Go Back   HondaSwap Forums > Members' Corner > Computers, Games, Electronics etc
Windows boot problem
Once You Know, You Newegg
Old 06-29-2007, 09:49 PM   #1
Dustin_m's Avatar
Ride:  2001 Jeep Cherokee
Rep Power: 83 Dustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud ofDustin_m has much to be proud of
myspace  FaceBook
Default Windows boot problem
About a week ago, i installed windows on two of my aunts computers. One is an HP and the other was a custom built one. I installed XP Pro on the custom built tower first, then tried to install Windows Home on the HP. When the HP boots up, it never gives you an option to boot from cd, and the current windows install was fubar, so what i did was take the hard drive out and plugged it into the other computer by itself (i removed the other hd). So i went through the install just fine,a nd everything worked great, so i removed the drive and put it back into the HP. Then after returning the other hard drive to its case and turning it on, it asked me which version of windows to boot, Home or Pro.
I can't figure out why its doing that, and why it even knows that i installed home with that machine. Is there memory on the motherboard that can be cleared or something? i even went through and reinstalled Pro on that comp, hoping that it would clear it up and it didnt.
any ideas?
Originally Posted by E_SolSi View Post
frankly ill be surprised if you ever form a post that doesn't read like you are wearing a hockey helmet chewing on a box of crayons drooling all over yourself while you lick the fucking monitor and mash away at the keyboard
My Photostream on Flickr
Dustin_m is offline   Reply With Quote
Old 06-29-2007, 10:47 PM   #2
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
go to control panel, and system. go to something else in there, and you can designate what boots. if i was on an XP machine i would tell you
its on the same screen where you can choose what graphics effects you want and etc.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 06-29-2007, 11:01 PM   #3
Dustin_m's Avatar
myspace  FaceBook
thanks, ill try that out
Old 06-30-2007, 08:01 PM   #4
Dustin_m's Avatar
myspace  FaceBook
so that didn't work. i went into system and under the advanced tab, selected the correct version of Windows as the default OS, but the other version still shows up when it boots up.
Old 06-30-2007, 09:26 PM   #5
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
if you dont want it to show up, you need to remove it from the boot.ini file
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
GSRCRXsi is online now   Reply With Quote
Old 07-01-2007, 04:29 AM   #6
Dustin_m's Avatar
myspace  FaceBook
msconfig, right?
and when i look at the text there, what parts do i remove?
Old 07-01-2007, 04:37 AM   #7
Rep Power: 68 endlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant futureendlesszeal has a brilliant future
Word, gotta edit the boot.ini file.
Heres a good link with somewhat thorough instructions.
How to Use and Edit Boot.ini in Windows XP
endlesszeal is offline   Reply With Quote
Old 07-01-2007, 02:14 PM   #8
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
How to remove a second installation of a Windows operating system from a partition
Anime Informant
reikoshea is offline   Reply With Quote
Old 07-01-2007, 04:31 PM   #9
Dustin_m's Avatar
myspace  FaceBook
Nice. thanks.
Electronical problem with honda accord 95 jay_nightrider General Tech and Maintenance 2 12-04-2006 12:39 PM
Old Problem, Revisted YBLEGAL HYBRID -> EG-EK / DC 4 11-25-2006 08:45 PM
Prelude Power Windows Problem SSL0207 Body / Exterior / Interior / Cosmetics 6 09-18-2006 12:20 AM
VTEC Solenoid problem... Intevic Productions HYBRID -> EG-EK / DC 5 08-17-2006 07:05 AM
Electrical Problem With My 1986 CRX Si The_MATRIX General Tech and Maintenance 0 06-17-2004 06:08 PM
