1989 Integra with no Spark
Old 05-11-2006, 08:19 PM   #1
Rep Power: 0 SuperRob is off the scale
Hey guys, my first post here.
I've got an 1989 Integra and it had been running rough for a few days. I thought it was bad gas, but then the other day it just died on me.
I've checked everything that I can think of with the exception of the Ignition Module. and I dont know how to do that. Replaced the Cap, Rotor, Plugs, Wires and the timing belt is ok. The rotor turns when cranking, and the coil tested well both primary and secondary windings.
I've got the distributor sittin on my coffee table right now, and my manual only shows how to test the 86-87 ignitors not the 88-89.
Can anyone help me?
Does this require special tools (oscilliscope? Dwell Meter? cause all I've got is a digital Multimeter {Fluke 77})
Thanks in advance.
I'm on MSN ilovesuperrob(AT)hotmail.com
SuperRob is offline   Reply With Quote
Old 05-12-2006, 08:21 PM   #2
HELP PLEASE!!!!!
*****BUMP*****
Old 05-12-2006, 08:44 PM   #3
Rep Power: 11 lil_red_si is off the scale
Send a message via AIM to lil_red_si Send a message via Yahoo to lil_red_si
should be the same way,....not sure but i think you can interchange almost any honda/acura ignitor...not fo sho tho
<span style=\"font-size:10pt;line-height:100%\"><span style=\"color:#FF0000\">new project!: 1989 crx si.....d16a6 block..all new gaskets, seals and bearings replaced and now BOOSTED!!!&gt;.....SAAB T3 TURBO....HF MANIFOLD...SAAB 2&quot; INTERCOOLER PIPING....DSM BLOW OFF VALVE....SAAB FRONT MOUNT INTERCOOLER.....BOOST BABY BOOST</span></span>
lil_red_si is offline   Reply With Quote
