Avoiding Tuning
Old 03-21-2009, 07:47 PM   #51
F**k plastic.
GlassHeadlights's Avatar
GlassHeadlights has a reputation beyond repute
GlassHeadlights has a reputation beyond reputeGlassHeadlights has a reputation beyond reputeGlassHeadlights has a reputation beyond reputeGlassHeadlights has a reputation beyond reputeGlassHeadlights has a reputation beyond repute
Thank you.
If anyone cares I ordered a stock P28 SST chip for my ECU and new NGK spark plugs.
GlassHeadlights is offline   Reply With Quote
Old 03-21-2009, 08:53 PM   #52
F**k plastic.
Oh...I forgot to put in my compression test readings.
Starting at the timing belt moving to the dizzy. 190 ish, 185 ish, 183 ish, 188 ish.
Old 03-21-2009, 10:53 PM   #53
F**k plastic.
I also hooked up my timing light to see where I was. When I brought up the revs from idle the timing went way off. That's normal right?
Old 03-22-2009, 01:51 AM   #54
K2e2vin's Avatar
Ride:  88 Honda Civic HB
K2e2vin has a reputation beyond repute
K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
Compression looks very good.
Yes, the timing will advance if you're revving it up/opening the throttle.
Old 03-23-2009, 10:58 PM   #55
FI FTW.
Matts96HB's Avatar
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Dude, if you're looking for a tuner in the Seattle/Tacoma area, try SpeedFactory. They do excellent work. If you're willing to drive a little further, Kaizenspeed is also in the area.
Matts96HB is offline   Reply With Quote
Old 03-23-2009, 11:01 PM   #56
F**k plastic.
Thanks, although I don't think I'm tuning anymore.
Old 03-23-2009, 11:15 PM   #57
übber ɐɾuıu etarip
Z6CRX's Avatar
Ride:  1995 BMW 318ti, 1985 Honda VF500F(now legal)
Z6CRX has a reputation beyond repute
Z6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond repute
Send a message via AIM to Z6CRX Send a message via Yahoo to Z6CRX myspace  FaceBook
good to hear.
Are you familiar with chipping an ECU or are you sending out or having someone you know do it?
Z6CRX is offline   Reply With Quote
Old 03-23-2009, 11:52 PM   #58
F**k plastic.
I already have a chipped P06 ECU. I just bought a SST chip with a D16Z6 stock basemap on it so I can just pull the old chip out and pop the new one in and be on my way.
Old 03-24-2009, 11:39 AM   #59
übber ɐɾuıu etarip
Z6CRX's Avatar
make sure of that, some people are jerks and solder the chips right in instead of putting a socked in place.
Old 03-24-2009, 04:50 PM   #60
F**k plastic.
This is what I have:
Old 03-24-2009, 04:50 PM   #61
F**k plastic.
I know its fine.
Old 03-24-2009, 09:47 PM   #62
übber ɐɾuıu etarip
Z6CRX's Avatar
that makes things 100x easier. looks like a zif socket.
Old 03-24-2009, 09:48 PM   #63
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
Hmm, good info here. I'm marking this down for later use.
To the OP, best of luck.
Luis998 is offline   Reply With Quote
Old 03-24-2009, 09:53 PM   #64
F**k plastic.
Yes it does. It has a CN2 port too.
Old 03-24-2009, 09:55 PM   #65
Honda Enthusiast
Luis998's Avatar
I have a question concerning the timing, Kevin or to anyone else that may be able to guide me in the right direction.
When doing a mini-me like the OP is doing, would switching the cam gear from the original B7 head to the Z6 head (from what I know this is possible) would one still have to set their timing or would everything be all right? I know that the teeth count is different and this is why one needs to adjust the timing. At times an adjustable cam gear is reccomended but I am wondering if this would be a simpler way to do things.
To the OP, best of luck on everything to you my friend. Keep us updated. I am curious to know how everything turns out for you as I have a somewhat similar project that I may take on in the near future.
P.S. Ah crap, sorry about the double posting.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
http://hondaswap.com/members-lounge/...thread-278554/
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Old 03-24-2009, 10:26 PM   #66
F**k plastic.
I think it would be fine if you used a B7 timing belt but idk.
Old 03-24-2009, 10:46 PM   #67
Honda Enthusiast
Luis998's Avatar
If you were using the Z6 head with everything you could not use the B7 timing belt. The number of teeth are different. I'm thinking though that if I were to switch the cam gears and match them that perhaps I would be able to use all Y7 components, in my case i.e. timing belt, water pump, cam gear...etc. etc. and not have to do anything to the timing. Again, this is just sheer speculation on my part. I have a freakin' book with a TON of write-ups on it but I haven't been able to find it since I moved. Ugh! That and my total web time is limited to whatever I can get at my first job.
