Go Back   HondaSwap Forums > Members' Corner > Computers, Games, Electronics etc
Need a new NIC card.
Once You Know, You Newegg
Old 05-28-2007, 04:57 PM   #1
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
Default Need a new NIC card.
That supports both wireless and wired connections. My laptops current NIC sucks cock worse than Paris Hilton.
My wireless doesn't work at all, and if I move my laptop it disconnects my cable until i fudge around with it.
I have a *cough* Dell Inspiron 2200.
Any suggestions? I've searched endlessly for notbook NICs, but can't seem to find any.
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
Old 05-28-2007, 05:06 PM   #2
Gonzo Scientist
TommyTheCat's Avatar
Ride:  96 Ford Escort
Rep Power: 36 TommyTheCat is a glorious beacon of lightTommyTheCat is a glorious beacon of lightTommyTheCat is a glorious beacon of lightTommyTheCat is a glorious beacon of lightTommyTheCat is a glorious beacon of light
As Colbert would say: "Wireless or Wired - Pick a side, we're at war"
I don't think you can get both in one device/card.
Tommythecat had many a story to tell, but it was a rare occasion, such as this, that he did.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
http://www.woostercollective.com/
TommyTheCat is offline   Reply With Quote
Old 05-28-2007, 05:30 PM   #3
2265787829
2000Si's Avatar
uh... I have both in one card right now.
Old 05-28-2007, 06:56 PM   #4
Rep Power: 68 endlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant future
I would suggest getting the same maker as the router you're using to make it easier for compatibility.
And, why would you want both? I think a LAN is useless on laptops because most laptops are meant for mobile use and the LAN hardly gets any usage.
I can see two scenarios 1)No WLAN avaliable 2)Gaming laptop.
endlesszeal is offline   Reply With Quote
Old 05-28-2007, 07:15 PM   #5
2265787829
2000Si's Avatar
My laptop is used for both work and play.
If I'm at home I plug it in to get my 100 Mbps. If i'm out and about and I find a wireless spot I like to get on to check in with our office manager, or surf the web while I'm waiting for something to do. If I go on long trips it's useful to look up mapquest in a parking lot also.
I need em both.
My router is one that Verizon gave us.
Old 05-28-2007, 08:00 PM   #6
2265787829
2000Si's Avatar
So any other suggestions other than how a LAN connection is useless on a laptop?
Old 05-28-2007, 08:13 PM   #7
Picture of Retarded Cat
Battle Pope's Avatar
Ride:  2007 Civic LX
Rep Power: 172 Battle Pope has a reputation beyond repute
Battle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond repute
The main advantage to that 100 Mbit connection is eliminated by the fact that your internet connection likely isn't nearly that fast. The only time you'll see any true benefit to a LAN connection that fast is if you're moving large files across a network a lot which I doubt you do. Just get a router with a Wireless Access Point built in, and a cheap wireless card for your laptop. Both can be had fairly cheap these days. If you don't want to spring for an actual card for the laptop, there's also USB wireless adapters you can buy.
Newegg.com - LINKSYS WRT54GL IEEE 802.3/3u, IEEE 802.11b/g Wireless-G Broadband Router - Retail - Wireless Router with excellent reviews and decently priced.
Newegg.com - LINKSYS WPC55AG 802.11a/b/g Dual Band Wireless LAN PCMCIA Card - Retail - Good PCMCIA card.
Customer Reviews Of TRENDnet TEW-429UB USB 2.0, 1.1 Compliant Wireless Adapter with HotSpot Detector - Retail - Decent USB device, has a built-in hotspot detector that tells you if the access point has security. Might be useful since you said you use hotspots some.
Originally Posted by Jeremy Clarkson
A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Battle Pope is offline   Reply With Quote
Old 05-28-2007, 08:28 PM   #8
2265787829
2000Si's Avatar
I realize that it's limited, but I'm also on 15 mbps/down FiOS.
Anyway. Thank you for the links.
Old 05-28-2007, 08:38 PM   #9
Ride:  2007 Civic LX
I did a little more poking around on newegg but I didn't see anything that has both Wireless and Ethernet. I bet it would be a hundred bucks or more though.
What I bet you could do is run a PCMCIA Ethernet card and then just get a USB wireless adapter and only use the USB one when you want a wireless connection. That would be a lot easier than finding one PCMCIA card that does both, I bet.
Old 05-28-2007, 09:43 PM   #10
2265787829
2000Si's Avatar
Thats what I was thinking after trying to find a replacement internal NIC for my laptop over the past week.
Dell... blah. My laptop is a year and a half old. 40 bucks for a 2 year warrenty that I didn't want to finance into it... POS Dell.
Old 05-28-2007, 11:34 PM   #11
2265787829
2000Si's Avatar
I can hear B now
*guitar strumming in background*
"told you so"
Old 05-29-2007, 11:23 AM   #12
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
in all likely hood the ethernet port and networking components are built into your motherboard and cant be replaced.
the wireless (if its built into the laptop) probably connects via a mini-PCI slot on the MB, which can be replaced if needed.
so no, the wired and wireless are not together, they are seperate
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 05-29-2007, 11:44 AM   #13
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
so, you need a network interface card card?
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 05-29-2007, 12:54 PM   #14
2265787829
2000Si's Avatar
Soon as I submitted my thread I knew someone would mention that.
NICard
Old 05-29-2007, 01:20 PM   #15
FALCON PUNCH!!!
Sabz5150's Avatar
Ride:  1989 Accord SE-i
Rep Power: 101 Sabz5150 has a reputation beyond repute
Sabz5150 has a reputation beyond reputeSabz5150 has a reputation beyond reputeSabz5150 has a reputation beyond reputeSabz5150 has a reputation beyond reputeSabz5150 has a reputation beyond reputeSabz5150 has a reputation beyond reputeSabz5150 has a reputation beyond repute
Find yourself a miniPCI card with an Atheros chipset.
Those cards are... neat.
lrwxrwxrwx 1 root root 9 2007-09-24 10:32 /dev/thisissparta -> /dev/null
Sabz5150 is offline   Reply With Quote
Old 05-29-2007, 04:33 PM   #16
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Originally Posted by 2000Si View Post
I can hear B now
"told you so"
Old 05-30-2007, 01:56 PM   #17
2265787829
2000Si's Avatar
I said fuck it all and went to Best Buy. Picked up two Belkin 56g USB wireless adapters. One for the laptop, one for the desktop also.
For 30 bucks each, can't go wrong.
Old 05-30-2007, 02:55 PM   #18
FALCON PUNCH!!!
Sabz5150's Avatar
Model number?
Old 05-30-2007, 05:31 PM   #19
2265787829
2000Si's Avatar
I have no idea, it's a Wireless G USB Network Adapter.
Pic;
Old 05-31-2007, 11:35 PM   #20
my avatar is better.
Rep Power: 52 YouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to behold
Send a message via AIM to YouKnowWhoIBee
There is a guy selling better ones on Hondatech for 10 each So yeah.. .you can go wrong.
YouKnowWhoIBee is offline   Reply With Quote
Old 06-02-2007, 12:25 PM   #21
2265787829
2000Si's Avatar
I needed mine by today, didn't have time to wait. I was out by best buy so I stopped in best buy.
two days for the money to get to him, 2-3 days to get them from him. Nah, I don't think I went wrong anywhere.
