i'm writing this in response to Pissedoffsol's article here:
http://www.hondaswap.com/forums/index.php?...=0&#entry306856 i'm pretty sure all 1 wire o2 sensor Hondas are obd0 and all obd1 hondas are 4 wire o2 sensor, with the exception of the VX which had a wide band 5 wire o2 sensor.. i'd be very interested in seeing a 92+ car that utilizes an obd1 ecu that came with a 1 wire o2 sensor.. i talked to several other honda guys i know and they agree with me. show me a helms for a obd1 car with 1w o2 and i'll believe. |
well i did some research this's what i found:
P05 92-95 OBD-1 Civic CX (D15B8) The P05 ECU came with the D15 SOHC non-vtec motor with close-coupled cat and a 1-wire O2 sensor in the 92-95 Civic CX. Basically an OBD1 version of the 88-91 HF motor. FUEL ECONOMY!!! well, i'll say that i'm wrong.. but i still think the article should be more specific on the years and such.. also the DX model has 4 wire o2.. its a P06 ecu. |
RETIRED
obd0 can also use the article- there are just differen't pinouts. and well, a LOT of 4th genner's convert to obd1 with a p28 anyway.
i mean, if you are doing a swap, and find that you have a 1-wire o2 and don't know what to do with it- then you'd start looking for info. if you have a 4, things will plug right in and work |
#5 |
Ride: 2007 Chevrolet Cobalt SS Supercharged
I had a `92 cx a long time ago, that used a single wire o2 sensor.
Is it good when my dipstick is rusty on my jeep? Linux Mint 6.0 "The only man who makes no mistakes is the man who never does anything. Do not be afraid to make mistakes providing you do not make the same one twice." Theodore Roosevelt http://homemodders.com/t188/ |
#6 |
there are two ecu's that are good for obd0 "B-series" swaps.. the obd0 Pr4 and the obd0 Pr3.. the Pm6 ecu works well if you chip it.
there really is no advantage to converting to obd1 unless you are dead set on using hondata S200 system. i have a 93 integra RS that i really wish was obd0, but its too much hassel to convert to obd0. there is alot of ecu rom developement going on at PGMFI for the pm6 ecu.. such that i would prefer to use that ecu. (good for boost) but oh well. there's quite a bit of developement for the obd1 ecus as well.. i just dont think they are to the point where Blundar is with boost on the pm6 in a CX that is obd1, i can see where someone would want to convert to 4 wire o2 sensor tho.. although its a simple transistor add to make the P05 ecu do 4 wire o2 sensor... and a few pins and wires ... to the o2 sensor. |
#7 |
RETIRED
aside from b-series, a LOT of 4th genner's drop d16z6's into their cars. running a p28 is really the only "correct" way to do it. it requires a 4-wire o2 as well.
*correct - I.E. no rpm-based vtec switches/buttons. lol |
#8 | |
Ride: 06 Chevy Silverado
from my original way of activating vtec before I went obd1 on my civic. The 4 wire article is helpful to anyone who is coverting to a 4 wire from a single wire.__________________
Ex 89 crx si,91 & 95 Civic owner. 06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap. |
#10 |
Brutal Moderator
Ride: 97 Integra LS Coupe
Well the first thing you'd probably want to do is to post in a thread that's NOT four years old...
#11 | |
you get the BRAKE
![]() __________________
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
| How to wire vtec | 92b16vx | General Tech Articles | 3 | 06-17-2005 06:13 PM |
| questions | rushcrx | HYBRID -> ED-EF / DA | 6 | 06-29-2004 11:54 PM |
| 92 civic cx with ls motor 4 wire o2 help | lsvtechater | HYBRID -> EG-EK / DC | 2 | 11-04-2003 11:13 PM |
| good sites for stereo installs | WetWilly | Car Audio / Security / Electronic Accessories | 4 | 08-26-2003 12:28 PM |
| How To Make Physical Wire Connections | dkasakitis | ECU's, Electronics, and Tuning | 3 | 01-27-2003 02:01 AM |
