#2 | |
!!YTINASNI
There is only one wire on a 92 teg's oxygen sensor. And that is the one you are after. Unless you've converted it to a wide band..
Dismember
#5 |
Dismember
I've always wondered whether it is common practice to splice the gauge into the sensor which the ECU uses and whether that has an adverse effect on the accuracy of the readings.
#7 |
Dismember
I thought you left the stock 02 sensor alone, and ran it to a wideband used exclusively for the gauge/tuning.
#8 | |
yep....mmhhm.......yep...
Ride: 92 PRELUDE SI
i would like to know this also. anyone?
Hugh.......I like money....... "idiocracey" Quote:
#10 | |
Ride: 92 PRELUDE SI
well post pics of the install if its good it might get stickied. i dont think we have any ref. material on this subject yet.
#12 | |
Ride: 92 PRELUDE SI
did it not come with directions? that sucks.....
#14 |
Dismember
Personally, I'd run it to a dedicated wideband. I wouldn't risk hacking up the o2 sensor and causing problems with the ECU readings.
#15 |
F.I. Junkie
Ride: 1996 Civic, 1992 Accord
If it's a narrowband gauge it MUST be used with a narrowband o2 sensor (i.e. tie it into your factory o2 sensor)
If it's a wideband gauge it must be used with a wideband o2 sensor (typically aftermarket) Sounds like you just have a gauge, so you need to tap into your factory o2 sensor. The wire color is black on the o2 sensor harness and then changes colors to white at the plug, and is white on the car's wiring harness I believe.. Don't quote me on that I will try to find some more information on it later tonight and see what I can dig up. __________________
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6- |
#18 |
SOHC VTEC at its best
Ride: 95 Civic EX Coupe
red would be power for the gauge to come on, black wouls be ground. the purple wire would be a signal wire that would get tapped to your signal wire on your stock o2 sensor. if it was a wideband gauge, it would have a wideband o2 sensor with it, and a harness and other stuff. i think the signal wire for a 4wire o2 sensor is green, i think.
95 Civic EX Coupe: GSR suspension rear LCAs & tie bar no PS or A/C Turbonetics t3/t4B (ceramic ball bearing) Super V Trim, Stg 2 .48 A/R Xenocron chipped ecu Greddy Type RS bov Tial 38mm WG GOAUTOWORKS cast mani, 3" DP, WG dump, & oil lines Spearco Intercooler 450cc DSM blue tops walbro 255 HG and ARP studs Aluminum rad/fan combo from GoAutoworks Competition Clutch Stg5 w/4puck disk BF Goodrich Drag Radials Soon to have: 15" Rota Slipstreams tune by Darren in Baton Rouge, LA |
#19 | ||||
I'll be back...
Ride: 06 Mazda 5, 91 Civic DX
![]() Quote:
Real Eyes Realize Real Lies |
#20 | |
F.I. Junkie
Red goes to a switched 12v power source that comes on with the key Black goes to ground Keep in mind that narrowband gauges don't really do any good when you're trying to tune. __________________
-320 WHP EJ6- |
#21 | |
I'll be back...
![]() __________________
#22 |
Ride: 92 integra gs, 03 sonoma zr2
thanks for all ur help and i dont have the kit its supposed to come with just the guage so i gotta piece it together myself which isnt hard just needed to know the signal wire. thanks again
#23 | |
#24 | |
I'll be back...
| air fuel ratio gauge | Dmolchanoff | Prelude | 3 | 04-03-2007 01:15 PM |
| carbonfiber air/ fuel ratio | zoomspeed05 | Parts: For Sale/Trade/Wanted | 11 | 12-02-2004 08:38 PM |
| Fuel ratio for H22 w/ cx fuel pump | twospun | HYBRID -> EG-EK / DC | 0 | 06-16-2004 01:03 AM |
| Air/fuel Ratio | liquid00meth | General Tech and Maintenance | 3 | 02-25-2003 07:58 PM |
| Air/fuel Ratio Gauge Install | EKDRIFTER | ECU's, Electronics, and Tuning | 4 | 02-21-2003 11:33 AM |
