2 O2 Sensors In Dc Sports Header
Old 03-19-2003, 12:07 AM   #1
Rep Power: 15 steelbuster is off the scale
I am swapping a B16 From a JDM SiR with PW0 ECU into a 89 Si. Thsi ECU requires 2 O2 sensors in order to run in closed loop correctly(See HONDATA TECH ARTICLE) I want to run a DC Sports Header which has only 1 Sensor bung in the collector. Where should the sensors be installed? Maybe try to match factory locations? DCSports doesn't seem to want me to weld in bungs in the header Primary's and I can't get a good answer why not. Any Ideas?
Never to old for SPEED
steelbuster is offline   Reply With Quote
Old 03-19-2003, 12:29 AM   #2
Rep Power: 17 solblu is off the scale
One goes on the cat. It's on the top at the muffler side of the Cat. You can get a "fake" one for that sensor.
<a href=\'http://www.knology.net/~jediklc/\' target=\'_blank\'>My Webpage</a>
<a href=\'http://www.geocities.com/DawgSol94S/Welcome.html\' target=\'_blank\'>Team Sol Georgia</a>
solblu is offline   Reply With Quote
Old 03-19-2003, 06:44 PM   #3
Read this and then let me know what you think about locations.
http://www.hondata.com/techo2problem.html
Old 03-19-2003, 07:04 PM   #4
Rep Power: 16 ryanwolfe911 is off the scale
Send a message via MSN to ryanwolfe911 Send a message via Yahoo to ryanwolfe911
I just drilled a hole and added a second o2 sensor bung right next to the other bung. Of course you have to weld it in. I have done this and it works just fine. Then again you could probably put it anywhere and it wouldnt matter, since OBD0 isn't that sensitive.[color=red][code]
[color=red]If 4 out of 5 people suffer from diahrea, does that mean 1 person enjoys it?
ryanwolfe911 is offline   Reply With Quote
Old 03-19-2003, 09:29 PM   #5
What motor/ECU do you have 911?
FS: DC Sports 4-2-1 Header for D series (ceramic) Calesta Parts: For Sale/Trade/Wanted 8 02-27-2004 02:28 PM
Dc Sports Jdm Header Vs Itr Jdm Header digital_toad General Tech and Maintenance 4 06-08-2003 07:54 PM
Fs: 97-99 Dc Sports Prelude Header Silverchild79 Parts: For Sale/Trade/Wanted 9 05-28-2003 11:08 AM
Header Info 4 Na Junkies JDMilan Engine Building 11 05-13-2003 09:28 PM
Dc Sports Jdm Itr Header. D See 2 General Tech and Maintenance 2 01-13-2003 03:37 AM
