This is a discussion on 91CRXdx DPFI to MPFI ecu jumper help please I beg yu!!!!! in the ECU's, Electronics, and Tuning forum
I am still stuck and my swap isn't fired up yet , I have one quick question for a swap guru , when it comes down to your ecu jumper harness if I got one for a Integra DA , civic , CRX si (al ...
| | #1 |
| I am still stuck and my swap isn't fired up yet , I have one quick question for a swap guru , when it comes down to your ecu jumper harness if I got one for a Integra DA , civic , CRX si (al of these are obd0 but mpfi STOCK ) that is meant for obd0 to obd1 , would this jumper harness work with my 91 Honda CRX dx ( it's DPFI stock ) and I am using the Zerg industries ecu jumper harness obd 0-obd 1 on a p28chipped ecu map for chrome on the B16A swap I am running (ecu wa in a working crx with b16 before obtained from DNR peformance in San Jose and car will turn over but won't start ? I am staring to question the ecu jumper harness have I mistakenly got the wrong one ,??!,?? I see online shopping results on eBay for cheap ecu jumper harness for obd0-obd1 and title goes as is ACURA CIVIC CRX ECU JUMPER OBD0-OBD1 ?!?!? Is the CRX part only meant for the si since its MPFI STOCK? while mine isn't its DPFI original and I just modified my stock harness for the b16swap the RIGHT WAY. I tripple million checked all my connections and I'm good ! Now I do see an expensive BOOMSLANG ECU JUMPER HARNESS DPFI OBD0-OBD1 MPFI for a whomping $150.00!?!? This title I like more than the last it gives me a reassurance that this might be my problem but I want some help from a pro I am still a noob |
Similar Threads | ||||
| 91 civic dpfi to mpfi harness. jumper question. | integraboomer | ECU's, Electronics, and Tuning | 0 | 08-06-2011 08:29 PM |
| Dpfi-mpfi? | StupidSlowEG | General Tech and Maintenance | 3 | 10-13-2008 01:16 PM |
| dpfi to mpfi help.... | TravisCadello | Civic and CRX - EF | 31 | 09-16-2008 09:42 PM |
| DPFI TO MPFI HELP? | turbocharged97l | General Tech and Maintenance | 1 | 04-14-2006 08:36 AM |
| DPFI to MPFI | YangpaNemsay | Engine Building | 2 | 12-26-2004 08:04 PM |
