`
MSI (s) (B0:A4) [03:00:32:437]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (B0:A4) [03:00:32:437]: Note: 1: 2228 2: 3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
MSI (s) (B0:A4) [03:00:32:437]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (B0:A4) [03:00:32:437]: Doing action: PatchFiles
Action ended 3:00:32: InstallFiles. Return value 1.
MSI (s) (B0:A4) [03:00:32:437]: Note: 1: 2228 2: 3: Patch 4: SELECT `File`,`FileName`,`FileSize`,`Direc tory_`,`PatchSize`,`File`.`Attribut es`,`Patch`.`Attributes`,`Patch`.`S equence`,`Component`.`Component`,`C omponent`.`ComponentId` FROM `File`,`Component`,`Patch` WHERE `Patch`.`#_MsiActive`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
Action start 3:00:32: PatchFiles.
MSI (s) (B0:A4) [03:00:32:437]: Doing action: DuplicateFiles
Action ended 3:00:32: PatchFiles. Return value 0.
Action start 3:00:32: DuplicateFiles.
MSI (s) (B0:A4) [03:00:32:447]: Doing action: BindImage
Action ended 3:00:32: DuplicateFiles. Return value 1.
Action start 3:00:32: BindImage.
MSI (s) (B0:A4) [03:00:32:447]: Doing action: CreateShortcuts
Action ended 3:00:32: BindImage. Return value 1.
Action start 3:00:32: CreateShortcuts.
MSI (s) (B0:A4) [03:00:32:447]: Doing action: RegisterClassInfo
Action ended 3:00:32: CreateShortcuts. Return value 1.
Action start 3:00:32: RegisterClassInfo.
MSI (s) (B0:A4) [03:00:32:447]: Doing action: RegisterExtensionInfo
Action ended 3:00:32: RegisterClassInfo. Return value 1.
MSI (s) (B0:A4) [03:00:32:447]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: RegisterExtensionInfo.
MSI (s) (B0:A4) [03:00:32:447]: Doing action: RegisterProgIdInfo
Action ended 3:00:32: RegisterExtensionInfo. Return value 1.
Action start 3:00:32: RegisterProgIdInfo.
MSI (s) (B0:A4) [03:00:32:447]: Doing action: RegisterMIMEInfo
Action ended 3:00:32: RegisterProgIdInfo. Return value 1.
MSI (s) (B0:A4) [03:00:32:447]: Note: 1: 2262 2: MIME 3: -2147287038
Action start 3:00:32: RegisterMIMEInfo.
MSI (s) (B0:A4) [03:00:32:447]: Doing action: WriteRegistryValues
Action ended 3:00:32: RegisterMIMEInfo. Return value 1.
Action start 3:00:32: WriteRegistryValues.
MSI (s) (B0:A4) [03:00:32:477]: Doing action: WriteIniValues
Action ended 3:00:32: WriteRegistryValues. Return value 1.
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2205 2: 3: IniFile
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2228 2: 3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`, `Section`,`IniFile`.`Key`,`IniFile` .`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action start 3:00:32: WriteIniValues.
MSI (s) (B0:A4) [03:00:32:477]: Doing action: WriteEnvironmentStrings
Action ended 3:00:32: WriteIniValues. Return value 1.
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2205 2: 3: Environment
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2228 2: 3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action start 3:00:32: WriteEnvironmentStrings.
MSI (s) (B0:A4) [03:00:32:477]: Doing action: RegisterFonts
Action ended 3:00:32: WriteEnvironmentStrings. Return value 1.
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2205 2: 3: Font
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2228 2: 3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action start 3:00:32: RegisterFonts.
MSI (s) (B0:A4) [03:00:32:477]: Doing action: InstallODBC
Action ended 3:00:32: RegisterFonts. Return value 1.
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description `,`RuntimeFlags`,`Directory_`,`File Name`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `Translator`,`ComponentId`,`Descrip tion`,`RuntimeFlags`,`Directory_`,` FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2205 2: 3: ODBCDataSource
MSI (s) (B0:A4) [03:00:32:477]: Note: 1: 2228 2: 3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverD escription`,`Description`,`Registra tion` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action start 3:00:32: InstallODBC.
MSI (s) (B0:A4) [03:00:32:477]: Doing action: RegisterTypeLibraries
Action ended 3:00:32: InstallODBC. Return value 0.
Action start 3:00:32: RegisterTypeLibraries.
MSI (s) (B0:A4) [03:00:32:477]: Doing action: SelfRegModules
Action ended 3:00:32: RegisterTypeLibraries. Return value 1.
Action start 3:00:32: SelfRegModules.
MSI (s) (B0:A4) [03:00:32:487]: Doing action: RegisterComPlus
Action ended 3:00:32: SelfRegModules. Return value 1.
MSI (s) (B0:A4) [03:00:32:487]: Note: 1: 2205 2: 3: Complus
MSI (s) (B0:A4) [03:00:32:487]: Note: 1: 2228 2: 3: Complus 4: SELECT `ComponentId`, `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed` FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action start 3:00:32: RegisterComPlus.
MSI (s) (B0:A4) [03:00:32:487]: Doing action: InstallServices
Action ended 3:00:32: RegisterComPlus. Return value 0.
MSI (s) (B0:A4) [03:00:32:487]: Detected older ServiceInstall table schema
MSI (s) (B0:A4) [03:00:32:487]: Note: 1: 2205 2: 3: ServiceInstall
MSI (s) (B0:A4) [03:00:32:487]: Note: 1: 2228 2: 3: ServiceInstall 4: SELECT `Name`,`DisplayName`,`ServiceType`, `StartType`,`ErrorControl`,`LoadOrd erGroup`,`Dependencies`,`StartName` ,`Password`,`ComponentId`,`Director y_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action start 3:00:32: InstallServices.
MSI (s) (B0:A4) [03:00:32:487]: Doing action: StartServices
Action ended 3:00:32: InstallServices. Return value 1.
MSI (s) (B0:A4) [03:00:32:487]: Note: 1: 2205 2: 3: ServiceControl
MSI (s) (B0:A4) [03:00:32:487]: Note: 1: 2228 2: 3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 3:00:32: StartServices.
MSI (s) (B0:A4) [03:00:32:487]: Doing action: RegisterUser
Action ended 3:00:32: StartServices. Return value 1.
Action start 3:00:32: RegisterUser.
MSI (s) (B0:A4) [03:00:32:487]: Doing action: RegisterProduct
Action ended 3:00:32: RegisterUser. Return value 1.
Action start 3:00:32: RegisterProduct.
MSI (s) (B0:A4) [03:00:32:487]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (B0:A4) [03:00:32:487]: Doing action: PublishComponents
Action ended 3:00:32: RegisterProduct. Return value 1.
MSI (s) (B0:A4) [03:00:32:487]: Note: 1: 2262 2: PublishComponent 3: -2147287038
Action start 3:00:32: PublishComponents.
MSI (s) (B0:A4) [03:00:32:487]: Doing action: MsiPublishAssemblies
Action ended 3:00:32: PublishComponents. Return value 1.
Action start 3:00:32: MsiPublishAssemblies.
MSI (s) (B0:A4) [03:00:32:497]: Doing action: PublishFeatures
Action ended 3:00:32: MsiPublishAssemblies. Return value 1.
Action start 3:00:32: PublishFeatures.
MSI (s) (B0:A4) [03:00:32:497]: Doing action: PublishProduct
Action ended 3:00:32: PublishFeatures. Return value 1.
Action start 3:00:32: PublishProduct.
MSI (s) (B0:A4) [03:00:32:497]: Doing action: InstallFinalize
Action ended 3:00:32: PublishProduct. Return value 1.
