b16a 2nd gen swap questions
Old 10-20-2002, 08:40 PM   #1
Rep Power: 16 ksrcivic is off the scale
new at this so i don't know what is right and wrong, i have a 95 civic ex stick 2 door, i got a 93 b16a 2nd gen sir II swap, what i need to know is if my engine wiring harness will work i was told by a local shop that my harness will plug right in all i would need to do is just extend some wires to make it all fit, other than that it shold just plug in and work, also I was told that my stock p28 ecu would drive the b16a with no problem, I already chipped the ecu to b16a spec, so what I would like to know is if the info i was given on the wiring harness and ecu is correct and if not what will i need to rewire/what ecu would i need, any help would be great.
ksrcivic is offline   Reply With Quote
Old 10-21-2002, 11:48 AM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
if the ECU has already been modified your all set your harness will work fine
МОΛΏΝ ΛΑΒΈ
E_SolSi is online now   Reply With Quote
Old 10-21-2002, 07:32 PM   #3
thanks for the info, should I just go with a p30 ecu instead, because it has the knock sensor in it or should i just stick with my modified p28 and not use the knock sensor? If I go with the p30 will it plug right into my harness or will i have to modify it to work? thanks again for all your help.
Old 10-21-2002, 07:48 PM   #4
E_SolSi's Avatar
if your using an aggressive fuel curve and good gas 93+ and get the thing tuned youll be fine... the knock sensor isnt important if you tune your engine and fuel properly.... i know a few people running B18C5s with the P28 and none of them have had issues
МОΛΏΝ ΛΑΒΈ
Old 10-21-2002, 09:15 PM   #5
B16
B16's Avatar
i use the P28 on my B16(w skunk2/mugen program), stick with your P28, it can be reprogrammed to do anything(as you said, it has been reprogrammed), or you can use in conjunction with a hondata system down the road if you choose to do more fine tuning.
2004 BMW 325i
2000 Mercedes Benz ML 430
99 JDM SiR B16A swap questions DravenVX HYBRID -> EG-EK / DC 22 07-14-2005 06:19 AM
b16a swap in my 89 crx si tranny questions???? optimusprime HYBRID -> ED-EF / DA 4 04-05-2005 09:47 PM
Some quick questions on z6 swap into crx Jeef HYBRID -> ED-EF / DA 2 06-01-2004 04:42 PM
FS B16a tranny, b16a head, Tons of swap parts!!!! WannabeSI Parts: For Sale/Trade/Wanted 9 05-20-2004 10:53 PM
b16a 2nd gen swap questions ksrcivic HYBRID -> EG-EK / DC 4 10-21-2002 07:27 PM
