| | LinkBack | Thread Tools |
| | #1 |
| Senior Member | I'm trying to figure out how to link the following TV Computer Xbox 360 Surround sound do you guys have any suggestions on a wireless modem that i can connect to digital cable? I want to set up wireless internet and an xbox 360 for online gaming and netflix. i want to have the 360 connected to my surround sound and to internet. can i use this? or are there better options? D-Link - Wireless-N Router - DIR-615 |
| | #4 |
| Führer Mod | no.. wire the xbox and surround sound to the tv... only way to go wireless on the xbox is to buy the wireless adapter for the xbox here is a list of compatible routers Home Networking Equipment |
| | #5 |
| Senior Member | i didn't say that right. so i can hook up my coax cable to the wireless modem, then run a hardline from the router to the xbox? i think there is usually 3-4 ports per router. the tv can run it's own cable to the wall outlet. we have several ports. |
| | #7 |
| Senior Member | is it better to use an xbox wireless adapter than running a hardline straight from the router? the other thread had a lot of people with lag time due to wireless. edit: must spread rep. |
| | #8 |
| Führer Mod | you can run the xbox wired straight to the router, thats the way i have mine hooked up.. i just thought you wanted to do it wireless.. ok, so change that dotted line to a solid line.. haha |
| | #10 |
| Führer Mod | i posted a link to a list.. seems to have went down between now and then.. lol... check that link a little later.. it shows all compatible and non-compatible xbox live routers |
| | #13 |
| angry bear Join Date: Oct 2004 Location: Oklahoma Age: 37
iTrader: 1 / 100% Ride: 02 Acura RSX
Rep Power: 57 | depends on how much money you want to spend, I do how ever recommend a "N" router or "N" plus I have this router, and love it, I am running a PS3, Xbox 360, Laptop and Desktop NETGEAR - Wireless-N Router - WNR2000-100NAS a buddy of mine has this router and highly recommended it to me. Hes running a PS3, Xbox 360, 3 laptops & one desktop D-Link - Xtreme N Wireless-N Gigabit Gaming Router with 4-Port Switch - DGL-4500 |
| | #14 | |
| Führer Mod | Quote: | |
| | #17 |
| Senior Member | i think wireless N is over priced for little features. most of our broadband connections cant even max it out. and for the price of 1 wireless N router, u can have two G routers setup with repeater mode and get far better coverage. however, if you plan on streaming HD movies over your network, then its worth while to consider. besides, if you have G stuff mixing with N stuff, usually the speed drops to G anyway. as for connecting your a/v i would actually connect your xbox to your receiver and then your receiver to the tv. provided that you have the a receiver for your surround sound. it lets it do all the processing. BUT, if you want to play games without surround sound all the time, you can have it connect to the TV and the TV out to the receiver. That why you can choose when you want surround sound or not but down side is its messier. lastly, MS are a bunch of pirates. make you u use "official supported" hardware and charge you a premimum, much like APple.. >=( |
| | #18 |
| now its a 91 Join Date: Mar 2007 Location: Acton, CA Age: 22
iTrader: 0 / 0% Ride: 91 civic dx hb with si harness and jdm d15b
Rep Power: 7 | Linksys!! home section of cisco. Get the one that is powered by linux. works great with my xbox, and it has a usb port - easy set up for a file server(usb hd or flash drive works) I have the N version and stream netflix all the time and it works fine, but wired is cheaper(no xbox adapter needed). It also has NAT that will route transmissions to the right ip faster than the older RIP platform, it works good for streaming video and large file transfers. I only vote linksys because I have had D-link and netgear quit on me, D-link multiple time. |
| | #19 | |
| DAT CAT Join Date: Jun 2004 Location: Southern Oregon Coast Age: 24
iTrader: 0 / 0% Ride: 2007 Civic LX
Rep Power: 219 | Just thought I'd take a minute to clear up some muddy terminology, which seems to happen often. Modem - connects to your phone line (dsl) or co-ax (cable), connects you to your ISP. Usually provided by your ISP as a leased device. Router - Connects to the modem, creating a home network, manages interaction between networked devices, and the internet. There is a big distinction here, because in the vast majority of cases, if you search for a wireless modem you will probably not find what you are looking for. You are probably looking for a similar configuration to what I use. Computer and Xbox connected to Router Xbox and Surround Sound connected to TV I use TVersity or PS3mediaserver (works with the 360) to stream movies from my computer to the xbox, which essentially play like DVDs. You could use a far more convoluted setup, of course, if you wanted to.
__________________ Quote:
| | #21 |
Rep Power: 219 | I may be out of the loop, but last I checked WMP media streaming functions doesn't transcode formats... i.e. mkv to mp4 etc. Between TVersity and PS3mediaserver, almost all formats I've tried can be transcode-streamed by one or both. |
| | #22 | |
| Senior Member | Quote:
fyi for those who arent certain, .mkv and .mp4 are containers and .h264 (usually HD files) are file formats that go into the containers along with audio. | |
| | #23 |
| 2265787829 Join Date: Aug 2003 Location: NOT in Indianapolis Age: 27
iTrader: 0 / 0% Ride: Refer to my name, dumbass.
Rep Power: 399 | Your surround sound should be connected to the TV like the Xbox separately. I have my computer connected to my tv, so its my monitor. The surround sound on aux plays tv/xbox, on Music Player setting it plays sound from the computer which I have set up through the headset jack. One of these days I'll hook the computer sound card to the surround sound separately. |
| wireless help | pissedoffsol | Computers, Games, Electronics etc | 9 | 10-08-2007 01:18 PM |
| wireless USB? | GSRCRXsi | Computers, Games, Electronics etc | 19 | 09-19-2007 07:39 AM |
| Motorola SB5100 modem for sale. | 2000Si | Parts: For Sale/Trade/Wanted | 0 | 04-12-2007 07:44 PM |