MSI (s) (B0:A4) [03:00:32:497]: Running Script: C:\WINNT\Installer\MSIB6.tmp
MSI (s) (B0:A4) [03:00:32:497]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (B0:A4) [03:00:32:507]: Machine policy value 'DisableRollback' is 0
MSI (s) (B0:A4) [03:00:32:507]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microso ft\Windows\CurrentVersion\Installer \Rollback\Scripts 3: 2
MSI (s) (B0:A4) [03:00:32:527]: Executing op: Header(Signature=1397708873,Version =301,Timestamp=912660497,LangId=103 3,Platform=0,ScriptType=1,ScriptMaj orVersion=21,ScriptMinorVersion=4,S criptAttributes=1)
Action start 3:00:32: InstallFinalize.
MSI (s) (B0:A4) [03:00:32:527]: Executing op: ProductInfo(ProductKey={37477865-A3F1-4772-AD43-AAFC6BCFF99F},ProductName=MSXML 4.0 SP2 (KB927978),PackageName=msxml.msi,La nguage=1033,Version=68429425,Assign ment=1,ObsoleteArg=0,,,PackageCode= {2B27DCD9-53FA-4885-B6CD-698623819F4C},,,InstanceType=0,LUAS etting=0,RemoteURTInstalls=0)
MSI (s) (B0:A4) [03:00:32:527]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (B0:A4) [03:00:32:527]: Executing op: DialogInfo(Type=1,Argument=MSXML 4.0 SP2 (KB927978))
MSI (s) (B0:A4) [03:00:32:527]: Executing op: RollbackInfo(,RollbackAction=Rollba ck,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,Clea nupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (B0:A4) [03:00:32:527]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (B0:A4) [03:00:32:527]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (B0:A4) [03:00:32:527]: Executing op: ActionStart(Name=ProcessComponents, Description=Updating component registration,)
MSI (s) (B0:A4) [03:00:32:527]: Executing op: ProgressTotal(Total=5,Type=1,ByteEq uivalent=24000)
MSI (s) (B0:A4) [03:00:32:527]: Executing op: ComponentUnregister(ComponentId={E9 BC82F6-AC0E-407C-8666-619D6D60DF2B},,BinaryType=0,Previou slyPinned=1)
MSI (s) (B0:A4) [03:00:32:537]: Note: 1: 1402 2: UNKNOWN\Components\6F28CB9EE0CAC704 686616D9D606FDB2 3: 2
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ComponentUnregister(ComponentId={81 754FFD-DA2B-49C6-9447-E1C1E1733BB6},,BinaryType=0,Previou slyPinned=1)
MSI (s) (B0:A4) [03:00:32:537]: Note: 1: 1402 2: UNKNOWN\Components\DFF45718B2AD6C94 49741E1C1E37B36B 3: 2
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ComponentUnregister(ComponentId={5E 6714E1-EA46-4B0F-B479-06D87058DC74},,BinaryType=0,Previou slyPinned=1)
MSI (s) (B0:A4) [03:00:32:537]: Note: 1: 1402 2: UNKNOWN\Components\1E4176E564AEF0B4 4B97608D0785CD47 3: 2
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ComponentUnregister(ComponentId={57 E0F99D-E884-4BD0-B8CB-803CF9EA2066},,BinaryType=0,Previou slyPinned=1)
MSI (s) (B0:A4) [03:00:32:537]: Note: 1: 1402 2: UNKNOWN\Components\D99F0E75488E0DB4 8BBC08C39FAE0266 3: 2
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ComponentUnregister(ComponentId={C7 63CD13-6E1E-4166-8C78-D274B266E9B6},,BinaryType=0,Previou slyPinned=1)
MSI (s) (B0:A4) [03:00:32:537]: Note: 1: 1402 2: UNKNOWN\Components\31DC367CE1E66614 C8872D472B669E6B 3: 2
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ProgressTotal(Total=14,Type=1,ByteE quivalent=24000)
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ComponentRegister(ComponentId={4075 CDF6-D88F-4F57-AF1A-29A124755695},KeyPath=c:\Program Files\MSXML 4.0\,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ComponentRegister(ComponentId={D21D 9CCD-C3FA-4D72-982F-C29A2DE361EC},KeyPath=02:\Software\ Microsoft\Updates\MSXML4SP2\Q927978 \Description,State=3,,Disk=1,Shared DllRefCount=0,BinaryType=0)
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ComponentRegister(ComponentId={4B1F 71A7-50C6-44B7-A3AD-B6C3574BB896},KeyPath=c:\WINNT\syst em32\msxml4.dll,State=3,,Disk=1,Sha redDllRefCount=1,BinaryType=0)
MSI (s) (B0:A4) [03:00:32:537]: Executing op: ComponentRegister(ComponentId={6284 6705-2671-4547-AB45-854DCC93B3C7},KeyPath=c:\WINNT\syst em32\msxml4r.dll,State=3,,Disk=1,Sh aredDllRefCount=1,BinaryType=0)
MSI (s) (B0:A4) [03:00:32:547]: Executing op: ComponentRegister(ComponentId={3AAE 95CD-F592-46E7-89A1-9B56717C4413},,State=-7,,Disk=1,SharedDllRefCount=0,Binar yType=0)
MSI (s) (B0:A4) [03:00:32:547]: Executing op: ComponentRegister(ComponentId={CCF8 B6EF-5FB9-4DE1-A276-683008BA3485},,State=-7,,Disk=1,SharedDllRefCount=0,Binar yType=0)
MSI (s) (B0:A4) [03:00:32:547]: Executing op: ComponentRegister(ComponentId={7B2F CEFF-0F22-B7E1-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,Binar yType=0)
MSI (s) (B0:A4) [03:00:32:547]: Executing op: ComponentRegister(ComponentId={7B2F CEFF-0F22-B7E1-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\ Microsoft\Windows\CurrentVersion\Si deBySide\Installations\x86_Microsof t.MSXML2_6bd6b9abf345378f_4.20.9841 .0_x-ww_18171213\downlevel_manifest\,Sta te=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
MSI (s) (B0:A4) [03:00:32:547]: Executing op: ComponentRegister(ComponentId={7B2F CEFF-0F22-B7E1-B06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\ Microsoft\Windows\CurrentVersion\Si deBySide\Installations\x86_Microsof t.MSXML2_6bd6b9abf345378f_4.20.9841 .0_x-ww_18171213\downlevel_payload\,Stat e=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
MSI (s) (B0:A4) [03:00:32:547]: Executing op: ComponentRegister(ComponentId={DA66 54F6-456F-3658-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,Binar yType=0)
MSI (s) (B0:A4) [03:00:32:547]: Executing op: ComponentRegister(ComponentId={DA66 54F6-456F-3658-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\ Microsoft\Windows\CurrentVersion\Si deBySide\Installations\x86_Microsof t.MSXML2R_6bd6b9abf345378f_4.1.0.0_ x-ww_29c3ad6a\downlevel_manifest\,Sta te=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ComponentRegister(ComponentId={DA66 54F6-456F-3658-B06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\ Microsoft\Windows\CurrentVersion\Si deBySide\Installations\x86_Microsof t.MSXML2R_6bd6b9abf345378f_4.1.0.0_ x-ww_29c3ad6a\downlevel_payload\,Stat e=3,,Disk=1,SharedDllRefCount=0,Bin aryType=0)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ComponentRegister(ComponentId={0E9F 98FC-A692-A6DF-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,Binar yType=0)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ComponentRegister(ComponentId={0E9F 98FC-A692-A6DF-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\ Microsoft\Windows\CurrentVersion\Si deBySide\Installations\x86_policy.4 .20.Microsoft.MSXML2_6bd6b9abf34537 8f_4.20.9841.0_x-ww_ff05e224\downlevel_manifest\,Sta te=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ProgressTotal(Total=1,Type=1,ByteEq uivalent=13200)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\W indows\CurrentVersion\SharedDLLs,,B inaryType=0)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ProgressTick()
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ActionStart(Name=RemoveODBC,Descrip tion=Removing ODBC components,)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ActionStart(Name=CreateFolders,Desc ription=Creating folders,Template=Folder: [1])
MSI (s) (B0:A4) [03:00:32:557]: Executing op: FolderCreate(Folder=c:\Program Files\MSXML 4.0\,Foreign=0,)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ActionStart(Name=InstallFiles,Descr iption=Copying new files,Template=File: [1], Directory: [9], Size: [6])
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ProgressTotal(Total=2521072,Type=0, ByteEquivalent=1)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: SetTargetFolder(Folder=c:\WINNT\sys tem32\)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: SetSourceFolder(Folder=1\System\)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_Core.cab,BytesPer Tick=32768,CopierType=2,ModuleFileN ame=c:\WINNT\Installer\33d31b5.msi, ,,,,IsFirstPhysicalMedia=1)
MSI (s) (B0:A4) [03:00:32:557]: Executing op: FileCopy(SourceName=msxml4.dll,Sour ceCabKey=msxml4.dll.246EB7AD_459A_4 FA8_83D1_41A46D7634B7,DestName=msxm l4.dll,Attributes=512,FileSize=1245 696,PerTick=32768,,VerifyMedia=1,,, ,,CheckCRC=0,Version=4.20.9841.0,La nguage=0,InstallMode=58982400,,,,,, ,)
MSI (s) (B0:A4) [03:00:32:567]: File: c:\WINNT\system32\msxml4.dll; Overwrite; Won't patch; Existing file is a lower version
MSI (s) (B0:A4) [03:00:32:567]: Source for file 'msxml4.dll.246EB7AD_459A_4FA8_83D1 _41A46D7634B7' is compressed
MSI (s) (B0:A4) [03:00:32:567]: Re-applying security from existing file.
