Facebook Twitter
91 CRX Si 16v No spark or fuel
This is a discussion on 91 CRX Si 16v No spark or fuel in the ECU's, Electronics, and Tuning forum
So I'm working on a CRX for my budddy it turns over but it has no spark and the fuel pump dosnt come on and the engine dosnt get fuel it has EFI I checked the distributor and it works it's brand new but it ...
Old 04-19-2006, 11:47 PM   #1
So I'm working on a CRX for my budddy it turns over but it has no spark and the fuel pump dosnt come on and the engine dosnt get fuel it has EFI I checked the distributor and it works it's brand new but it dosnt get power to the coil the check engine light comes on and flash's really fast and makes a clicking sound I took the back off to get the the fuel pump I checkd it to see if its getting power it's getting about 6.5to five I think its the ecu that controls the EFI I only have one day left with the car untiill he tows it to a shop.
White_russian5 is offline   Reply With Quote
Old 04-20-2006, 12:20 AM   #2
VTECin5th's Avatar
Originally Posted by White_russian5 @ Apr 20 2006, 12:47 AM) [post=651878
Quoted post[/post]]
Main relay, misc fuses, main fuses, wrong ecu, wrong wiring, altezza tail lights.. it could be anything.. we don't even know what engine/ecu or what year crx?
VTECin5th is offline   Reply With Quote
Old 04-20-2006, 09:35 AM   #3
check your ground at the thermostat and replace your main relay above the hood release lever......bet it is that...i actaully will put money on that
lil_red_si is offline   Reply With Quote
Old 04-20-2006, 12:36 PM   #4
also i remember when my alternator solenoid valve fuse underneath the dash blew my car wouldnt start.....check that one too
Old 04-23-2006, 10:02 PM   #5
Last night we dropped the gas tank to check the fuel pump and it worked we went out and bought a new ecu and relays and still no go. This is starting to get to ne the car cranks the starter turns but there is no spark and the fuel pump dosnt come on when the key is in the on position so far we have changed the main relays, ECU and distributor what else can be the problem. We are almost ready to take the car to the junk yard its driving us insane!
© 2001-2013 HondaSwap.com
