94 Hb With Gsr Engine Need Help!
Old 07-29-2006, 06:09 PM   #1
eg b18c1
hb9406's Avatar
Ride:  94 HB
Rep Power: 7 hb9406 is on a distinguished road
Default 94 Hb With Gsr Engine Need Help!
I Have A 94 Civic Hb That Had A D15, I Now Have A Obd2 Gsr Engine In The Car. My Question I If I Can Run That Engine With An Obd1 P72 Ecu Of Do I Need 2 Convert My Harness 2 An Obd2 An Run With An Obd2 Ecu?
hb9406 is offline   Reply With Quote
Old 07-30-2006, 12:34 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
you can run it off an obd1 ecu. it will plug right into your car.
you will also need to re-wire the IAB on the intake manifold. There is an article on this in the Swap Articles forum.
the plugs on the motor will be different through.
Easy fix-- get obd1 parts for the alternator, distributor, and injectors
harder fix, less cost - swap plugs and re-wire to make the connections.
cx with d16z6 engine rev problems crxsi HYBRID -> EG-EK / DC 1 09-28-2006 12:06 PM
gsr engine into a dx sedan joemuench HYBRID -> EG-EK / DC 2 12-13-2004 11:06 AM
light weight engine SolPWR Members' Lounge 31 12-11-2003 05:09 PM
ecotec tweakman Members' Lounge 22 09-29-2003 03:23 AM
What is double clutching? Calesta General Tech Articles 0 12-27-2002 03:06 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