MSI (s) (B0:A4) [03:00:32:577]: Verifying accessibility of file: msxml4.dll
MSI (s) (B0:A4) [03:00:32:587]: SOFTWARE RESTRICTION POLICY: Verifying object --> 'c:\WINNT\Installer\33d31b5.msi' against software restriction policy
MSI (s) (B0:A4) [03:00:32:587]: SOFTWARE RESTRICTION POLICY: c:\WINNT\Installer\33d31b5.msi has a digital signature
MSI (s) (B0:A4) [03:00:32:677]: SOFTWARE RESTRICTION POLICY: c:\WINNT\Installer\33d31b5.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (B0:A4) [03:00:32:677]: Note: 1: 2318 2: c:\WINNT\system32\msxml4.dll
MSI (s) (B0:A4) [03:00:32:687]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:697]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:707]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:717]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:727]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:737]: Executing op: FileCopy(SourceName=msxml4r.dll,Sou rceCabKey=msxml4r.dll.246EB7AD_459A _4FA8_83D1_41A46D7634B7,DestName=ms xml4r.dll,Attributes=512,FileSize=8 2432,PerTick=32768,,VerifyMedia=1,, ,,,CheckCRC=0,Version=4.10.9404.0,L anguage=1033,InstallMode=58982400,, ,,,,,)
MSI (s) (B0:A4) [03:00:32:737]: File: c:\WINNT\system32\msxml4r.dll; Won't Overwrite; Won't patch; Existing file is of an equal version
MSI (s) (B0:A4) [03:00:32:737]: Executing op: SetTargetFolder(Folder=c:\WINNT\win sxs\Manifests\)
MSI (s) (B0:A4) [03:00:32:737]: Executing op: SetSourceFolder(Folder=1\Windows\wi nsxs\manifest\|Windows\winsxs\Manif ests\)
MSI (s) (B0:A4) [03:00:32:737]: Executing op: FileCopy(SourceName=xl34x2va.rt8|x8 6_Microsoft.MSXML2_6bd6b9abf345378f _4.20.9841.0_x-ww_18171213.manifest,SourceCabKey=m anifest.7B2FCEFF_0F22_B7E1_FF6B_D6B 9ABF34537,DestName=x86_Microsoft.MS XML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest,,FileSize=3973 ,PerTick=32768,,VerifyMedia=1,Eleva teFlags=4,,,,CheckCRC=0,,,InstallMo de=58982400,HashOptions=0,HashPart1 =-85909274,HashPart2=-393638470,HashPart3=495071453,HashP art4=945762879,,)
MSI (s) (B0:A4) [03:00:32:737]: File: c:\WINNT\winsxs\Manifests\x86_Micro soft.MSXML2_6bd6b9abf345378f_4.20.9 841.0_x-ww_18171213.manifest; To be installed; Won't patch; No existing file
MSI (s) (B0:A4) [03:00:32:737]: Source for file 'manifest.7B2FCEFF_0F22_B7E1_FF6B_D 6B9ABF34537' is compressed
MSI (s) (B0:A4) [03:00:32:737]: Note: 1: 2318 2: c:\WINNT\winsxs\Manifests\x86_Micro soft.MSXML2_6bd6b9abf345378f_4.20.9 841.0_x-ww_18171213.manifest
MSI (s) (B0:A4) [03:00:32:757]: Executing op: FileCopy(SourceName=yl34x2va.rt8|x8 6_Microsoft.MSXML2_6bd6b9abf345378f _4.20.9841.0_x-ww_18171213.cat,SourceCabKey=catalo g.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34 537,DestName=x86_Microsoft.MSXML2_6 bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat,,FileSize=8347,PerT ick=32768,,VerifyMedia=1,ElevateFla gs=4,,,,CheckCRC=0,,,InstallMode=58 982400,HashOptions=0,HashPart1=-1679697816,HashPart2=1808584787,Has hPart3=1425912084,HashPart4=6292369 04,,)
MSI (s) (B0:A4) [03:00:32:757]: File: c:\WINNT\winsxs\Manifests\x86_Micro soft.MSXML2_6bd6b9abf345378f_4.20.9 841.0_x-ww_18171213.cat; To be installed; Won't patch; No existing file
MSI (s) (B0:A4) [03:00:32:757]: Source for file 'catalog.7B2FCEFF_0F22_B7E1_FF6B_D6 B9ABF34537' is compressed
MSI (s) (B0:A4) [03:00:32:757]: Note: 1: 2318 2: c:\WINNT\winsxs\Manifests\x86_Micro soft.MSXML2_6bd6b9abf345378f_4.20.9 841.0_x-ww_18171213.cat
MSI (s) (B0:A4) [03:00:32:757]: Executing op: SetTargetFolder(Folder=c:\WINNT\win sxs\x86_Microsoft.MSXML2_6bd6b9abf3 45378f_4.20.9841.0_x-ww_18171213\)
MSI (s) (B0:A4) [03:00:32:757]: Executing op: SetSourceFolder(Folder=1\Windows\wi nsxs\tl34x2va.rt8\)
MSI (s) (B0:A4) [03:00:32:757]: Executing op: FileCopy(SourceName=1m34x2va.rt8|ms xml4.dll,SourceCabKey=msxml4.dll.7B 2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537, DestName=msxml4.dll,,FileSize=12456 96,PerTick=32768,,VerifyMedia=1,Ele vateFlags=4,,,,CheckCRC=0,Version=4 .20.9841.0,Language=0,InstallMode=5 8982400,,,,,,,)
MSI (s) (B0:A4) [03:00:32:757]: File: c:\WINNT\winsxs\x86_Microsoft.MSXML 2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\msxml4.dll; To be installed; Won't patch; No existing file
MSI (s) (B0:A4) [03:00:32:757]: Source for file 'msxml4.dll.7B2FCEFF_0F22_B7E1_FF6B _D6B9ABF34537' is compressed
MSI (s) (B0:A4) [03:00:32:767]: Note: 1: 2318 2: c:\WINNT\winsxs\x86_Microsoft.MSXML 2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\msxml4.dll
MSI (s) (B0:A4) [03:00:32:767]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:777]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:787]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:797]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:807]: Note: 1: 2360
MSI (s) (B0:A4) [03:00:32:817]: Executing op: SetTargetFolder(Folder=c:\WINNT\win sxs\Manifests\)
MSI (s) (B0:A4) [03:00:32:817]: Executing op: SetSourceFolder(Folder=1\Windows\wi nsxs\manifest\|Windows\winsxs\Manif ests\)
MSI (s) (B0:A4) [03:00:32:817]: Executing op: FileCopy(SourceName=9n0mtfut.k85|x8 6_Microsoft.MSXML2R_6bd6b9abf345378 f_4.1.0.0_x-ww_29c3ad6a.manifest,SourceCabKey=m anifest.DA6654F6_456F_3658_FF6B_D6B 9ABF34537,DestName=x86_Microsoft.MS XML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest,,FileSize=500, PerTick=32768,,VerifyMedia=1,Elevat eFlags=4,,,,CheckCRC=0,,,InstallMod e=58982400,HashOptions=0,HashPart1=-707213148,HashPart2=1938794768,Hash Part3=-933075776,HashPart4=-843550219,,)
MSI (s) (B0:A4) [03:00:32:817]: File: c:\WINNT\winsxs\Manifests\x86_Micro soft.MSXML2R_6bd6b9abf345378f_4.1.0 .0_x-ww_29c3ad6a.manifest; Won't Overwrite; Won't patch; Existing file is unversioned and unmodified - hash matches source file
MSI (s) (B0:A4) [03:00:32:817]: Executing op: FileCopy(SourceName=an0mtfut.k85|x8 6_Microsoft.MSXML2R_6bd6b9abf345378 f_4.1.0.0_x-ww_29c3ad6a.cat,SourceCabKey=catalo g.DA6654F6_456F_3658_FF6B_D6B9ABF34 537,DestName=x86_Microsoft.MSXML2R_ 6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat,,FileSize=8349,PerT ick=32768,,VerifyMedia=1,ElevateFla gs=4,,,,CheckCRC=0,,,InstallMode=58 982400,HashOptions=0,HashPart1=-1336197992,HashPart2=-627824155,HashPart3=82633343,HashPa rt4=1105156543,,)
MSI (s) (B0:A4) [03:00:32:827]: File: c:\WINNT\winsxs\Manifests\x86_Micro soft.MSXML2R_6bd6b9abf345378f_4.1.0 .0_x-ww_29c3ad6a.cat; Overwrite; Won't patch; Existing file is unversioned and unmodified - hash doesn't match source file
MSI (s) (B0:A4) [03:00:32:827]: Source for file 'catalog.DA6654F6_456F_3658_FF6B_D6 B9ABF34537' is compressed
MSI (s) (B0:A4) [03:00:32:827]: Re-applying security from existing file.
MSI (s) (B0:A4) [03:00:33:057]: Verifying accessibility of file: x86_Microsoft.MSXML2R_6bd6b9abf3453 78f_4.1.0.0_x-ww_29c3ad6a.cat
MSI (s) (B0:A4) [03:00:33:118]: Note: 1: 2318 2: c:\WINNT\winsxs\Manifests\x86_Micro soft.MSXML2R_6bd6b9abf345378f_4.1.0 .0_x-ww_29c3ad6a.cat
MSI (s) (B0:A4) [03:00:33:148]: Executing op: SetTargetFolder(Folder=c:\WINNT\win sxs\x86_Microsoft.MSXML2R_6bd6b9abf 345378f_4.1.0.0_x-ww_29c3ad6a\)
MSI (s) (B0:A4) [03:00:33:148]: Executing op: SetSourceFolder(Folder=1\Windows\wi nsxs\5n0mtfut.k85\)
MSI (s) (B0:A4) [03:00:33:148]: Executing op: FileCopy(SourceName=dn0mtfut.k85|ms xml4r.dll,SourceCabKey=msxml4r.dll. DA6654F6_456F_3658_FF6B_D6B9ABF3453 7,DestName=msxml4r.dll,,FileSize=82 432,PerTick=32768,,VerifyMedia=1,El evateFlags=4,,,,CheckCRC=0,Version= 4.10.9404.0,Language=1033,InstallMo de=58982400,,,,,,,)
MSI (s) (B0:A4) [03:00:33:158]: File: c:\WINNT\winsxs\x86_Microsoft.MSXML 2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\msxml4r.dll; Won't Overwrite; Won't patch; Existing file is of an equal version
MSI (s) (B0:A4) [03:00:33:158]: Executing op: SetTargetFolder(Folder=c:\WINNT\win sxs\Policies\x86_policy.4.20.Micros oft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\)
