2000 SI Fuel Pump Problem
Old 08-21-2005, 11:35 PM   #1
Rep Power: 9 tuppscivic is off the scale
I purchased a 2000 honda civic si that had a ls darton sleeved block bored out to a 2.1L. The car had an aftermarket accel stand alone, cp pistons, crower rods, msd inline fuel booster, msd ignition, 680cc injectors, stock fuel pump, turbo, ect. I bought the car with a blown motor and desided to swap the stock motor (99 si b16a with about 3000 miles on it) back in. When I turn the ignition on, the fuel pump keeps on running. On all of my other honda's the car primes for about 3 seconds and than stops untill you start the car. I was told not to worry about this, but after about 6 miles, the IAC (EACV) - idle air control valve went out. The other problem is that when you turn the key on, it sounds like the fuel is flowing straight through the regulator and back to the return line. I tried to replace the evaporative emmission control solinoid (on top of the fuel rail, injectors plug into it ), the fuel relay, and the fuel pressure regulator without any change. I checked the ecu wiring, and from what i could see the pump wiring is all stock.
Can anyone tell me what is causing the pump to keep running and would this cause any problems in the future? thanks
tuppscivic is offline   Reply With Quote
Old 08-22-2005, 04:06 AM   #2
VTECin5th's Avatar
Rep Power: 41 VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
bad relay?
k20dc5
VTECin5th is offline   Reply With Quote
Old 08-22-2005, 08:32 AM   #3
Originally posted by VTECin5th@Aug 22 2005, 03:06 AM
bad relay?
Tryed swapping the relay with one out of a 97 civic that works and still no change.
Old 08-24-2005, 03:44 AM   #4
Rep Power: 9 EG_Case is off the scale
Originally posted by tuppscivic+Aug 22 2005, 08:32 AM--><div class='quotetop'>QUOTE(tuppscivic @ Aug 22 2005, 08:32 AM)</div><div class='quotemain'><!--QuoteBegin-VTECin5th@Aug 22 2005, 03:06 AM
bad relay?
[/b][/quote]
maybe the inline fuel pump? or maybe he lied to you and it has a bigger intake fuel pump, i just swapped a walbro 255HP into my car and it stays running from the time i turn the key till i shut it off and you can hear it, if its not that maybe he swaped the Filter on the pump with an aftermarket one, most every aftermarket pump's Filter is known to be loud
BTW the ez way to check if you gotta fuel pump is see what the fuel PSI is at, or let the car run and see if you smell rotten eggs and along with the smell your eyes will start to tear ( its only unburnt fuel ) cant cause nuttin but bad gas milage
with Gas Prices these days its a good thing i dont eat alot of gas but i Pack Alot of Muscle
EG_Case is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
