Bogging
Old 01-22-2007, 05:32 PM   #1
jtornado's Avatar
Ride:  92 Civic Si
Rep Power: 0 jtornado is infamous around these parts
Default Bogging
I have a d16z6 and I dont think im getting the right throttle response and power in low rpm.........its kinda hard to explain but people say it could be my cat or fuel problem. What do you guys think??????????
jtornado is offline   Reply With Quote
Old 01-23-2007, 08:43 PM   #2
drive it like U stole it
custompainter's Avatar
Ride:  99 dx coupe y8, 94 ex coupe z6, 89 teg zc,
Rep Power: 11 custompainter is on a distinguished road
explain a little more of what the car is doing
custompainter is offline   Reply With Quote
Old 01-23-2007, 11:13 PM   #3
Got Rice?
801CRX's Avatar
Ride:  89' CRX HF and 90' Civic Si
Rep Power: 27 801CRX is just really nice801CRX is just really nice801CRX is just really nice801CRX is just really nice
Cap and rotor, plugs and wires.
www.supremacyracing.com
801CRX is offline   Reply With Quote
Old 01-23-2007, 11:33 PM   #4
jtornado's Avatar
Ride:  92 Civic Si
okay well when im driving at lets say 30mph in second and when I shift I hear a low bogging noise and when it gets into a higher rpm it seems like the throttle response is perfect cause at low rpm the throttle response is off it sounds like. okay im going to try to explain this to you in numbers and hopefully you will know what I mean.......111111111112222233344556 7789 and ill try to explain it in rpms when im giving it full throttle........800........900..... ...1000...............1500......200 0.......4000......6000. So when im giving it full throttle at 30 mph in 3rd gear, I dont pick up much speed. Do you kinda know what I mean now?????????
Old 01-23-2007, 11:34 PM   #5
jtornado's Avatar
Ride:  92 Civic Si
My cap.....rotor......plugs......wires are fine.
Old 01-23-2007, 11:35 PM   #6
Got Rice?
801CRX's Avatar
Ummmmm valve lash?
Old 01-24-2007, 09:21 AM   #7
jtornado's Avatar
Ride:  92 Civic Si
what exactly does that mean???????
Old 02-07-2007, 08:55 PM   #8
Rep Power: 16 killercannible will become famous soon enough
same thing happened to me when i put in my b16, looked at everything with the one dreadfull thought in the back of my head which of course turned out to be the problem. Timing belt was off a tooth, sliped it off and realined it and i was in business. Take off your valve cover and timing belt cover and check it.
Got my swap!!! Needs to be faster.
killercannible is offline   Reply With Quote
92 prelude bogging at low rpms and idle DarkmanA Prelude 77 02-05-2008 09:37 PM
b16 obd0 - Bogging Nightmare! wougoose HYBRID -> ED-EF / DA 19 11-23-2006 05:09 AM
d16y5 bogging bad byebyebaby HYBRID -> ED-EF / DA 5 11-22-2006 10:10 PM
Civic Bogging Out paraplegic Civic and del Sol - EG and EK 1 07-27-2006 04:56 PM
bogging at 4500 rpm sil180drifter Forced Induction 6 09-03-2003 09:04 AM