MSI (s) (B0:A4) [03:00:33:158]: Executing op: SetSourceFolder(Folder=1\Windows\wi nsxs\Policies\i0r1wg7y.dqe\)
MSI (s) (B0:A4) [03:00:33:158]: Executing op: FileCopy(SourceName=l0r1wg7y.dqe|4. 20.9841.0.policy,SourceCabKey=manif est.0E9F98FC_A692_A6DF_FF6B_D6B9ABF 34537,DestName=4.20.9841.0.policy,, FileSize=652,PerTick=32768,,VerifyM edia=1,ElevateFlags=4,,,,CheckCRC=0 ,,,InstallMode=58982400,HashOptions =0,HashPart1=49613189,HashPart2=113 9053242,HashPart3=-1699064514,HashPart4=-854272932,,)
MSI (s) (B0:A4) [03:00:33:158]: File: c:\WINNT\winsxs\Policies\x86_policy .4.20.Microsoft.MSXML2_6bd6b9abf345 378f_x-ww_88e8eab8\4.20.9841.0.policy; To be installed; Won't patch; No existing file
MSI (s) (B0:A4) [03:00:33:158]: Source for file 'manifest.0E9F98FC_A692_A6DF_FF6B_D 6B9ABF34537' is compressed
MSI (s) (B0:A4) [03:00:33:158]: Note: 1: 2318 2: c:\WINNT\winsxs\Policies\x86_policy .4.20.Microsoft.MSXML2_6bd6b9abf345 378f_x-ww_88e8eab8\4.20.9841.0.policy
MSI (s) (B0:A4) [03:00:33:158]: Executing op: FileCopy(SourceName=m0r1wg7y.dqe|4. 20.9841.0.cat,SourceCabKey=catalog. 0E9F98FC_A692_A6DF_FF6B_D6B9ABF3453 7,DestName=4.20.9841.0.cat,,FileSiz e=8359,PerTick=32768,,VerifyMedia=1 ,ElevateFlags=4,,,,CheckCRC=0,,,Ins tallMode=58982400,HashOptions=0,Has hPart1=-861819424,HashPart2=1423527147,Hash Part3=-1146259424,HashPart4=2040409349,,)
MSI (s) (B0:A4) [03:00:33:158]: File: c:\WINNT\winsxs\Policies\x86_policy .4.20.Microsoft.MSXML2_6bd6b9abf345 378f_x-ww_88e8eab8\4.20.9841.0.cat; To be installed; Won't patch; No existing file
MSI (s) (B0:A4) [03:00:33:158]: Source for file 'catalog.0E9F98FC_A692_A6DF_FF6B_D6 B9ABF34537' is compressed
MSI (s) (B0:A4) [03:00:33:158]: Note: 1: 2318 2: c:\WINNT\winsxs\Policies\x86_policy .4.20.Microsoft.MSXML2_6bd6b9abf345 378f_x-ww_88e8eab8\4.20.9841.0.cat
MSI (s) (B0:A4) [03:00:33:168]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_SDK.cab,BytesPerT ick=32768,CopierType=2,ModuleFileNa me=c:\WINNT\Installer\33d31b5.msi,, ,,,IsFirstPhysicalMedia=1)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: CacheSizeFlush(,)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: InstallProtectedFiles(AllowUI=0)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: ActionStart(Name=WriteRegistryValue s,Description=Writing system registry values,Template=Key: [1], Name: [2], Value: [3])
MSI (s) (B0:A4) [03:00:33:168]: Executing op: ProgressTotal(Total=112,Type=1,Byte Equivalent=13200)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegAddValue(,Value=XML DOM Document 4.0,)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegAddValue(,Value=c:\WINNT\system3 2\msxml4.dll,)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Both,)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegOpenKey(,Key=Msxml2.DOMDocument. 4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegAddValue(,Value=Msxml2.DOMDocume nt.4.0,)
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:168]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(,Value={F5078F18-C551-11D3-89B9-0000F81FE221},)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=Msxml2.DOMDocument. 4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(,Value={88D969C0-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(,Value=Free Threaded XML DOM Document 4.0,)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(,Value=c:\WINNT\system3 2\msxml4.dll,)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Both,)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=Msxml2.FreeThreaded DOMDocument.4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(,Value=Msxml2.FreeThrea dedDOMDocument.4.0,)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=Msxml2.FreeThreaded DOMDocument.4.0\CLSID,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(,Value={88D969C1-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(,Value=XML Data Source Object 4.0,)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:178]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Apartment,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=Msxml2.DSOControl.4 .0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value=XML Data Source Object 4.0,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value=Msxml2.DSOContro l.4.0,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value={F5078F18-C551-11D3-89B9-0000F81FE221},)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=Msxml2.DSOControl.4 .0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value={88D969C4-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value=XML HTTP 4.0,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value=c:\WINNT\system3 2\msxml4.dll,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Apartment,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=Msxml2.XMLHTTP.4.0, ,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value=Msxml2.XMLHTTP.4 .0,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=Msxml2.XMLHTTP.4.0\ CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value={88D969C5-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegAddValue(,Value=Server XML HTTP 4.0,)
MSI (s) (B0:A4) [03:00:33:188]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Apartment,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=Msxml2.ServerXMLHTT P.4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value=Server XML HTTP 4.0,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value=Msxml2.ServerXML HTTP.4.0,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value={F5078F18-C551-11D3-89B9-0000F81FE221},)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=Msxml2.ServerXMLHTT P.4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value={88D969C6-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value=XML Schema Cache 4.0,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value=c:\WINNT\system3 2\msxml4.dll,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Both,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=Msxml2.XMLSchemaCac he.4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value=Msxml2.XMLSchema Cache.4.0,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=Msxml2.XMLSchemaCac he.4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value={88D969C2-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegAddValue(,Value=XSL Template 4.0,)
MSI (s) (B0:A4) [03:00:33:198]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Both,)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=Msxml2.XSLTemplate. 4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value=XSL Template 4.0,)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value=Msxml2.XSLTempla te.4.0,)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=Msxml2.XSLTemplate. 4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value={88D969C3-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value=SAX XML Reader 4.0,)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value=c:\WINNT\system3 2\msxml4.dll,)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=Msxml2.SAXXMLReader .4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value=Msxml2.SAXXMLRea der.4.0,)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=Msxml2.SAXXMLReader .4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value={7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F},)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=CLSID\{00B7E0AB-817A-44AD-A04B-D1148D524136},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegAddValue(,Value=MX XML Reader 4.0,)
