90 b18 OBD 0 VS 93 B18 OBD 1
Old 08-14-2004, 08:59 PM   #1
Rep Power: 17 CRseX84 is off the scale
Send a message via AIM to CRseX84 Send a message via MSN to CRseX84 Send a message via Yahoo to CRseX84
hey i have a 92 civic cx and im rebuildin a 90 b18, now the 90 b18 is OBD 0, i dont wana buy a obd conversion harness, so i have 2 ?s
1- what makes the 90 a OBD 0 , the distributor? if so can i put a 92 b18 dizzy in?
2- can i use a 92 teg ECU insted of the 90 with a conversion harness? thanks for the help guys i realy aprechiate it..
Tyler
CRseX84 is offline   Reply With Quote
Old 08-14-2004, 10:52 PM   #2
Rep Power: 26 projectxspeed is off the scale
Send a message via AIM to projectxspeed Send a message via Yahoo to projectxspeed
First, you need to put more thought into your questions before you type. I think your question is: how do you go from obd0 to obd1? The main parts that decide what obd your is ECU, DIZZY, INJECTORS. If you want switch your obd those are the parts you need.
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a>
Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a>
projectxspeed is offline   Reply With Quote
Old 08-14-2004, 11:01 PM   #3
Rep Power: 13 robspeed005 is off the scale
I think if it is possible you need not motor harness off the obd1 motor or any b series obd1 motor. I think they have diff crank positioning sensors also
Call Hasport. email me if you need the number. I have a 93 cx with a b18b in it so let me know if you need help
Rob
robspeed005 is offline   Reply With Quote
Old 08-14-2004, 11:31 PM   #4
Rep Power: 16 handlebarsfsr is an unknown quantity at this point
go to a junkyard and pull the whole wiring harness and intake manifold, complete with dizzy, injectors, fuel rail, etc. bolt the entire piece onto your 90, viola, you have an obd1 b18a.
handlebarsfsr is offline   Reply With Quote
Old 08-15-2004, 09:48 PM   #5
no i have a 92 civic (obd 1) and the b18 is a obd0 motor.. so there for i would have to get a wirring conversion harness and crap. i dont want to play with swichin OBD's i just wana change wut ever i need to on the motor to make it a obd1, it doesnt come with a distributor so i will put what ever one i need, same with injectors and ecu..
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
