This is a discussion on 3g civic ecu swap problems in the ECU's, Electronics, and Tuning forum
went to the salvage yard today and got 2 teg ecu's one from a 86 and the other from 87. installed them in a 86 civic si...everything ran fine until it was tach'd out past 5k, then the pgm light came on...never came on with ...
| | #1 |
| went to the salvage yard today and got 2 teg ecu's one from a 86 and the other from 87. installed them in a 86 civic si...everything ran fine until it was tach'd out past 5k, then the pgm light came on...never came on with stock ecu...the tegs ecu flashed its led 8 times...any ideas? |
| | #2 |
| sounds like you are running out of fuel... |
| | #3 |
| Brian, actualy...I went to Barnes and Noble...look up in a acura service manual and found a flash 8 code to be the TDC sensor...well upon inspection of the distributor my friend and I think it to be a combination of things....since the fuel injection is based upon piston position and timing we are going to put a timing light on it and replace the vacum lines to the advance dashpot...the ones on it a in real bad shape...I'm doin this because we never got the ecu code on the stock ecu....since the honda ecu is programed for economy first and this not being the original motor..me thinks the timing could be off a few degrees....since vacum is gone by 5300rpms makes sense that there is no advance when the teg's ecu calls for it...no advance no extra fuel?...trying to troubleshoot it before going out and buying crap he doesn't need!...
__________________ it's funny how a TD05-14g can change your whole outlook for a civic sedan.... |
Similar Threads | ||||
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 12:03 PM |
| O2 Sensor Problems, '97 Civic Swap | redricegti | ECU's, Electronics, and Tuning | 1 | 11-05-2004 10:53 PM |
| 6th gen Civic Basic swap overview | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:14 AM |
| Decoding VIN Numbers | pissedoffsol | General Tech Articles | 0 | 01-11-2004 07:48 PM |
| All This Reference Material, And No Cel Code Chart | Slo86GT | Members' Lounge | 5 | 06-13-2003 09:31 AM |