MSI (s) (B0:A4) [03:00:33:208]: Executing op: RegOpenKey(,Key=CLSID\{00B7E0AB-817A-44AD-A04B-D1148D524136}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Both,)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegAddValue(,Value=MXXMLWriter 4.0,)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegAddValue(,Value=c:\WINNT\system3 2\msxml4.dll,)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.MXXMLWriter. 4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegAddValue(,Value=Msxml2.MXXMLWrit er.4.0,)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.MXXMLWriter. 4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegAddValue(,Value={88D969C8-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegAddValue(,Value=MXHTMLWriter 4.0,)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.MXHTMLWriter .4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegAddValue(,Value=Msxml2.MXHTMLWri ter.4.0,)
MSI (s) (B0:A4) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=Msxml2.MXHTMLWriter .4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value={88D969C9-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value=SAXAttributes 4.0,)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value=c:\WINNT\system3 2\msxml4.dll,)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(Name=ThreadingModel,Val ue=Both,)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=Msxml2.SAXAttribute s.4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value=Msxml2.SAXAttrib utes.4.0,)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=Msxml2.SAXAttribute s.4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value={88D969CA-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value=MXNamespaceManag er 4.0,)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\InProcServer32,,Binar yType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=Msxml2.MXNamespaceM anager.4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value=Msxml2.MXNamespa ceManager.4.0,)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0 )
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegOpenKey(,Key=Msxml2.MXNamespaceM anager.4.0\CLSID,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:228]: Executing op: RegAddValue(,Value={88D969D6-F192-11D4-A65F-0040963251E5},)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\U pdates\MSXML4SP2\Q927978,,BinaryTyp e=0)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(Name=Description,Value= FIX: ASP stops responding when calling Response.Redirect to another server using msxml4 sp2,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(Name=InstalledDate,Valu e=3/6/2007,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(Name=InstalledBy,Value= ,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(Name=IsInstalled,Value= #1,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(Name=ServicePack,Value= #1,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\Typ eLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(,Value=Microsoft XML, v4.0,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\Typ eLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\0,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(,,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\Typ eLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\0\win32,,BinaryTy pe=0)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(,Value=c:\WINNT\system3 2\msxml4.dll,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\Typ eLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\FLAGS,,BinaryType =0)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegAddValue(,Value=0,)
MSI (s) (B0:A4) [03:00:33:238]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\Typ eLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\HELPDIR,,BinaryTy pe=0)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\W indows\CurrentVersion\SideBySide\In stallations\x86_Microsoft.MSXML2_6b d6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_payload,,Bina ryType=0)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegAddValue(,,)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\W indows\CurrentVersion\SideBySide\In stallations\x86_Microsoft.MSXML2_6b d6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_manifest,,Bin aryType=0)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\W indows\CurrentVersion\SideBySide\In stallations\x86_Microsoft.MSXML2R_6 bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_payload,,Bina ryType=0)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\W indows\CurrentVersion\SideBySide\In stallations\x86_Microsoft.MSXML2R_6 bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_manifest,,Bin aryType=0)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\W indows\CurrentVersion\SideBySide\In stallations\x86_policy.4.20.Microso ft.MSXML2_6bd6b9abf345378f_4.20.984 1.0_x-ww_ff05e224\downlevel_manifest,,Bin aryType=0)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\W indows\CurrentVersion\SideBySide\Pa tchedComponents,,BinaryType=0)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegAddValue(Name={7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537},Value=c:\WINNT\winsxs \Manifests\\x86_Microsoft.MSXML2_6b d6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537}[~]c:\WINNT\winsxs\Manifests\\x86_Micr osoft.MSXML2_6bd6b9abf345378f_4.20. 9841.0_x-ww_18171213.cat[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537}[~]c:\WINNT\winsxs\Manifests\[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537},)
MSI (s) (B0:A4) [03:00:33:248]: Executing op: RegAddValue(Name={7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537},Value=c:\WINNT\winsxs \x86_Microsoft.MSXML2_6bd6b9abf3453 78f_4.20.9841.0_x-ww_18171213\\msxml4.dll[~]{7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537}[~]c:\WINNT\winsxs\x86_Microsoft.MSXML 2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\[~]{7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537},)
MSI (s) (B0:A4) [03:00:33:258]: Executing op: RegAddValue(Name={DA6654F6-456F-3658-C06B-D6B9ABF34537},Value=c:\WINNT\winsxs \Manifests\\x86_Microsoft.MSXML2R_6 bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537}[~]c:\WINNT\winsxs\Manifests\\x86_Micr osoft.MSXML2R_6bd6b9abf345378f_4.1. 0.0_x-ww_29c3ad6a.cat[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537}[~]c:\WINNT\winsxs\Manifests\[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537},)
MSI (s) (B0:A4) [03:00:33:258]: Executing op: RegAddValue(Name={DA6654F6-456F-3658-B06B-D6B9ABF34537},Value=c:\WINNT\winsxs \x86_Microsoft.MSXML2R_6bd6b9abf345 378f_4.1.0.0_x-ww_29c3ad6a\\msxml4r.dll[~]{DA6654F6-456F-3658-B06B-D6B9ABF34537}[~]c:\WINNT\winsxs\x86_Microsoft.MSXML 2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\[~]{DA6654F6-456F-3658-B06B-D6B9ABF34537},)
MSI (s) (B0:A4) [03:00:33:258]: Executing op: RegAddValue(Name={0E9F98FC-A692-A6DF-C06B-D6B9ABF34537},Value=c:\WINNT\winsxs \Policies\x86_policy.4.20.Microsoft .MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\\4.20.9841.0.policy[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537}[~]c:\WINNT\winsxs\Policies\x86_policy .4.20.Microsoft.MSXML2_6bd6b9abf345 378f_x-ww_88e8eab8\\4.20.9841.0.cat[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537}[~]c:\WINNT\winsxs\Policies\x86_policy .4.20.Microsoft.MSXML2_6bd6b9abf345 378f_x-ww_88e8eab8\[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537},)
MSI (s) (B0:A4) [03:00:33:258]: Executing op: ActionStart(Name=RegisterTypeLibrar ies,Description=Registering type libraries,Template=LibID: [1])
MSI (s) (B0:A4) [03:00:33:258]: Executing op: TypeLibraryRegister(,,FilePath=c:\W INNT\system32\msxml4.dll,LibID={F50 78F18-C551-11D3-89B9-0000F81FE221},Version=1024,,Languag e=0,,BinaryType=0,IgnoreRegistratio nFailure=0)
MSI (s) (B0:A4) [03:00:33:258]: QueryPathOfRegTypeLib returned 0 in local context. Path is 'c:\WINNT\system32\msxml4.dll'
MSI (s) (B0:A4) [03:00:33:258]: Note: 1: 1402 2: UNKNOWN\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\400.0\0\win32 3: 2
MSI (s) (B0:A4) [03:00:33:258]: CMsiServices::ProcessTypeLibrary runs in local context, not impersonated.
