96 LS/Vtec do I have everything?
Old 02-09-2006, 04:00 PM   #1
Rep Power: 8 Abrasintegra is off the scale
Send a message via AIM to Abrasintegra
What's up everyone, I want to make sure I have everything for my LS/Vtec swap. I'll list my parts at the bottom. But I'm not sure on the distributor, I was hoping I could use the one on my LS head but I don't think I can and I can't find any referances online some help here would be appreciated. Here are all the parts I'm going to be throwing on my car in this project.
LS/VTEC
-B16 p&p head w/solinoid cams etc. pluged and drilled for ls/vtec
-B16 p&p intake manifold/Throttle body
-Golden Eagle LS/Vtec conversion
-ARP head studs
-ARP rod bolts
-dowels
-Full LS gasket kit
-B16 Head gasket kit
-ITR oil pump
-ITR water pump
-GSR timing belt
-p72 ecu (still working on getting the engine wire harness)
Misc
-Phantom Grip LSD
-ACT 6 puck clutch
-Fidanza flywheel
-ITR pistons w/rings
-ACL Rod/Main bearings
-Walboro Fuel pump
-AEM fuel rail
-AEM FPR
-440 injectors
-NX wet kit
-One disgruntled wife
I think that's everything. The head is complete, it just doesn't have a distributor. I could use some reasurance before I go pulling my motor out then kicking myself in the ass for missing somthing. Thanks all. If you want you can hit me up on AIM @ AbrasIntegra1234. Thanks again.
Abrasintegra is offline   Reply With Quote
Old 02-10-2006, 08:03 AM   #2
Rep Power: 9 geoffrey is off the scale
What car is this going into and whcih OBD generation are you using, because you haven't listed your electricals and ECU?
geoffrey is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