Anywho, I hope to be able to get a lot of good information from this thread. I'll probably end up printing it out and putting it in my book.
Old 03-24-2009, 10:59 PM   #68
K2e2vin's Avatar
If I recall correctly, the only time you'd need to swap cam gears is when going from non-VTEC D15 to VTEC.
The cam gear on the B7 is exactly the same as the Z6(PM3B).
As far as waterpump, etc. goes you'd have to use corresponding block compenents(ie, Y7 block; just use Y7 waterpump and tensioner). Every gear has the same tooth count; differences are within the tensioner(I believe the non-VTEC D15s have larger tensioners; which is why you use a Z6 belt when doing a mini-me).
Old 03-24-2009, 11:04 PM   #69
F**k plastic.
I thought you were doing a swap.
I have already done my mini-me swap. Its been driving for 6000 miles now. It was a bit of a practice run because I didn't know if the head was good but it did better than I ever expected. I expected it to last for a week due to the used headgasket but its still trukin' along.
I just used the stock A6 bottom end, removed the oil jet, put the head on and used a Z6 timimg belt. Thats the correct way to do it with my set up. Somewhere I read you use the timing belt to match the head but idk.
1990 Celestial Blue CRX Si
-A6/Z6 Mini-Me w/Y8 IM and I/H/E //////////////////
-Function & Form Type 1's
Originally Posted by A notable gynecologist
The best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so fucking temperamental.
Old 03-24-2009, 11:14 PM   #70
Honda Enthusiast
Luis998's Avatar
Ahh! That explains a LOT! I've always wondered when the teeth count made a difference and why. That really clears it up for me, Kevin. Thank you! Rep!
All I will have to make sure is to get a tune and my set-up will be good to go. Thanks again.
EDIT: Ugh! I can't rep! My freakin' kayak needs to be spread around more. Thanks anyways though, Kevin. I think I may have accidentally reported the post. I feel like such a newb now. haha If I did report it, B, E, Clint and every other letter in the alphabet, please ignore that.
Old 03-24-2009, 11:57 PM   #71
Not a real OG lol
OGMatt's Avatar
Ride:  89' CRX Si
OGMatt has a reputation beyond repute
OGMatt has a reputation beyond reputeOGMatt has a reputation beyond reputeOGMatt has a reputation beyond repute
we have a chaterbox on are hands lol
OGMatt is offline   Reply With Quote
Old 03-31-2009, 10:26 PM   #72
F**k plastic.
I got the chip and plugs in yesterday.
I put the chip in today and it made things worse.
The motor shakes and doesn't idle smooth like it does with the basemap I had on it before.
I set the timing with that chip in and it helped a bit but not much.
What does detonation sound like? I put my ear by the combustion chamber and revved it up to about 1100-1200 RPM and I heard some sound of knock. It may be a valve but it kinda sounded like a spark plug igniting.
I'm thinking I'm gonna get it tuned.
Old 04-01-2009, 03:42 AM   #73
K2e2vin's Avatar
Detonation sounds like "tinking". Probably best to use a stethoscope or "det can".
Do you know exactly what map you had in there before? Sounds like the maps are different. Have you tried resetting your ECU by unhooking the battery?
Old 04-01-2009, 09:22 AM   #74
F**k plastic.
When I bought the ecu I got a free basemap put on. I told him I basically have a D16Z6 with a 10:1 compression ratio.
The chip I just bought was for a stock D16Z6, and it runs worse on it.
When I changed out the chip I unhooked the ecu.
I'm not working today so I'll take a better look.
Old 04-01-2009, 03:11 PM   #75
übber ɐɾuıu etarip
Z6CRX's Avatar
yeah.. that just sounds weird.
I know a higher octane would offset this, but at 10:1 it shouldn't be pinging.
ecu tuning 101? jspeccrx91 ECU's, Electronics, and Tuning 6 01-28-2009 04:04 PM
NEW HERE!!-need help with tuning!! loops ECU's, Electronics, and Tuning 6 10-04-2008 05:55 PM
best ecu for tuning? stmotorsports ECU's, Electronics, and Tuning 18 04-25-2007 05:31 PM
Tuning ctfinest Members' Lounge 2 03-15-2007 03:16 PM
Help Tuning! Uk Civic HYBRID -> EG-EK / DC 7 08-28-2003 12:11 AM