MSI (s) (B0:A4) [03:00:33:378]: ProcessTypeLibraryCore returns: 0. (0 means OK)
MSI (s) (B0:A4) [03:00:33:388]: CMsiServices::ProcessTypeLibrary runs in local context, not impersonated.
MSI (s) (B0:A4) [03:00:33:408]: ProcessTypeLibraryCore returns: 0. (0 means OK)
MSI (s) (B0:A4) [03:00:33:408]: Executing op: ActionStart(Name=RegisterUser,Descr iption=Registering user,Template=[1])
MSI (s) (B0:A4) [03:00:33:408]: Executing op: UserRegister(Owner= ,,ProductId=none)
MSI (s) (B0:A4) [03:00:33:408]: Executing op: ActionStart(Name=RegisterProduct,De scription=Registering product,Template=[1])
MSI (s) (B0:A4) [03:00:33:408]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_Core.cab,BytesPer Tick=0,CopierType=2,ModuleFileName= c:\WINNT\Installer\33d31b5.msi,,,,, IsFirstPhysicalMedia=1)
MSI (s) (B0:A4) [03:00:33:408]: Executing op: DatabaseCopy(DatabasePath=c:\WINNT\ Installer\33d31b5.msi,ProductCode={ 37477865-A3F1-4772-AD43-AAFC6BCFF99F},CabinetStreams=XML_Co re.cab;XML_SDK.cab,,)
MSI (s) (B0:A4) [03:00:33:558]: Executing op: ProductRegister(UpgradeCode={7CE723 E3-E56B-432C-9F24-78C0606045A5},VersionString=4.20.98 41.0,HelpLink=http://support.microsoft.com/kb/927978,,,InstallSource=c:\6e006e1c0 29410c635f6d2f79f13a7\,Publisher=Mi crosoft Corporation,,,,,,,,,,,,EstimatedSiz e=2625)
MSI (s) (B0:A4) [03:00:33:618]: Executing op: ProductCPDisplayInfoRegister()
MSI (s) (B0:A4) [03:00:33:628]: Executing op: ActionStart(Name=PublishFeatures,De scription=Publishing Product Features,Template=Feature: [1])
MSI (s) (B0:A4) [03:00:33:628]: Executing op: FeaturePublish(Feature=MSXML,,Absen t=2,Component=MF}e835XRAhvfl[X%h~W(s-UlQ2mt@MgogY-xd{t)
MSI (s) (B0:A4) [03:00:33:628]: Executing op: FeaturePublish(Feature=MSXMLSYS,Par ent=MSXML,Absent=2,Component=V2?0@7 $9*=IdbugpYRMX}GHaGLdZ==A&kv@Y~]3iui-r60O)l=Em%pCn7G4))
MSI (s) (B0:A4) [03:00:33:638]: Executing op: FeaturePublish(Feature=MSXMLSUPP2,P arent=MSXML,Absent=2,Component=?`Zs jqO[%A*`NW3OG&nR)
MSI (s) (B0:A4) [03:00:33:648]: Executing op: FeaturePublish(Feature=MSXMLSXS,Par ent=MSXML,Absent=2,Component=LdCZOH qG+dpWsfdDE!j5LdCZOHqG+d6XsfdDE!j5L dCZOHqG+d%XsfdDE!j5`DM4olJ_O5pWsfdD E!j5`DM4olJ_O56XsfdDE!j5`DM4olJ_O5% XsfdDE!j5l0Rd'9?m^^pWsfdDE!j5l0Rd'9 ?m^^6XsfdDE!j5)
MSI (s) (B0:A4) [03:00:33:648]: Executing op: FeaturePublish(Feature=XMLSDK,,Abse nt=3,Component=mk`[Q=PRe?RvYBgpXHXc5~{DF_B]-@1_XLnB~RWMMvh8D]u5G@j^sM7=J&oH0G,*i]!a$9uKNVM3Kykc)
MSI (s) (B0:A4) [03:00:33:658]: Executing op: ActionStart(Name=PublishProduct,Des cription=Publishing product information,)
MSI (s) (B0:A4) [03:00:33:658]: Executing op: IconCreate(Icon=icon.exe,Data=Binar yData)
MSI (s) (B0:A4) [03:00:33:778]: Executing op: CleanupConfigData()
MSI (s) (B0:A4) [03:00:33:778]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microso ft\Windows\CurrentVersion\Installer \UserData\S-1-5-18\Products\568774731F3A2774DA34AAC FB6FC9FF9\Patches 3: 2
MSI (s) (B0:A4) [03:00:33:778]: Executing op: RegisterPatchOrder(Continue=0,Seque nceType=1,Remove=0)
MSI (s) (B0:A4) [03:00:33:778]: Note: 1: 1402 2: UNKNOWN\Products\568774731F3A2774DA 34AACFB6FC9FF9\Patches 3: 2
MSI (s) (B0:A4) [03:00:33:778]: Executing op: ProductPublish(PackageKey={2B27DCD9-53FA-4885-B6CD-698623819F4C})
MSI (s) (B0:A4) [03:00:33:778]: Note: 1: 1402 2: UNKNOWN\Installer\Products\56877473 1F3A2774DA34AACFB6FC9FF9 3: 2
MSI (s) (B0:A4) [03:00:33:799]: Executing op: UpgradeCodePublish(UpgradeCode={7CE 723E3-E56B-432C-9F24-78C0606045A5})
MSI (s) (B0:A4) [03:00:33:799]: Executing op: SourceListPublish(,,,,NumberOfDisks =2)
MSI (s) (B0:A4) [03:00:33:799]: Note: 1: 1402 2: UNKNOWN\Installer\Products\56877473 1F3A2774DA34AACFB6FC9FF9\SourceList 3: 2
MSI (s) (B0:A4) [03:00:33:809]: Executing op: ProductPublishClient(,,)
MSI (s) (B0:A4) [03:00:33:809]: Executing op: SourceListRegisterLastUsed(SourcePr oduct={37477865-A3F1-4772-AD43-AAFC6BCFF99F},LastUsedSource=c:\6e0 06e1c029410c635f6d2f79f13a7\)
MSI (s) (B0:A4) [03:00:33:809]: Entering CMsiConfigurationManager::SetLastUs edSource.
MSI (s) (B0:A4) [03:00:33:809]: Specifed source is already in a list.
MSI (s) (B0:A4) [03:00:33:809]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (B0:A4) [03:00:33:809]: Machine policy value 'DisableBrowse' is 0
MSI (s) (B0:A4) [03:00:33:809]: Machine policy value 'AllowLockdownBrowse' is 0
MSI (s) (B0:A4) [03:00:33:809]: Adding new sources is allowed.
MSI (s) (B0:A4) [03:00:33:809]: Set LastUsedSource to: c:\6e006e1c029410c635f6d2f79f13a7\.
MSI (s) (B0:A4) [03:00:33:809]: Set LastUsedType to: n.
MSI (s) (B0:A4) [03:00:33:809]: Set LastUsedIndex to: 1.
MSI (s) (B0:A4) [03:00:33:809]: Executing op: End(Checksum=0,ProgressTotalHDWord= 0,ProgressTotalLDWord=4481872)
MSI (s) (B0:A4) [03:00:33:819]: User policy value 'DisableRollback' is 0
MSI (s) (B0:A4) [03:00:33:819]: Machine policy value 'DisableRollback' is 0
MSI (s) (B0:A4) [03:00:34:029]: No System Restore sequence number for this installation.
MSI (s) (B0:A4) [03:00:34:029]: Unlocking Server
MSI (s) (B0:A4) [03:00:34:029]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
MSI (s) (B0:A4) [03:00:34:029]: Skipping action: SxsUninstallCA (condition is false)
MSI (s) (B0:A4) [03:00:34:029]: Doing action: RemoveExistingProducts
Action ended 3:00:34: InstallFinalize. Return value 1.
Action start 3:00:34: RemoveExistingProducts.
Action ended 3:00:34: RemoveExistingProducts. Return value 1.
Action ended 3:00:34: INSTALL. Return value 1.
Property(S): ProductName = MSXML 4.0 SP2 (KB927978)
Property(S): ProductCode = {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Property(S): Manufacturer = Microsoft Corporation
Property(S): ProductVersion = 4.20.9841.0
Property(S): ProductLanguage = 1033
Property(S): BannerBitmap = bannrbmp
Property(S): IAgree = No
Property(S): ProductID = none
Property(S): ARPHELPLINK = MS06-071: Security update for Microsoft XML Core Services 4.0
Property(S): ButtonText_Back = < &Back
Property(S): ButtonText_Browse = Br&owse
Property(S): ButtonText_Cancel = Cancel
Property(S): ButtonText_Exit = &Exit
Property(S): ButtonText_Finish = &Finish
Property(S): ButtonText_Ignore = &Ignore
Property(S): ButtonText_Install = &Install
Property(S): ButtonText_InstallNow = &Install Now
Property(S): ButtonText_Next = &Next >
Property(S): ButtonText_No = &No
Property(S): ButtonText_OK = OK
Property(S): ButtonText_Remove = &Remove
Property(S): ButtonText_Reset = &Reset
Property(S): ButtonText_Resume = &Resume
Property(S): ButtonText_Retry = &Retry
Property(S): ButtonText_Return = &Return
Property(S): ButtonText_Yes = &Yes
Property(S): CompleteSetupIcon = completi
Property(S): CustomSetupIcon = custicon
Property(S): DialogBitmap = dlgbmp
Property(S): DlgTitleFont = {&DlgFontBold8}
Property(S): ExclamationIcon = exclamic
Property(S): InfoIcon = info
Property(S): InstallerIcon = insticon
Property(S): INSTALLLEVEL = 3
Property(S): InstallModeTxt_1 = Custom
Property(S): InstallModeVal = InstallModeTxt_1
Property(S): InstallModeTxt_2 = Complete
Property(S): InstallModeTxt_3 = Server Image
Property(S): InstallModeTxt_4 = Change
Property(S): InstallModeTxt_5 = Repair
Property(S): InstallModeTxt_6 = Remove
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): Progress1Txt_1 = Installing
Property(S): Progress1 = Progress1Txt_1
Property(S): Progress2Txt_1 = installs
Property(S): Progress2 = Progress2Txt_1
Property(S): Progress1Txt_2 = Changing
Property(S): Progress2Txt_2 = changes
Property(S): Progress1Txt_3 = Repairing
Property(S): Progress2Txt_3 = repairs
Property(S): Progress1Txt_4 = Removing
Property(S): Progress2Txt_4 = removes
Property(S): PROMPTROLLBACKCOST = P
Property(S): RemoveIcon = removico
Property(S): RepairIcon = repairic
Property(S): Setup = Setup
Property(S): Wizard = Setup Wizard
Property(S): DefaultUIFont = DlgFont8
Property(S): ErrorDialog = ErrorDlg
Property(S): TARGETDIR = c:\
Property(S): USERNAME =
Property(S): APPS_TEST = 1
Property(S): VersionNT = 501
Property(S): SecureCustomProperties = MSXML4SP2
Property(S): UpgradeCode = {7CE723E3-E56B-432C-9F24-78C0606045A5}
Property(S): ALLUSERS = 1
Property(S): WINHTTP_51 = WinHttpRequest Component version 5.1
Property(S): MSXML = c:\Program Files\MSXML 4.0\
Property(S): SourceDir = c:\6e006e1c029410c635f6d2f79f13a7\
Property(S): DesktopFolder = c:\Documents and Settings\All Users\Desktop\
Property(S): ProgramFilesFolder = c:\Program Files\
Property(S): ProductState = -1
Property(S): PackageCode = {2B27DCD9-53FA-4885-B6CD-698623819F4C}
Property(S): SystemFolder.246EB7AD_459A_4FA8_83D 1_41A46D7634B7 = c:\WINNT\system32\
Property(S): SystemFolder.781A0624_31FF_4712_BFF D_31C829FFDBF1 = c:\WINNT\system32\
Property(S): SystemFolder.FA0F135B_0C6B_485B_9A2 7_5A4A5044D5AB = c:\WINNT\system32\
Property(S): WinSxsDirectory.7B2FCEFF_0F22_B7E1_ FF6B_D6B9ABF34537 = c:\WINNT\winsxs\
Property(S): payload_ul.7B2FCEFF_0F22_B7E1_FF6B_ D6B9ABF34537 = c:\WINNT\winsxs\x86_microsoft.msxml 2_6bd6b9abf345378f_4.20.9841.0_none _b7e10f227b2fceff\
Property(S): payload.7B2FCEFF_0F22_B7E1_FF6B_D6B 9ABF34537 = c:\WINNT\winsxs\x86_Microsoft.MSXML 2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
Property(S): WinSxsManifests.7B2FCEFF_0F22_B7E1_ FF6B_D6B9ABF34537 = c:\WINNT\winsxs\Manifests\
Property(S): WindowsFolder.7B2FCEFF_0F22_B7E1_FF 6B_D6B9ABF34537 = c:\WINNT\
Property(S): SystemFolder.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 = c:\WINNT\system32\
Property(S): WinSxsPolicies.7B2FCEFF_0F22_B7E1_F F6B_D6B9ABF34537 = c:\WINNT\winsxs\Policies\
Property(S): policydir.7B2FCEFF_0F22_B7E1_FF6B_D 6B9ABF34537 = c:\WINNT\winsxs\Policies\x86_Micros oft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\
Property(S): policydir_ul.7B2FCEFF_0F22_B7E1_FF6 B_D6B9ABF34537 = c:\WINNT\winsxs\x86_Microsoft.MSXML 2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
Property(S): WinSxsDirectory.DA6654F6_456F_3658_ FF6B_D6B9ABF34537 = c:\WINNT\winsxs\
Property(S): payload_ul.DA6654F6_456F_3658_FF6B_ D6B9ABF34537 = c:\WINNT\winsxs\x86_microsoft.msxml 2r_6bd6b9abf345378f_4.1.0.0_none_36 58456fda6654f6\
Property(S): payload.DA6654F6_456F_3658_FF6B_D6B 9ABF34537 = c:\WINNT\winsxs\x86_Microsoft.MSXML 2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
Property(S): WinSxsManifests.DA6654F6_456F_3658_ FF6B_D6B9ABF34537 = c:\WINNT\winsxs\Manifests\
Property(S): WindowsFolder.DA6654F6_456F_3658_FF 6B_D6B9ABF34537 = c:\WINNT\
Property(S): SystemFolder.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 = c:\WINNT\system32\
Property(S): WinSxsPolicies.DA6654F6_456F_3658_F F6B_D6B9ABF34537 = c:\WINNT\winsxs\Policies\
Property(S): policydir.DA6654F6_456F_3658_FF6B_D 6B9ABF34537 = c:\WINNT\winsxs\Policies\x86_Micros oft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\
Property(S): policydir_ul.DA6654F6_456F_3658_FF6 B_D6B9ABF34537 = c:\WINNT\winsxs\x86_Microsoft.MSXML 2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
Property(S): WinSxsDirectory.0E9F98FC_A692_A6DF_ FF6B_D6B9ABF34537 = c:\WINNT\winsxs\
Property(S): payload_ul.0E9F98FC_A692_A6DF_FF6B_ D6B9ABF34537 = c:\WINNT\winsxs\x86_policy.4.20.mic rosoft.msxml2_6bd6b9abf345378f_4.20 .9841.0_none_a6dfa6920e9f98fc\
Property(S): WinSxsPolicies.0E9F98FC_A692_A6DF_F F6B_D6B9ABF34537 = c:\WINNT\winsxs\Policies\
Property(S): policydir.0E9F98FC_A692_A6DF_FF6B_D 6B9ABF34537 = c:\WINNT\winsxs\Policies\x86_policy .4.20.Microsoft.MSXML2_6bd6b9abf345 378f_x-ww_88e8eab8\
Property(S): WindowsFolder.0E9F98FC_A692_A6DF_FF 6B_D6B9ABF34537 = c:\WINNT\
Property(S): SystemFolder.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 = c:\WINNT\system32\
Property(S): WinSxsManifests.0E9F98FC_A692_A6DF_ FF6B_D6B9ABF34537 = c:\WINNT\winsxs\Manifests\
Property(S): payload.0E9F98FC_A692_A6DF_FF6B_D6B 9ABF34537 = c:\WINNT\winsxs\x86_policy.4.20.Mic rosoft.MSXML2_6bd6b9abf345378f_4.20 .9841.0_x-ww_ff05e224\
Property(S): policydir_ul.0E9F98FC_A692_A6DF_FF6 B_D6B9ABF34537 = c:\WINNT\winsxs\x86_policy.4.20.Mic rosoft.MSXML2_6bd6b9abf345378f_4.20 .9841.0_x-ww_ff05e224\
Property(S): DesktopFolder.4576A2F1_959E_4BCA_94 A9_596523761901 = c:\Documents and Settings\All Users\Desktop\
Property(S): ProgramMenuFolder.4576A2F1_959E_4BC A_94A9_596523761901 = c:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): MenuMSXML.4576A2F1_959E_4BCA_94A9_5 96523761901 = c:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\
Property(S): DOC.4576A2F1_959E_4BCA_94A9_5965237 61901 = c:\Program Files\MSXML 4.0\doc\
Property(S): LIB.4576A2F1_959E_4BCA_94A9_5965237 61901 = c:\Program Files\MSXML 4.0\lib\
Property(S): INC.4576A2F1_959E_4BCA_94A9_5965237 61901 = c:\Program Files\MSXML 4.0\inc\
Property(S): CommonFilesFolder = c:\Program Files\Common Files\
Property(S): MicrosoftShared.3FB7DAB3_19E7_40A0_ 8730_4482CE77AC59 = c:\Program Files\Common Files\Microsoft Shared\
Property(S): MSDN.3FB7DAB3_19E7_40A0_8730_4482CE 77AC59 = c:\Program Files\Common Files\Microsoft Shared\MSDN\
Property(S): Date = 3/6/2007
Property(S): PackagecodeChanging = 1
Property(S): REBOOT = ReallySuppress
Property(S): CURRENTDIRECTORY = c:\6e006e1c029410c635f6d2f79f13a7
Property(S): CLIENTUILEVEL = 3
Property(S): CLIENTPROCESSID = 2492
Property(S): VersionDatabase = 200
Property(S): VersionMsi = 3.01
Property(S): WindowsBuild = 2600
Property(S): ServicePackLevel = 2
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): WindowsFolder = c:\WINNT\
Property(S): WindowsVolume = c:\
Property(S): SystemFolder = C:\WINNT\system32\
Property(S): System16Folder = C:\WINNT\system\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\WINNT\TEMP\
Property(S): AppDataFolder = C:\WINNT\system32\config\systemprof ile\Application Data\
Property(S): FavoritesFolder = C:\WINNT\system32\config\systemprof ile\Favorites\
Property(S): NetHoodFolder = C:\WINNT\system32\config\systemprof ile\NetHood\
Property(S): PersonalFolder = C:\WINNT\system32\config\systemprof ile\My Documents\
Property(S): PrintHoodFolder = C:\WINNT\system32\config\systemprof ile\PrintHood\
Property(S): RecentFolder = C:\WINNT\system32\config\systemprof ile\Recent\
Property(S): SendToFolder = C:\WINNT\system32\config\systemprof ile\SendTo\
Property(S): TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property(S): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(S): LocalAppDataFolder = C:\WINNT\system32\config\systemprof ile\Local Settings\Application Data\
Property(S): MyPicturesFolder = C:\WINNT\system32\config\systemprof ile\My Documents\My Pictures\
Property(S): AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property(S): ProgramMenuFolder = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): StartMenuFolder = C:\Documents and Settings\All Users\Start Menu\
Property(S): FontsFolder = C:\WINNT\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): Intel = 6
Property(S): PhysicalMemory = 1023
Property(S): VirtualMemory = 1324
Property(S): AdminUser = 1
Property(S): LogonUser = SYSTEM
Property(S): UserSID = S-1-5-18
Property(S): UserLanguageID = 1033
Property(S): ComputerName = RINGO
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 1400
Property(S): ScreenY = 1050
Property(S): CaptionHeight = 37
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 20
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 3:00:34
Property(S): MsiNetAssemblySupport = 1.0.3705.288
Property(S): MsiWin32AssemblySupport = 5.1.2600.3019
Property(S): RedirectedDllSupport = 2
Property(S): Privileged = 1
Property(S): DATABASE = c:\WINNT\Installer\33d31b5.msi
Property(S): OriginalDatabase = c:\6e006e1c029410c635f6d2f79f13a7\m sxml.msi
Property(S): UILevel = 2
Property(S): ACTION = INSTALL
Property(S): ROOTDRIVE = c:\
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): SOURCEDIR = c:\6e006e1c029410c635f6d2f79f13a7\
Property(S): SourcedirProduct = {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Property(S): ProductToBeRegistered = 1
MSI (s) (B0:A4) [03:00:34:169]: Note: 1: 1707
MSI (s) (B0:A4) [03:00:34:169]: Product: MSXML 4.0 SP2 (KB927978) -- Installation completed successfully.
MSI (s) (B0:A4) [03:00:34:419]: Cleaning up uninstalled install packages, if any exist
MSI (s) (B0:A4) [03:00:34:419]: MainEngineThread is returning 0
MSI (s) (B0:CC) [03:00:34:520]: Destroying RemoteAPI object.
MSI (s) (B0:80) [03:00:34:520]: Custom Action Manager thread ending.
=== Logging stopped: 3/6/2007 3:00:34 ===
MSI (c) (BC:3C) [03:00:34:530]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (BC:3C) [03:00:34:530]: MainEngineThread is returning 0
=== Verbose logging stopped: 3/6/2007 3:00:34 ===
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
